Old Apr 25, 2009, 10:52 PM
acurusaragon is offline
Find More Posts by acurusaragon
Malaysia
Joined Jul 2008
My first sailplane with Flaps ie 2 servos on each wing - Help!!
I'd been flying e-sailplane for sometimes now, and all of it only have 1 servo on each wing.
Currently I am assembling a e-sailpane with flaps ie 2 servos on each wing.
Anybody is kind enough to explain the setup on this type of wing? What are these flaps suppose to do and when should it be used?
Is it the same as the normal aileron functions? Thanks guys.
acurusaragon is offline Find More Posts by acurusaragon
Old Apr 25, 2009, 11:11 PM
Zerts is offline
Find More Posts by Zerts
John,not Zerts.JOHN, NOT Zerts
USA, AZ, Chandler
Joined Nov 2007
Crow or butterfly - steepens glide slope for landing or diving out of thermals without fear of excessive speed folding wing. Flaps down sharply, ailerons up.
Full-span camber control - for optimum airfoil while thermalling or speeding across sink, for example. Flap moves up or down small amount, aligned with aileron.
Aileron with flap - provides full-span aileron for faster roll rate or less drag when making frequent small corrections while thermalling. Aileron travels up or down more than flap (see illustration in Hiitec radio pdf below)
Does your radio have at least capability such as this one? (Sailplane programming starts on page 28 of the pdf)
http://www.hitecrcd.com/product_file...QPCMmanual.pdf
Zerts is offline Find More Posts by Zerts
Old Apr 25, 2009, 11:16 PM
Malaysia
Joined Jul 2008
I think my radio should have the function .... But I'd yet to explore it
Anyway I'm on 12FG . Thanks
But what really the real function of having these flaps?
Old Apr 25, 2009, 11:19 PM
Malaysia
Joined Jul 2008
Zerts ... Thanks for the explanation . I shall further explore the meaning of each functions
Old Apr 27, 2009, 05:49 PM
Vito is offline
Find More Posts by Vito
USA, PA, New Hope
Joined Nov 2001
Acuru,
I just maidened a GEM with 4 servos in the wing. I have the flaps on a 3-position switch to be used for landing mainly. This plane floats forever and the theory is that with some significant flap deployment, it slows the plane and increases lift. I need to mix some down elevator to keep the pitch stable. I test the amount of elevator compensation at altitude to avoid any bumps. I needed a 7-channel Rx to get signals to all the servos and a Y- cable to attach an external BEC (too many servos for ine built in BEC)
Vito
Vito is offline Find More Posts by Vito
Old Jul 10, 2009, 06:42 AM
Malaysia
Joined Jul 2008
Originally Posted by Vito
Acuru,
Vito
Vito, mind sharing the type of servos that u used for the aileron , flaps and the ruddervator?
Old Jul 10, 2009, 07:41 AM
Vito is offline
USA, PA, New Hope
Joined Nov 2001
Sure,
I am usually pretty cheap, but sprung for 4 Hitec 125MG servos for the wings. I reverted to normal with HS 81s for the tail. I got the best price at Tower with $ off. I fiddled with the wing servos quite a bit to get then installed. The 125s are thin but pretty much fill the holes. It worked well and fit under the provided servo covers.
BTW - I love the flaps. I have used flaperons in the past and these are much more effective. Since the ailerons are free to roll as needed, the whole process is slick. I come in to land pretty hot and flip the flaps on and put it where I want it. No more watching as the glider floats past and into the weeds.
Vito
Yippee! My first FPV flight longer than 2-3 minutes and with OSD! Shift FPV Talk 9 Jul 24, 2008 10:23 AM
For Sale New Omega 2.5 Electric With Flaps BLUE & SERVOS CARBON KEVLAR FUSE UNPAINTED bipe22 Aircraft - Sailplanes (FS/W) 1 Jul 15, 2008 12:27 AM
Discussion My first flights with the Slowhawk 2: awesome!!!! bennetje Ornithopters 66 Mar 14, 2007 05:11 PM
My first AP with a sailplane... :D Kai@UCSB Aerial Photography 2 Mar 29, 2004 11:23 PM
