Old Apr 25, 2009, 08:12 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
Help!
Timing setting on Hacker/Jeti Master Basic 90A Opto ESC
Hoping someone can help me here:
I have just purchased the Hacker/Jeti Master Basic 90A Opto ESC, but was bummed to find the instructions were in German . The dealer tells me to go the manufacturer's website, so I try www.jetimodel.cz and there is no manual there. I email Jeti and they say I must contact "Mr Hacker". Who the hell is this? Anyway, I did go on to www.hackerbrushless.com and they don't even list the Master Basic series.
Problem 1: I am trying to set the timing and I can just make out from the instructions there are 5 timing settings, each represented by no. of beeps in 5 repetitions. But these don't seem to make much difference to power. I was actually getting around 30% more power on another ESC I was using, so something must be wrong.
Problem 2: The brake seems to be on, as it only emits one beep when arming, and I can hear the brake kick in when I cut power. How do I turn this off? The programming mode only seems to run through the timing options, not any brake options.
Problem 3: The ESC seems to be on a soft start - it takes over 5 seconds to spool up to power. How do I set normal/hard start?
Background info - I am running the Mega FAI (16/25/2 variant) in EDF on 5S or 6S.
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Apr 25, 2009, 09:21 AM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Try this
http://www.hacker-motor.com/images/M...anual-Engl.pdf
Bob
bruff is offline Find More Posts by bruff
Old Apr 25, 2009, 01:42 PM
Joined Oct 2007
Thanks Bob, that's most helpful!
Old Apr 25, 2009, 02:08 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Looking at this website:
http://www.voltmaster.de/controllers...c-90-Opto.html
it seems the "Hacker Master Basic 90 opto" is very similar to the Jeti Spin 90 & Spin 77/99,
http://www.jetimodel.cz/index.php?page=product&id=47
Most likely most features are nearly identical (ie programming) expect possibly the power rating.
So, you can probably program it also with a Spin Box if you or your friends have one, http://www.jetimodel.cz/index.php?page=product&id=34
Herb is offline Find More Posts by Herb
Old Apr 25, 2009, 02:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Keep in mind that the best settings for Mega (6 pole) + Jeti in edf are
http://www.rcgroups.com/forums/showt...6#post11380056
1) brake off
2) timing default = lowest, 3-4 degrees, for best efficiency,
3) everything else default
I have been running several of these jeti/mega combinations for years, and looked at every possible timing combinations,
http://www.rcgroups.com/forums/showt...&page=7&pp=100
A more advanced timing produces a bit more power (+10% or so) but also lower efficiency = more heat generated in motor.
Sold Hacker/Jeti Master 70-O-Flight ESC PDX Slope Pilot Aircraft - Electric - Power Systems (FS/W) 1 Jan 07, 2009 09:47 PM
Sold Hacker/Jeti Master 70-O-Flight ESC PDX Slope Pilot Aircraft - General - Radio Equipment (FS/W) 0 Jan 04, 2009 12:44 AM
Sold Hacker/Jeti Master 18 amp brushless esc muntquist Aircraft - Electric - Power Systems (FS/W) 5 Aug 31, 2007 03:55 PM
Question Need help in governor mode with my Hacker jeti master B 40 H esc. HAL1 Electric Heli Talk 0 Mar 29, 2007 05:49 PM
Hacker Heli Master 48-3P OPTO ESC Blackbird Aircraft - Electric - Helis (FS/W) 1 Aug 12, 2004 08:46 AM
