This thread is privately moderated by Inflexo, who may elect to delete unwanted replies.
Old Aug 19, 2009, 08:02 AM
aerophilia is offline
Find More Posts by aerophilia
building building building!
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Originally Posted by pldaniels
Aerophilia,
The 470uF unit should be fine on this setup, the HXT500's are quite light on the current draw. What receiver are you using?
The other option of course is something like a BAC-004 / BAC-LMA-004
Paul.
Thanks Paul. The receiver is an AR6100.
aerophilia is offline Find More Posts by aerophilia
Old Aug 19, 2009, 05:46 PM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Aerophila,
Yes, the 470uF will be a suitable choice
Well, looks like a busy day for me... so I better get into that workshop and... work.
(if I'm _really_ lucky a helicopter will arrive for me today)
Paul.
Inflexo is offline Find More Posts by Inflexo
Old Aug 19, 2009, 10:18 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
NQRC server is currently "offline" due to a software update that didn't seem to bode so well with our virtual-machine system.
Paul.
Old Aug 20, 2009, 06:12 AM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
Paul.
Curious... what type? Did you get that 400 size heli going?
G
glydr is offline Find More Posts by glydr
Old Aug 20, 2009, 04:25 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
It's a Walkera #62 (belt drive tail). No electronics though It actually is a gift from someone that I've know for a while.
Oh less amusing news, the NQRC server is still waiting to be rebooted.
Old Aug 20, 2009, 08:06 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Server is back... *phew*.
Old Aug 24, 2009, 12:43 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
New NQRC site
The new site is up... would you believe it's taken me a whole couple of days of fiddling and farting, graphics are just horribly time-consuming even with good tools.
I'll likely make a few tweaks here and there as I get around to things or see glitches.
Paul.
Old Aug 25, 2009, 02:41 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Good to see you back up and running Paul. I got a delivery of you doculam film a few days ago, the thickest version. It's impressive stuff! I have used it to cover a set of Depron wings in a pylon racer type plane. Even with the carbon spars in, the film has added tremendous strength. And it stuck to the foam well without melting anything, which is always a bonus. Do you need to prepare the surface before painting? And what sort of paints have you had success with?
Thanks, A.
Old Aug 25, 2009, 03:25 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Hi there Aerophilia,
Nothing like a sequence of unplanned outages to get the heart started.
I'm impressed that the 80um was able to be ironed on without melting the underlying foam, very impressed (normally I have to use the 30um for polystyrene).
As for painting it, it might be a good idea to look into the "Doculam discoveries" thread here on RCGroups - http://www.rcgroups.com/forums/showthread.php?t=274520 ).
It makes sense that the film would add some strength, since it'll resist and tensile forces applied and as we both know, that stuff is insanely tough.
Paul.
Old Aug 25, 2009, 05:00 AM
aerophilia's Avatar
Melbourne Australia
Joined Jun 2006
Thanks Paul, that's a great resource. I knew there'd be something like that around here somewhere!
I had my iron set to about 110 degrees celcius. I was suprised as well how the foam held up to the heat.
Old Aug 26, 2009, 03:33 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Aerophilia,
I'll have to keep that snippet of information in my head for the next time someone asks. Certainly I would have anticipated the EPP to survive for the 30 and 38~42um but wasn't expecting much to survive the 80
I've got some wider rolls of the stuff coming in the next week or two, seems I've about sold out already of the 80, it's very popular.
Paul.
Old Sep 06, 2009, 09:28 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Product stock update
Looking now to getting Corona 4SP1 and RP6D synth receivers for 36MHz. The 4ch ones I've used myself and do nicely for DLGs, the 6ch dual-conversion units are also quite nice with the dual-conversion helping a lot for inter-channel interference rejection.
Prices will be about ~$35, can't be absolutely sure yet as I've not received all the costs. It compares well against the GWS receivers considering you don't need a crystal with these. Certainly a lot cheaper than 2.4GHz units
Paul
Old Sep 07, 2009, 10:02 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
New MM order
Just put through another Mountain Models order
* Slipso400 short kits
* Seether short kits
* More DL50's
* J3 Cub (clipped wing)
Have been trying hard to flesh out the "in stock" items at the store, it's getting there slowly.
If anyone is wanting one of the new MM Firestorm's let me know in advance for the next order.
Cost here in AU will be about $159 AUD. It's a BIG plane (47" span)
( http://www.mountainmodels.com/produc...roducts_id=620 )
Old Sep 12, 2009, 01:15 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Just as a bit of a side note, I'm busy making up a new AP platform for some local fun.
It's a delta-wing, 1.2m span. Build thread is at - http://www.rcgroups.com/forums/showthread.php?t=1107896
Old Sep 16, 2009, 06:19 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
New arrivals - 36MHz receivers
The new Corona receivers arrived today. I've got the single-conversion 4 channel and the dual-conversion 6 channel synthesized units.
I've also got some servos as well that I'm testing out to see if they'll be good replacements for my existing units (9g digital and 12.6g metal-gear analogue).
http://www.nqrc.com/?page=products&catagory=receivers
Paul.
Discussion Mountain Models general banter thread Mountain Models Parkflyers 1860 Nov 13, 2015 08:32 PM
Discussion GuanLi Mirage Speed Contest, Build and General Interest Thread dankers Foamy EDFs 93 Oct 14, 2013 07:42 AM
