This thread is privately moderated by Inflexo, who may elect to delete unwanted replies.
Old Jul 19, 2011, 10:22 AM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Just a note to all... no, I've not been taken over by an alien... I've just had a face and name change due to various factors in life.
Inflexo is offline Find More Posts by Inflexo
Old Oct 24, 2011, 04:20 PM
lornecherry is offline
Find More Posts by lornecherry
Joined Dec 2009
Question about Power Distribution Board
Hi Paul:
...got 2 of your compact BACs and they work well. Question 'bout the redundant battery distribution board that I want to try in a full house or big scale E-glider.
If I use one tap from the BEC (switching - good quality) that comes built into the ESC, can I simply run a Life into the other port of the distribution board? If the ESC blows up/shorts/smokes/overheats, would it/could affect the distribution board, or would the board do its job by auto switching to the LiFe. Asking this because I'd like to save the weight of a 2nd Life, if the main motor Lipo is powering a switching BEC already.
lornecherry is offline Find More Posts by lornecherry
Old Nov 01, 2011, 05:52 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Hi there Lornecherry, sorry about the protracted delay in this reply...
If you put a schottky diode on the +ve line of the "spare" LiFe pack and the power out of the BEC, then yes, it could well work. The purpose of the schottky is to prevent the power sources pushing their way into each other. With the schottky diodes, what ever source has the higher voltage will win out.
Perhaps you can draw up a diagram to demonstrate your configuration?
Old Nov 03, 2011, 09:58 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Latest projects
Just a quick note of new products being worked on -
PLD-LOM7: Precision Low-Ohms-Meter, serious bit of high end gear for high current diagnostics
Status: On sale
http://nqrc.com?vp=PLD-LOM7
PLD-SCC1: Battery fuel gauge (0~10A, 4~8.5V),
Status: developed, sold and now back in PREORDER status
http://nqrc.com?vp=PLD-SCC1
http://www.rcgroups.com/forums/showthread.php?t=1477133
PLD-SLOGGER1: Servo pulse, voltage and current logger, proto PCB submitted
Status - Prototype PCBs submitted
http://www.rcgroups.com/forums/showthread.php?t=1533259
PLD-SFUSE1: Servo fuse, signal booster and filter combination, will have option of either a polyfuse (resetting) or a blow-once replaceable fuse
http://www.rcgroups.com/forums/showthread.php?t=1533260
PLD-BACALL: Combination 1S booster BAC with USB/5V integrated charging, voltage reporting, low voltage alarm and lost model alarm option
http://www.rcgroups.com/forums/showthread.php?t=1533263
PLD-MCC1: Same as the PLD-SCC1 but with a 30V, 30A capability, making it ideal for medium size electric models
http://www.rcgroups.com/forums/showthread.php?t=1533265
Old Nov 05, 2011, 06:40 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Another new development tonight;
PLD-POWERBUS-MINI: Run up to 6 servos off a separate power to the RX, preventing brownouts/lockouts. Complete with low-ESR decoupling caps and LED indicators.
http://www.rcgroups.com/forums/showthread.php?t=1534282
Old Nov 06, 2011, 12:28 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
PLD-ESJ100: Switch up to 100A constantly, 200A peak. Inherent spark suppression and very low switch losses.
http://www.rcgroups.com/forums/showthread.php?t=1534713
Old Nov 07, 2011, 07:57 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
PLD-POWERBUS-A4: 4 channel servo power bus board with individual regulators per servo channel. Accepts 2S lipo directly.
http://www.rcgroups.com/forums/showthread.php?t=1535957
Old Nov 08, 2011, 05:02 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
PLD-BESJ5AR: 5A BAC ESJ unit, just like the popular PLD-BAC-ESJ unit, except larger and more current carrying ability
http://www.rcgroups.com/forums/showthread.php?t=1536139
Old Nov 08, 2011, 01:50 PM
Tony Finn is offline
Find More Posts by Tony Finn
Tony Finn's Avatar
Australia, QLD, Gordonvale
Joined Jul 2007
LED flasher units
G'day Paul
I have just about fried all my old strobe units and was wandering if you have any thing in the pipe line for a strobe unite that can handle the 450ma or so that the 1m led strips consume. I am typically using about 6 of these led strips on my night flyers and had them spread over 3 of your strobe units providing quite a visual show but have had to resort to using a relay now which is pretty boring in comparison. Would it be possible to use your old strobe design driving say 3 of those 2 amp relays (more chanels would be better) and have it all on a common board.
Rgds Tony
Tony Finn is offline Find More Posts by Tony Finn
Old Nov 08, 2011, 05:46 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Tony,
I'm sure I can modify the original design to cope with higher loads (new PCB).
Paul.
Old Nov 08, 2011, 05:50 PM
Tony Finn's Avatar
Joined Jul 2007
G'day Paul
put me down for 4
Rgds Tony
Old Nov 08, 2011, 08:06 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Tony,
Submitted the new design today - in a few weeks hope to have some good news.
New design uses a different chip, more flash memory, so I can program in some more features, might even be able to program in fade-in/fade-out. The MOSFETs on the new one will deal with 1A no problem. You'll still be able to use the existing programmer (serial). Lastly, I've added a 4th channel and the ability to switch between external power, or internal/RX power (obviously one has to be conservative with the RX option).
Old Nov 08, 2011, 08:12 PM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
PLD-PGMS8: 4 channel programmable LED strobe with serial programming interface
http://www.rcgroups.com/forums/showthread.php?t=1536543
Old Nov 09, 2011, 02:49 PM
Tony Finn's Avatar
Joined Jul 2007
Paul
that will be perfect
Tony
Old Nov 10, 2011, 05:31 AM
Inflexo is offline
Magicsmoke maker
Inflexo's Avatar
Joined Dec 2003
Just had the pleasure of finding a new switching MOSFET with about half the on resistance of the ones I was going to use ( 15mR vs 31mR ), which is GREAT. I'll likely wholesale change over to the new MOSFET which will reduce the wastage in a lot of my products which use the one I used to use before or planned to use ( BAC-ESJ6, PGMS8, BACALL and a couple of others ).
Discussion Mountain Models general banter thread Mountain Models Parkflyers 1860 Nov 13, 2015 08:32 PM
Discussion GuanLi Mirage Speed Contest, Build and General Interest Thread dankers Foamy EDFs 93 Oct 14, 2013 07:42 AM
