This thread is privately moderated by PLD, who may elect to delete unwanted replies.
Old Jun 06, 2009, 05:28 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Extreme Edition of the BAC-004
This is really more of a post-incubator device. I took the standard BAC-004, which is a very nice device already and tried to see what I could 'upgrade' on it.
The new one is the BAC-004 'EE' (or just PLD-BAC-EE), If you take the now standard BAC-004 and make the following changes;
* Quadruple the size of the low-ESR 5V side cap
* Add a 52'C/W heatsink to the regulator (the bare DPAK device alone is 100'C/W
* Add a brown-out/low-voltage detector (eg, below 4.3V)
* Switch to 22AWG wiring
The aim of this version is to give a larger margin of operation compared to the standard BAC-004 unit. The heatsink gives us another 1W dissipation capacity typically over the normal non-heatsink version. The larger low-ESR cap means we can cope with larger 'instant demands' from servos, as well as squelching more ripples.
Now the really new feature here is the brown-out/low-voltage warning. If while you are flying something happens (eg, a servo bind or such) and it pulls the power down below 4.3V for more than a mS or so, it'll register on the BAC unit. The BAC will then blink the "error" LED for each time a brownout has occured (up to about 5 times, then it just stays at 5, no point making it indicate more, since clearly there's an "issue" if you get more than 1 or 2). If there's a brownout detected, it'll also continuously 'pip' the speaker (I might change this) ever couple of seconds to let you know "Oi! something went wrong".
Theoretically we shouldn't see the brownout light trigger but consider it as a "You should check your setup" type light.
Right now I've not got it ready for the store, I'm still running more tests to see what sort of loads are needed to drive it to the brownout situation.
Paul.
PLD is offline Find More Posts by PLD
Old Jun 11, 2009, 01:57 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Okay, around and around we go... so here's another idea to throw some fun in the mix
What about a lipo charger/balancer for small packs, eg, up to 250mAh.
All the bigger ones do 100mA charge steps which tends to be a bit coarse for for smaller packs (and disasterous potentially for 50mA packs etc).
Paul.
Old Jun 11, 2009, 06:27 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
Paul.
My charger/balancer goes down to 100ma and I've used it on 50mah and 70mah cells a bunch with no issues. Generally, the smaller cells can tolerate a bit over 1C with no problems.
Unless you are going to really, really small cells like 10mah, then I think 100mah steps is fine. You'll always be within 50ma of 1C.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Aug 07, 2009, 10:48 PM
Barnes Wallis is offline
Find More Posts by Barnes Wallis
Bradster
Melbourne
Joined Jun 2007
I would like to see module to convert hobby irons from very inaccurate bi metal temperature control to using electronic control, similar to that used on soldering irons.
I get frustrated with my iron because the temp can vary by huge amounts
Barnes Wallis is offline Find More Posts by Barnes Wallis
Old Aug 07, 2009, 10:51 PM
neilmny is offline
Find More Posts by neilmny
Bush Mechanic
neilmny's Avatar
Mt. Dandenong, Australia
Joined Oct 2005
Not a bad idea that one
neilmny is offline Find More Posts by neilmny
Old Aug 07, 2009, 10:59 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Are you referring to the actual covering irons?
Old Aug 08, 2009, 07:17 AM
Joined Nov 2000
Just get a better iron
http://www.coverite.com/accys/covr2700.html
Old Aug 08, 2009, 05:11 PM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
Yes Paul.
Old Aug 19, 2009, 05:02 AM
Bradster
Melbourne
Joined Jun 2007
Yes, I am talking about the covering irons. Until I saw the link for the coverite iron, I have never seen an iron that uses electronic control.
What I had envisioned was a very simple feedback circuit to control the on/off part rather than the bi-metal strip which has a very large hysteresis.
I suppose the fact that you would be switching 240 VAC may make it more difficult at least from the safety point of view.
Old Aug 19, 2009, 05:59 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Yes, alas getting a safe mod for such a thing would be rather difficult. There's a few 240V related projects I'd love to bring to market but having them all certified is just absurdly costly
Paul.
Old Aug 29, 2009, 11:24 PM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
Crazy idea.
BAC for 2 batteries in parallel. When batt A drops below voltage batt B takes over. Without power down batt A cannot be reconnected. If batt A is low on powerup then batt B will be re connected anyway.
I was reading about people wanting to do the LSF 8 hour flights, this could be good for them. Idea being say 2 x 850mAh Lipo (or even 2 x 1000) takes less space (lengthwise) than a 1600mAh (or 2000mAh). Could be for 2S or 3S.
Crazy or not, you be the judge.
Neil.
Old Aug 29, 2009, 11:29 PM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Neil,
Actually a simple 2-schottky-diode configuration works fine for that. The packs will then automagically balance in their depletion concurrently, there won't be a "first A, then B" type large-scale switching. You can expand this out to as many packs as required.
The "downside" is that you lose 0.3V (roughly) in the diode, though if you're feeding into a linear regulator/BAC then it's actually useful as it means the BAC has to dissipate less heat. (at max, say 1A, it'll drop from 3.4W dissipation to 3.1W)
Paul.
Old Aug 30, 2009, 06:57 AM
Joined Nov 2000
http://www.fromeco.org/Products/04FR...b/Default.aspx
http://www.ramrcandramtrack.com/rcfails.html
and more if you care to search for them.
Old Aug 30, 2009, 07:24 AM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
I don't like mechanical switches, specially those rotten fall apart, when you don't want them to, slide switches. I was thinking all electronic perhaps with Pauls, charge plug as the de-activator..............an extension/expansion of the charge/BAC.
Old Sep 11, 2009, 01:27 AM
PLD is offline
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
So... I wonder if I should make my little foam cutter into an actual product...
Rewards for good ideas here.... zagisrule! Aerial Photography 65 Apr 14, 2004 09:52 AM
AVRO Arrow EDF design -- kicking around some ideas byrocat Electric Ducted Fan Jet Talk 16 Jun 10, 2002 12:20 PM
Cool Where Do Babies Come From? Don Sims Humor 0 May 20, 2002 01:33 PM
KALT CYCLONE/Irvine61 multi needle,anyone got the a books or good ideas/tips please donlynn Fuel Heli Talk 0 Apr 14, 2002 09:14 AM
