Oh another thought I had, you could couple it with a 2S50mAh lipo if you really wanted to save weight. That'd give you 8.4V on a full charge to set off the igniter which is reasonably close to 9V.
Paul. |
Latest blog entry: What a change of life. No more R/C.
I have to say, that is one thing that really tests my love for JR at times, really I do like their gear but the disturbing lack of fundamental things like a count-down/up timer on the TX really gets me mad.
You know what'd be good on JR's... a plugon clock/timer that works based on the PPM stream out of the trainer port... trouble is, plug that in and it probably shuts down the RF-transmitter
The bad bit however is that as slick and nice as you might make an additional timer block, it still is an awkward accessory hanging off the TX, something to get knocked off/beaten-up, cause complications.
update
The pressure sensors have been sent - probably a week now before they land here.... then another two years before I use them Paul. |
Doug,
Interesting idea, I did have one in development but things got canned when I ran into the clock-jitter problems with some of the equipment used to do the 'mixing'. I could probably look at the situation again and produce a unit to do the job, likewise a go-slow and compander, all were in demand until the jitter problem forced me to can production of them (nothing like having 300 units ready to go and then having to just trash them ).Paul. |
updates
The pressure sensors have arrived. They're still a little larger than I had anticipated but certainly not "insanely large". They're about the same footprint as the little microcontrollers I use on the BAC units but twice the height. ... now, to make good use of them ![]() Paul. |
I'm not sure I understand the need for another altimeter. We already have:
EagleTree http://www.rc-electronics.org/ http://home.epix.net/~rcbrust/ http://www.magtechinc.net/SkyAssistant.htm and other similar to those. I'd like a servo current logger. Monitor servo current with a fairly fast sample rate, log the data and download to computer. Maybe also a realtime display option. |
Ralph,
What I do have "in design" is a bench-top servo analysis tool that goes far beyond the usual "servo tester" unit. This unit does the following; * End point discovery * Current logging * Jitter/dead spot discovery * Torque / current mapping * Torque limits * Performance/speed testing * Linearity testing It's a hefty device but the problem is that there's a lot of mechanical stuff involved in it and I can't find an easy way to manufacture those bits yet. It also can consume a fair bit of power for the torque testing :| Paul. |
Ralph,
Where this servo tester aims to be "more relevant" to general use is for diagnosing of possibly-dud servos, especially things like 1-tooth-missing events or pitted feedback pots etc. Now as for the current meter, yes, it's moderately simple (you'd probably log amps and volts to give a better picture). Something like that would probably end up being about the size of the BAC-ESJ units but a bit thinner. Paul. |
| Thread Tools | |
| Rewards for good ideas here.... | zagisrule! | Aerial Photography | 65 | Apr 14, 2004 08:52 AM |
| AVRO Arrow EDF design -- kicking around some ideas | byrocat | Electric Ducted Fan Jet Talk | 16 | Jun 10, 2002 11:20 AM |
| Cool Where Do Babies Come From? | Don Sims | Humor | 0 | May 20, 2002 12:33 PM |
| KALT CYCLONE/Irvine61 multi needle,anyone got the a books or good ideas/tips please | donlynn | Fuel Heli Talk | 0 | Apr 14, 2002 08:14 AM |
