This thread is privately moderated by PLD, who may elect to delete unwanted replies.
Old Apr 24, 2009, 09:19 AM
PLD is online now
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Idea
Design incubator - where good ideas come to grow
Got an idea for an electronics device and think that we might be able to turn it into a reality for yourself and the rest of the R/C community? Let us know about it here and see where it can go
Most good ideas are simple, to the point and don't cost the bank.
PLD is online now Find More Posts by PLD
Old May 15, 2009, 12:37 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Okay, for the last few years I've been thinking about making my own altimeter, and now I'm feeling good about some of the sensors I've found on the market, specifically first up the Motorola/Freescale MPXA units which give a very nice "practical" output going from 0 to 5V from 15kPa -> 115kPa respectively (115kPa being roughly sea-level).
Of course, that's the easy bit - the question is, given that there are already many other altimeters out there, what can I do to make them more specific or get into a market niche?
One idea I had was to lug on a 433MHz transmitter and be sending out the altitude constantly, though that'll push the costs up considerably, mostly due to the base-station.
There's a range from the dead-simple devices that just record the maximum height, or the logging devices that handle minutes/hours of data. One thing that -has- always irked me about the existing devices is the absolute lack of support beyond Windows software, now I know 90% of the population uses Windows but there's a higher density of geeks/Linux/Mac users in RCGroups and I'm one of them. Personally I'd rather write software that works on -all- the OS's.
Paul.
Old May 15, 2009, 01:52 AM
neilmny is offline
Find More Posts by neilmny
Bush Mechanic
neilmny's Avatar
Mt. Dandenong, Australia
Joined Oct 2005
Paul,
If you can come up with a "low" cost altimeter that can say record a single flight profile in presettable increments which could then be down loaded to a "low" cost hand held gadget??????????
or
Same as above transmitting to a simple receiver in presettable increments, just a data logger, no displays or such like to keep the cost down???????
neilmny is offline Find More Posts by neilmny
Old May 15, 2009, 02:03 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Neil, the primary cost killers in this concept are as follows;
* pressure sensor ($30 AU each... trying to find a better supplier of course )
* Telemetry link (roughly $40 AU for the pair including matched antennas)
* Output display... could use a 128x32 pixel display... did I mention costs? ($20+)
* Casing, if we're going with a hand-held readout, it's going to bite (it's a big stalling factor on the PIRCAT too).
If the sensor wasn't so insanely expensive things would be a lot easier. I can probably purchase them direct from Freescale but it'll likely need to be at least 100 unit purchases, that's a lot of cash up front.
I must say though, it'd be doubly nice if you could actually just slot a micro-SD card into it and pop that into the computer when you're done, save having to link a cable up all the time and you could use multiple cards for the day's events.... okay, getting over my head again.
Paul.
Paul.
Old May 15, 2009, 02:08 AM
neilmny is offline
Bush Mechanic
neilmny's Avatar
Joined Oct 2005
Originally Posted by pldaniels
.........I must say though, it'd be doubly nice if you could actually just slot a micro-SD card into it and pop that into the computer when you're done.................
I really like this idea. A 2 or 4 gig SD could hold how many flights
Old May 15, 2009, 02:22 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
A stupidly insane number of flights/duration. If you store a 2-byte value every 0.1 seconds, 20bytes/sec .. and there's 2,000,000,000 bytes in a 2GB SD stick... that gives us a nice long long period of time... crazy long. . . . makes you start wanting to do things like putting a temperature and voltage sensor... and... and... here we go again.
Old May 15, 2009, 02:54 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
I've got a pair of the pressure sensors being shipped to me now - probably will take about two weeks, that gives us enough time to bash through a few dozen ideas.
Realistically, adding a voltage and temperature sensor to the mix isn't hard, since all the hardware is already there and the microcontroller can deal with at least 8 different inputs. There's more work in the software side of things, though I've actually already written an application that's portable which could be adjusted... of course there's always Java *bleah*.
Paul.
Old May 15, 2009, 05:15 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Paul, don't forget my "flying fuel gauge" idea. Would be a doddle to add to this if you already have the uC with ADC and 433 link in place. Would certainly be a marketing edge since no one else offers that AND it's insanely useful.
Paul.
jj604 is online now Find More Posts by jj604
Old May 15, 2009, 05:21 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
John,
I think I should just wrap up one of those tiny Asus eeePC's and put it in the plane the way features are being added (I tease, I tease!).
A fuel gauge could be a nice top up if we're going for the do-everything-and-kitchen-sink system. Of course then I have to come up with a coulomb counter to keep track of things, that makes things harder since you either have break the power line or add a hall sensor / current-sensor. For 1~5A it's not a problem, just place the whole gadget in the middle of the line and stick a 0.005R shunt in the way.
Paul
Old May 15, 2009, 05:33 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Remember the info I sent you on the Raztec Hall Effect sensors? Slip over a battery wire if using bullet connectors or use a plug through Deans Male/Female. That's what I had in mind. I did an analog circuit mock-up using an LM331 and 433 modules and it worked fine. Resend you the info if you want. Would add only a few grams, 0-80A linear (less range/more precision with multiple turns). Optimised for 3.3 or 5V supplies. The Coulomb counter doesn't have to be in the airborne unit - it's actually more sensible to have it in your ground display unit I would think.
John
Paul
Old May 15, 2009, 10:45 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
John,
Yes, still got those links
I was thinking for sub-5A loads it's cheaper/simpler/more-compact to go with something like a 10~50mR 1206 or 2512 size resistor shunt, since it can be placed on the board very compactly.
Paul.
Old May 15, 2009, 11:26 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Paul, you know I'm persistent!
What's the point of a <5A in-flight current sensor? What I'm suggesting is a low cost simple equivalent of the Seagull telemetry system for us ordinary folks. Bet there's a real market for something that tells you exactly how much capacity you have left in the battery at any time during a flight. If you are doing the altimeter and RF link in any case, why not look at a useful, real-life current draw, additional function that adds virtually no weight and maybe $2:00 cost?
Do have a look at the Raztec specs. They are rugged as a rock, only 1g in weight, a 3.5mm bullet passes right through (or even thicker wire without a connector), and they mount direct to the board with three pins. How much simpler can it get? NO power loss and NO current limitation. I'd make one myself in a shot if I had your uC skills and knowledge but I don't so the best I can do is persuade someone cleverer to do it instead.
I'll send you my sample if you want to have a play with it.
John
John,
Paul.
Old May 15, 2009, 11:38 PM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
John... persistent? really?
Well, really there's two things to chase here --- I really just want a simple altitude device first up, not sure I want to try chasedown/design a full spec system that'll do everything... yet. . . . then I must get that 4-wire/PIRCAT system sorted out.
The universal IRM is proving to be a bit of a pain but I've got it mostly licked (cough). The method I'll use is to probably supply-isolate the voltage drop sensing system from the processing side and opto-link them for the data-transfer. It makes things a little bit bizzare in that I'll have added circuitry just to do the DC-DC isolation (though it'll probably be cheaper these days to simply buy one of those very handy 5V-5V blocks, they're about $10 and provide 1kV separation). The best thing then is that if something 'strange' happens on the cell input it won't destroy things.
Paul.
Old May 19, 2009, 02:02 AM
jayhwoolley is offline
Find More Posts by jayhwoolley
getting thorney
jayhwoolley's Avatar
Roxburgh Park
Joined May 2008
i need a simple light weight switch that i can fire an onboard booster rocket with, i need it to plug into a spare channel on my reciever and put out 9v from a remote battery (square ones) as to not interupt with the standard internals.
for now the tests will be carried out on a cheep 2ch glider thats 330g with a c6-0 estes rocket which i dont think will be stupidly fast...i hope
will be stepping it up to an x-1 slope glider thats got "ignition" like its true form
hope you can help or sugest something thats already been used
jayhwoolley is offline Find More Posts by jayhwoolley
Old May 19, 2009, 02:22 AM
PLD is online now
PLD
PLD
Magicsmoke maker
PLD's Avatar
Joined Dec 2003
Jay,
Yep, I've got something pretty similar to what you're after. The existing PLD-RCS-1A ( http://nqrc.com/?vp=PLD-RCS-1A ) would have to just be wired slightly differently to allow you to use the 9V battery.
Paul.
Rewards for good ideas here.... zagisrule! Aerial Photography 65 Apr 14, 2004 08:52 AM
AVRO Arrow EDF design -- kicking around some ideas byrocat Electric Ducted Fan Jet Talk 16 Jun 10, 2002 11:20 AM
Cool Where Do Babies Come From? Don Sims Humor 0 May 20, 2002 12:33 PM
KALT CYCLONE/Irvine61 multi needle,anyone got the a books or good ideas/tips please donlynn Fuel Heli Talk 0 Apr 14, 2002 08:14 AM
