Australia, NSW, Bungendore
Joined Jan 2005
Peter Rake's Powell PH-2 Racer
If lack of documentation found on the 'net is an indication of a 'rare bird', then the Powell PH-2 is certainly an obscure prototype. But then that's Peter's preference
The Powell series of small racing planes started in the 1920s with an all-wood version designed by Prof. Powell - an aeronautics instructor at Detroit Universtity. This was followed by the PH-2 - the subject of Peter's model. At least one later model was designed but looks much more contemporary. I've found photos of the first all-wood version, one picture of a later machine and NONE of the PH-2! If anyone has further info, I'd love to hear. Peter's introduction to the design is at: http://www.rcgroups.com/forums/showt...1030599&page=3 On a personal note - to reduce stress, anxiety (and blood pressure ), I was not going to enter any competitions, build prototypes etc this year. I've failed miserably - I dont like deadlines or pressure but Pete has said he's not in a hurry and so this build may be fast or slow - we'll see Pat |
Latest blog entry: A Big Move.....
Joined Jan 2005
A Small Start..
While I am waiting for Charlie/Vicki at Manzano to produce some parts for this model, I figured I'd get some of the hardware sorted.
The centre section struts and landing gear are simple wire shapes, bent up, soldered together, and fastened to the model. These bits were bent from 1.6 and 2mm wire (16 and 14 swg) using a pair of pliers and a thumb. I'll make some simple jigs to hold them together when soldering. Pat |
Joined Jan 2005
Wire-Work Assembly
The various UC and CS parts were held together in the vice or clamped to a wooden jig while being brazed. I chose to silver-braze because I have the facility but the normal binding with thin copper wire and soft soldering is OK too. The brazing rod used is known as 'Easy-Flo'.
Apart from the greater strength of the brazed joint, I like that the wire is a little easier to clad with wood without the bulky binding. Just a personal choice. As soon as the joint is made, the work should be plunged into a water bath to help preserve the temper of the spring wire. After joining, the parts were scrubbed in warm soapy water with a wire brush to remove all traces of flux - same should be done for a soldered joint. Pat |
Joined Jan 2005
Making some 'P' clips...
Thanks Trey - because this should be a fairly simple build, I thought I'd spend a little more time explaining how basic things are done. Over the last few months, I've seen quite a few basic questions about how to do stuff and while I always say "....read a few build threads completely..." - not all the little processes are explained. So back to 'P' clips
I've used these to hold together many of my Rake and own-design models for a few years and love them. Being able to disassemble a model while planking, finishing (or repairing is great). They are called P clips because the end shape is like the letter 'P' These were made from a 1cm wide strip cut from a produce can (empty). Cheap and easy to work. The strip is wrapped around a piece of wire the same diameter (or a size smaller) and squeezed with pliers or in a vice. After being cut to length, a clearance hole is drilled for the securing screw. Remove the burrs and it's done. Note that the clips are left on the wire when drilling the holes. This keeps fingers away from the job in case the drill bit snags the clip. I dont like bleeding In Peter's design for the Powell, he has specified saddle clamps to secure the centre struts to the top wing. These P clips serve the same purpose. I will also use them to fasten the UC legs to fuselage instead of binding and gluing. For me, it make assembly and finishing a little easier. Pat |
Joined Jan 2005
Apropos of Nothing.......
While I was cleaning up my garage (also the hangar) I had a clump of my flyable models waiting to be stored on the shelf so they were paraded for a photo
Three Peter Rakes, two Maltones and a couple of ARFs. All fully equipped and have flown recently (and survived the experience)!The missing spinners/cowls is testament to a rough field, rougher piloting and nose-overs Pat (back to the housekeeping....) |
Joined Feb 2004
Nice 'squadron' pic, Pat. Here's one I took a while ago of part of my fleet at the time - only I don't have the luxury of a garage floor!
I've recently sold all my Rake planes - BE2c, Eastbourne, DH6, SE5a, EIII and Morane L - to an old club mate who is getting into WW1 electric flight. He only wanted the DH6 but then he made me a rather nice offer on the lot . Broke my heart to part with any of them but I simply need the space; the Eastbourne at 48" was really too big for my small field anyway.Hot on the heels of this, I also sold the 'Emma' to another mate who was a Flambards fan. I liked this model but it flew quite fast which for me, spoiled the 'olde worlde' illusion. (The actual one used in Flambards was the same so Boddo slowed the film down to half-speed). I intend to build nothing bigger than 30" in the future when I resume modelling - and to exercise restraint (I hope) ![]() Steve |
You could always pick up a 1932 "Flying and Glider Manual," though it's hard to say what's revealed about the Powell Racer... http://www.aircraftspruce.com/catalo...dermanuals.php By the way, please keep the great building tips and companion photos coming. It's always helpful to see how others solve problems, even the routine stuff that we might take for granted. I was speaking with one of the modeling legends at our field last weekend about the "good old days" when you had to figure everything out on your own, with maybe a little help from the occasional magazine article or flying buddy. I came away from that conversation doubly grateful for this forum, and the fact that we can share information from all corners of the earth only sweetens the deal. |
Joined Jan 2005
Yippee! Powell Bits....
I suppose I should grow up one day, but I always get a bit of a thrill when a nice box arrives from the Postmans van all the way from Manzano
I hear of others having problems with international post but this box arrived in Australia about 6 days after being posted in Arizona and was not intercepted or interfered with in any way by customs etc.Twelve sheets of balsa, ply and liteply. All balsa seems to be of good, even quality. No noticably heavy or hard grade wood. Thanks Vicki (and Charlie) I cant wait to get gluing Note the 12" (30cm) ruler across the liteply sheet - for a 37" model, that is a large fuselage former - nearly 6" X 4.5" ! I guess I'd better clean the workshop up a little.... Pat (I love building) |
| Thread Tools | |
| Any interest in a Laser Cut short kit of Peter Rake's White Monoplane? | Twmaster | Scale Electric Planes | 11 | Mar 05, 2010 04:59 AM |
| Peter Rake's 1913 Rapid | dottney | Scale Electric Planes | 25 | Sep 18, 2003 07:20 AM |
| Peter Rake's Sperry Monoplane | JRuggiero | Scale Electric Planes | 9 | Oct 19, 2002 12:40 PM |
| Peter Rake's Tiger Moth | YEAP CHIN POH | Scale Electric Planes | 5 | Sep 14, 2002 03:10 AM |
| Peter Rake's Fokker D-VIII | Jim Drissell | Scale Electric Planes | 12 | Aug 02, 2002 01:10 PM |
