Old Mar 31, 2003, 06:43 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Need A10 Build Help - What's with this small battery bay?
I am just in the beginning phases of my A10 Building project. I am right now looking at this strange (small) battery bay. I'm scratching my head because I have not found any of my packs that will fit in this. Are most of you guys opening this bay up to actually fit a decent battery pack, this bay seems not long enough. What packs are you using in your A10? I swear, I have a rather large assortment of battery packs but I have yet to find one that will fit. I was thinking of moving the pack way forward to get the proper CG but the Nose gear seems to be in the way, what have you done & how far forward should I move the pack??
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Mar 31, 2003, 06:46 PM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
5/4 AAA 800 8 cell nimhs fit and fly it
thats what i use in mine
Mr Lin,or someone in his name, when over at RC Zone said the small bay was intentional; to keep people from putting in larger batteries and burning up the motors faster
Chuck
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Old Mar 31, 2003, 06:59 PM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
Mine flys on either a 7 cell AAA 720 mah nimh pack or a 2S2P LIPOLY pack in the cockpit. It will also fit a 6 cell 600 mah AA pack altough your flight times will be short. I scraped the battery door and just lined the outside with Velcro. I then use two velcro straps across the battery opening to hold the AAA in. This will leave your options very open.
Mike Parsons is offline Find More Posts by Mike Parsons
Old Mar 31, 2003, 07:07 PM
mrebman is offline
Joined Nov 2000
I was hopeing to use my 2S2P Qualcomm 830 Parallel pack in this plane, I'm thinking it would be ideal. However, the Lion pack is too long BUT, If I make up (2) seperate 2-cell packs & use a Y-Connector I may be able to stick them in Heighth wise & may just be able to even get the battery door closed, Maybe! Has anybody experimented with the 2S2P Qualcomm 830 setup? How would this combo work with the EDF50's?
-Mike-
Old Mar 31, 2003, 10:32 PM
mrebman is offline
Joined Nov 2000
Chuck:
Are you using a Side-X-Side Pack or a brick pack? How long is your pack & where did you get it?
-Thanks-
P.S. - Isn't the 8-Cell 9.6V pack too many volts for these little EDF-50 motors?
Old Apr 01, 2003, 04:24 AM
Joined Jun 2002
hi Mike,
side by side packs
www.allerc.com (19.99 perpack)
yes they recommend 8.4 volt nimh 7.2 volt nicad
but then...everyone knows i'm crazy anyway, but the way it flies on 8 cells leaves me wondering what 7 cells will do
it is a very slow flyer even on 8 cells, i have aquired a 7 cell GWS pack that i will try this weekend.
Chuck
Old Apr 01, 2003, 04:31 AM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
I had to dremel out the aft part of my batt compartment so I could slide my pack back to balance it. I'm using a standard GWS 6 cell - 7.2 V 600mah pack and it flies great at 16.5 oz!!!!
skyhawk is offline Find More Posts by skyhawk
Old Apr 01, 2003, 07:41 AM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
Chuck
Chuck,
You will not see a noticable thrust decrease from 8 cells to 7. 7 cells is already pushing these EDF's to their limit. You will see an RPM increase with 8 cells, but not enough Thrust difference to justify using them. Plus it adds the weight of another cell and not enough thrust to make up for it.
Old Apr 01, 2003, 08:16 AM
rtucker is offline
Find More Posts by rtucker
Columbus, Indiana
Joined Dec 2001
Anyone tried a side-by-side 6 cell Kan 950 pack yet?
I made a pack up to experiment with, if I ever get my A-10. I have no intention of using the supplied battery cover so the size should not be a problem. I'm just concerned about weight, power to get it off the ground, and motor life....
Rick
rtucker is offline Find More Posts by rtucker
Old Apr 01, 2003, 08:37 AM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
Rick,
6 cells will get it off the ground, but 7 cells would be better IMO. Kan's will be fine as some are using HEcells that carry the same weight I believe. You may need to hog out (pun intended) the battery compartment a little to fit the Kan's, but they will work. Just leave off the battery door and use velcro to give yourself more options.
Old Apr 01, 2003, 09:44 AM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
I used a 7 cell HE1100 pack (2/3A) like this ===I use a dremal with a sanding drum attachment to open up the back side of the compartment, then lined the floor with velcro. Had to move the pack about 1/2 back to get it to balance right, otherwise it would have been nose heavy
dave morris is offline Find More Posts by dave morris
Old Apr 01, 2003, 09:54 AM
rtucker is offline
Columbus, Indiana
Joined Dec 2001
I wonder if the increase in thrust (7th cell) is worth the added 3/4oz. of weight? I can't wait to get my bird so I can start playing with this stuff!!! If it is the typical (post Beaver) battery bay, should be able to make most pack sizes fit.
Thanks Guys,
Rick
Old Apr 01, 2003, 11:48 AM
Joined Jun 2002
Originally posted by foamflyer
Chuck,
Thanks for Input FF
will try it., anyhow it does fly
Chuck
Old Apr 01, 2003, 12:50 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
Rick
Rick,
In this case, the 7 cell does increase the thrust over the 6 cell as long as we are talking about NIMH's. If speaking of NICD's stay with a 6 cell.
Chuck,
Anytime
Old Apr 05, 2003, 03:36 PM
mrebman is offline
Joined Nov 2000
How would (2) 2-cell Qualcomm 830 Lion Packs hooked up in Parallel with a Y-Connector works with the A10? I would align the 4-cell in this fashion (IIII) Straight up & down in the battery bay, should just fit. Anybody tried these Lions? I using this exact setup in my Mustang & seems fine, I assume it will also work in the A10, Do I assume correctly?
I would apprciate any input-Thanks
Discussion What's with this C stuff? Laggard Batteries and Chargers 6 Feb 27, 2007 12:31 PM
What's with this bungee stuff? wRCcarter Hand Launch 25 Aug 13, 2006 12:27 AM
GWS Corsair Build Question - What's with these ailerons? mrebman Parkflyers 8 Sep 08, 2003 12:17 PM
Help! What's wrong with Ni-Mh battery Jim Lin Parkflyers 2 May 16, 2002 09:12 PM
