Old Jun 17, 2001, 07:13 PM
asperkins is offline
Find More Posts by asperkins
asperkins's Avatar
Arlington, TX, USA
Joined Jun 2001
71" Piper Cub first flight
My Airborne Models 71" Piper Cub flew for the first time. I have had marginal luck with cubs so I intentionally overpowered this one for insurance.
The model is excellent. Very well built and LIGHT! After adding an Aveox 1015/2Y with 4:1 gearbox and 16 Panasonic 3000 Nimh batteries it was still below 20oz wing loading. The batteries weighed 2lbs. All up weight was 6 pounds. It had 4.5 pounds static thrust and pulled 28 amps on a fresh battery.
I took it to the field, topped off the battery, and had a friend take the controls. In true cub fashion it was a handful on the ground. But once up to speed he pulled back on the elevator and up she went. It climbed at a 45 degree angle!!! Not very cub like I know. The 13x8 prop sounded great.
This model flew wonderfully. Stalls were gentle and predictable. After 10 minutes of flight we had a problem with the motor so we had to land. My calculations show that the model should fly about 15 minutes on a charge. I will verify this when I get the motor back.
I would highly recommend this model to anyone wanting a larger cub. Best of all, it is an ARF!
Check it out here http://www.airborne-models.com/html/piper.html
It is the Cub 48.
Can't wait to get my 57" Mustang in the air now!
[This message has been edited by asperkins (edited 06-17-2001).]
asperkins is offline Find More Posts by asperkins
Old Jun 25, 2001, 01:01 PM
asperkins's Avatar
Arlington, TX, USA
Joined Jun 2001
I cut away some of the forward former so that I can place the battery nearly against the firewall.
You may be able to make an access door on the bottom. near to front of the plane.
Old Jun 26, 2001, 12:58 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Sounds great, I just pick one up and plan to power it with either Astro 15G or Aveox 1010/2Y with 4.4:1 or 1406/4Y (?)on 12-14 cells. I will have it with floats.
When do you put the battery? I hope to find a place so I don't have to remove the wing and struts everytime.
Brian
bhchan is offline Find More Posts by bhchan
Help! Kyosho Piper J-3 Cub, a.k.a. ParkZone J-3 Cub, FIRST FLIGHT phase_boy Parkflyers 6 Dec 29, 2008 02:38 AM
Pico Cub first flight... indyflyer Parkflyers 11 Aug 03, 2002 09:15 PM
Sure Flite J3 Cub First Flight Report HavingFun2002 Foamies (Kits) 4 Jul 19, 2002 07:57 PM
GWS Cub - First Flight jerrysimon Parkflyers 23 Jan 01, 2002 10:27 AM
HL Super Cub first flight report! Paul Scale Kit/Scratch Built 8 May 14, 2001 11:10 PM
