Venom GPV-1 Hints and Info.
After the main hints and tips thread grew too confusing and complicated I've collated the main points here to make then easy to read.
Just for info, the old thread is still there if you want to plough through several dozen pages of communication.... http://www.rcgroups.com/forums/showthread.php?t=957024 Right lets get straight into the main points to fix on the GPV-1 RTR from the box. The servo horn should be 90 degrees to the link rod at straight ahead, if it's not just re-centre it, use a 1.5mm hex wrench to slacken the two collets, unscrew the servo horn with a little philips and pull the servo horn right off the splines, turn on the radio tx & rx and leave it at neutral, check any trims etc are all at centre too, reposition the servo horn on it's splines to it's 90 degrees to the link rod and re-tighten the centre screw. Reposition your spring collets so they are just touching the spring and pushing it lightly aginst the centre slider and re-tighten the grub screws. Job done. Two minutes with a hex wrench and you'll be sorted. Steering as recieved. Offset to one side with wheel dead ahead. ![]() As Reset to 90 degrees at straight ahead.
Practise Practise Practise
Get on a car park and figure out what the bike needs to make a clean corner, get that nailed and then get on track, when you get it nailed it's a great thrill, but heading straight for the track can prove frustrating.
Here's three vids of GPV-1 action, so you can see how it really works. GPV-1 lapping of Bedworth viewed from drivers rostrum.
GPV-1 wheelies, and action shot down low.
GPV-1 on board mid race action.
| Thread Tools | |
| Mini-HowTo Venom GPV-1 Hints and tips | Dez82 | Motorcycles | 359 | Apr 21, 2009 01:52 AM |
| Alert Please Sticky !! Mini How To Venom Gpv-1 Hints And Tips Thread | rcphreak | Motorcycles | 4 | Apr 16, 2009 04:22 PM |
| For Sale Venom GPV-1 Bike for sale NIB | fgbasher | Cars - Motorcycles (FS/W) | 5 | Jan 13, 2009 11:55 AM |
| Sold venom gpv-1 | gmrvegas | Cars - Motorcycles (FS/W) | 1 | Dec 27, 2008 08:13 PM |
| Discussion Venom GPV-1 | Spitfire-01 | Motorcycles | 9 | Oct 08, 2008 05:20 AM |
