Old Apr 23, 2009, 05:42 PM
dan duesentrieb is offline
Find More Posts by dan duesentrieb
dan duesentrieb's Avatar
germany
Joined May 2004
Now everything makes sense, now I know, why I HAD to buy that modified fourstroke head...I hoped this bike would be available some day!
This bike is definetly a milestone in the history of RC bikes!
Hugo
www.rc-bike.com
dan duesentrieb is offline Find More Posts by dan duesentrieb
Old Apr 23, 2009, 06:09 PM
W.C.mach is offline
Find More Posts by W.C.mach
Flat out
W.C.mach's Avatar
Plymouth, MA
Joined Mar 2002
Originally Posted by Nolan Farmer
Wow, thanks John. I have to admit I'm a bit overwelmed with how well things have turned out. I didn't even plan on doing a body but the others are too large for the machine.
The 7075 will spring back and would take a lot to break I am thinking. I plan on having the frame heat treated to have it be this way as well.
The axle is a TT unit.
Nolan
Good call, The 7075 has the same strength as 1018 steel. Most manufacturers would not spend the extra $$$ on it. I commend you. Be careful the anodizer does not burn them. Warren
W.C.mach is offline Find More Posts by W.C.mach
Old Apr 27, 2009, 12:20 PM
Nolan Farmer is offline
Find More Posts by Nolan Farmer
Nolan Farmer's Avatar
United States, CO, Jamestown
Joined Jun 2006
I have a large piece of 1.3" billet left over from a job to use. If you look closely at Lido's purple chassis, the 7075 parts are darker. My Anodizer is 15 minutes away and has done a great job for years.
I have updated the website with the two side renderings having more detail and being suitable for wallpaper. http://farmerplastics.com/
Nolan
Nolan Farmer is offline Find More Posts by Nolan Farmer
Old Apr 28, 2009, 01:47 PM
Lazman is offline
Find More Posts by Lazman
United States, VA, Mechanicsville
Joined Oct 2006
What's your timeline Nolan... still very interested. Glad I already have a head.
Laz
Lazman is offline Find More Posts by Lazman
Old Apr 28, 2009, 02:21 PM
Joined Jun 2006
Laz
I'm thinking 6-9 months if I stick with it. I know really fast ways to make the Nylon parts and even the fuel tanks are not too hard to do. But it's still a load of work and materials. It will be a stretch to pull it off. I've decided to do 24 or it will not be worth doing.
I'm getting ready to saw some BILLET!
Nols
Old Apr 28, 2009, 08:23 PM
Lazman is offline
Joined Oct 2006
Well if you need another tester keep me in mind.
Laz
Old Apr 28, 2009, 08:36 PM
dmincin is offline
Find More Posts by dmincin
dammachines
United States, WV, Harpers Ferry
Joined Feb 2004
Nice! Even the soft jaws are works of art!
Dave
dmincin is offline Find More Posts by dmincin
Old Apr 28, 2009, 11:00 PM
lectroglide is offline
Find More Posts by lectroglide
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
dont know what looks better, the website or the bike itself
lectroglide is offline Find More Posts by lectroglide
Old May 02, 2009, 10:02 AM
4strokenut is offline
Find More Posts by 4strokenut
Joined Apr 2009
Will you be posting price and availability on your web page or in forum or both, this bike is amazing piece of work thanks for being so dedicated to this and keeping us updated . WANT ONE BAD !!!
4strokenut is offline Find More Posts by 4strokenut
Old May 03, 2009, 05:39 AM
Lazman is offline
Joined Oct 2006
Hey Nolan, I can't tell is it still a 2 speed? Or in your new design did you swap it out to be a one speed?
Laz
Old May 03, 2009, 08:31 AM
Joined Jun 2006
I've told a few that it would be between 750-1000 USD. I want to go through the process of machining again before I set it all in stone.
It will also depend on what I can afford to add to the kit. Things like wheels, forks, ele. starter. And most likely you will need to supply your own motor and carb.
N
Old May 03, 2009, 10:03 AM
Joined Jun 2006
Laz
The SS Swing arm is one speed only. This freed up the design to have less moving parts in the drive train, made the assembly stronger, easy to change gearing, and moved the center of gravity to the middle. It also moved the pipe out of harms way and will not hose the rear brake with oil.
I could see having a long swingarm drag bike option with the two speed. It just doesn't work well without engine braking if you need to turn. The bike will quickly go from walking speed to almost 50mph with one gear, just fine for roadracing.
N
Old May 03, 2009, 10:07 AM
Lazman is offline
Joined Oct 2006
Sweet, Thanks
Laz
Old May 04, 2009, 11:24 AM
Joined Jun 2006
Twenty seven bottles of beer on the wall.................
Old May 04, 2009, 12:03 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
What machines are you using to cut those?
village_idiot is offline Find More Posts by village_idiot
Question Nolan Farmer FPM r30fs NEW BIKE some info. malcabro racer Motorcycles 2 Oct 13, 2008 12:44 PM
