Old Apr 20, 2009, 06:13 PM
Raydee is online now
Find More Posts by Raydee
RC Addict
Raydee's Avatar
United States, NY, Niagara Falls
Joined Jun 2002
ESC Motor and Batt wire length
Does anyone see a problem with shortening both the motor and Batt wires on a Castle ESC?
Raydee is online now Find More Posts by Raydee
Old Apr 20, 2009, 06:16 PM
foamnpacktape is offline
Find More Posts by foamnpacktape
Build it, don't buy it
foamnpacktape's Avatar
Calgary, AB, Canada
Joined Apr 2008
I don't.
foam.
foamnpacktape is offline Find More Posts by foamnpacktape
Old Apr 20, 2009, 06:27 PM
RC Addict
Raydee's Avatar
Joined Jun 2002
I didn't think there was a problem BUT I have heard that you don't want to shorten the wires on a Brushless motor if they are already soldered. I have no idea if this applies to all brushless motors or not though.
Old Apr 20, 2009, 06:44 PM
Calgary, AB, Canada
Joined Apr 2008
Never heard of that. I used to have a couple of brushed ESC's with a disc shaped PCB that you soldered directly to the motor, no wire at all.
I have always used the rule of thumb: the less wire the better, and have never had issues. I wouldn't worry about it myself, but if your concerned it never hurts to wait for brighter minds to chime in.
foam.
Old Apr 20, 2009, 06:55 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Some brushless motors have the lead out wires as part of the windings... for whatever reason, apparently those are the ones you must not shorten.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 21, 2009, 10:20 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Nearly all cheap motors bring windings out as leads. It's not that you shouldn't shorten them but rather you must remember to remove the enamel before soldering.
rich smith is offline Find More Posts by rich smith
Old Apr 21, 2009, 10:43 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No, there is no problem shortening the wires on the ESC.
Though as some people have helpfully explained, if in the future you are ever thinking about shortening the wires on the motor instead you may need to be a little careful .
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 21, 2009, 12:15 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
And removing that enamel can be a royal PITA, especially if the manufacturer has used lots of very tiny gauge wire in the windings (wound in parallel). And that is the reason to look before you snip!
Alan Hahn is offline Find More Posts by Alan Hahn
Old Apr 21, 2009, 12:17 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
From Himaxx: this does not explain why shortening motor wires may cause motor failure... but there must be a reason other than voiding the warranty.
Do not shorten the motor wires. Shortening or cutting the motor wires voids the warranty and may cause motor failure. If the supplied connectors are not to be used, remove them by desoldering. DO NOT CUT THE CONNECTORS OFF!
Old Apr 21, 2009, 12:56 PM
rich smith's Avatar
Joined Dec 2006
It sounds like they are warning for exactly the reason I stated, noobs who don't know about magnet wire enamel. Desoldering instead of cutting would eliminate this pitfall.
I never pay attention to mfg warnings anyway. Why last week I brazenly removed a tag from my futon mattress... knowingly, willingly, and under penalty of law. Tore it right off! I am a wild mustang.
Old Apr 21, 2009, 02:28 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Shorter motor wires do not hurt the motor in any way IF shortening is done correctly of course. How to do it correctly has already been explained by the other posters here.
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Discussion ESC's and Feed wire length Nexus21214 Coaxial Helicopters 0 Apr 15, 2008 10:29 AM
Discussion Max motor-ESC wire length? cloud-9 Power Systems 10 Mar 23, 2008 10:39 PM
Discussion Wire length from ESC to Motor rainedave Power Systems 1 Feb 16, 2007 10:20 PM
Discussion ESC-Motor Wire Length?? Pilebuck Electric Sailplanes 4 May 07, 2006 12:46 PM
GP Electricub 41" ARF Review!! $79.99 w/esc, motor and batt! gotime242 Parkflyers 3 Nov 18, 2005 11:49 AM
