Old Apr 19, 2009, 10:12 PM
cjbucher is offline
Find More Posts by cjbucher
cjbucher's Avatar
Raleigh, NC
Joined Sep 2004
Video
Stryker Take 2
Amazing what a difference a prop can make. Here's the same plane from this video http://www.rcgroups.com/forums/showthread.php?t=1021479 with a 4.5x4.1 APC E prop instead of the 5x3 APC prop.
The rest is the same:
Motor: Ammo 24-33-3500 kv
Battery: Rhino 1750 3S 25C
ESC: Apollo 25 amp
I've managed to up the speed by 10 mph (doppered a couple passes around 83 mph! +/- a couple mph) and also improved the climb rate! But that's kind of unusual because the 4.5x4.1 measures a lower static thrust. Either the faster speed is allowing for better climb or when this prop is in flight it has better thrust.
Oh, and it only added 1 more amp of draw over the 5x3. (27 amps static test vs 26 amps with the 5x3) Overall not bad performance for a Stryker in the "less than 300 watt" category.
Here's the video:
cjbucher is offline Find More Posts by cjbucher
Old Apr 19, 2009, 10:23 PM
annihil8ted is offline
Find More Posts by annihil8ted
San Diego
Joined May 2008
MOAR SPEED!!!
Haha, today, i managed to get my phantom, styker's ducted fun brother to sound like a turbine by taking the cover off and dive bombing. Hopefully ill be able to get a speed reading soon but it look like in the 80+ range.
annihil8ted is offline Find More Posts by annihil8ted
What happens when you take 2 EDF units and.... Tres Wright Parkflyers 4 Aug 18, 2009 01:10 PM
model choice help take 2 cheech27 The Builders Workshop 1 Apr 21, 2004 07:32 AM
wood working advice take 2 cruzomatic Life, The Universe, and Politics 3 Apr 09, 2003 04:59 AM
Hurricane, take 2 Martin Hunter Scale Kit/Scratch Built 51 Jan 27, 2003 09:54 AM
OOPS! take 2, Questions form a newbie Rxb Beginner Training Area (Aircraft-Electric) 3 Oct 09, 2002 09:37 AM
