Apr 19, 2009, 06:56 PM
Alberta
Joined Aug 2004
50cc CRRC PRO GAS ENGINE
50cc CRRC PRO GAS ENGINEUsed one season 50cc CRRC PRO GAS ENGINE
SELLING ---250.00
Or TRADE FOR 26CC GAS
FEATURES:
2 pcs. aluminum crankcase, 3 ball bearings supported crankshaft, 2 needle bearings conecting rod, walbro butterfly type carburetor.
Auto-advance CDI ignitION
SPECIFICATIONS:
Type: 2 cycle piston valves type gasoline engine for airplane.
Displacement(cc): 50cc
Bore x Stroke(mm): 43mm*34mm
Dry Weight: 1.69kg/3.7lbs. (With muffler and CDI)
Carburetor: Diaphragm butterfly valve type
Maximum Output: 4.85ps/7200rpm
Speed range: 1500-7600rpm
Ignition: Auto-advaance DC-CDI
Iis-Ignition: 4.8V DC
Gasoline/oil mixture: Pre-mixed Fuel, 40:1(25:1 for break in)
Lubrication oil: 2 cycle engine oil
Propeller: 20x10,22x10,22x8,23x8
