Old Apr 19, 2009, 06:35 PM
Rogo is offline
Find More Posts by Rogo
High Planes Drifter
Rogo's Avatar
Joined Oct 2006
Question
Convex hinge lines and hinge bending resistance
Folks -
I've constructed some balsa SGII tailfeathers with kevlar fabric hinges (under 0.75 oz bagged glass) on one side. Both the stab and rudder have some convexity to them along the long axis (tapered towards the tips). I have cut out the triangular hinge gap no problem, but note that there is some bending resistance as the movable surface reaches maximum travel (in both directions), due to the convexity of the hinge line. The resistance is not huge, but I'm wondering if it will make servos work harder than they have to.
Any fixes, or is this something I shouldn't worry about?
- Rogo
Rogo is offline Find More Posts by Rogo
Old Apr 19, 2009, 06:40 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
If you bag the parts out of the beds, and lay the hinged side flat on the work bench, it fixes the problem. It seems a little late now, but maybe cutting a few slits through the hinges at the apex of the bent part will help.....
Target
target is offline Find More Posts by target
Old Apr 19, 2009, 08:03 PM
pyrsly is offline
Find More Posts by pyrsly
pyrsly's Avatar
Poland, Śląskie, częstochowski
Joined May 2008
Originally Posted by Rogo
Folks -
- Rogo
Soften hinge little more that should reduce problem
pyrsly is offline Find More Posts by pyrsly
Old Apr 19, 2009, 09:05 PM
soarluck is offline
Find More Posts by soarluck
soarluck's Avatar
Canada .the great
take a triangular file and drag it down the hinge line along the top and bottom of the fin where it makes a bend ,,file until you see fuzz from the kelvar BUT no more than that ..
soarluck is offline Find More Posts by soarluck
Discussion Covering hinge lines. dwreel Fuel Plane Talk 1 Dec 25, 2006 05:18 PM
