Old Apr 18, 2009, 09:11 PM
bad400 is offline
Find More Posts by bad400
crashs come easy patience dont
bad400's Avatar
USA, MI, Shelby Township
Joined Jan 2009
FAQ
DYNAM gy48v
ok just got the dynam gy48v today.
on first inspection, it seems very well made.
i have only 2 batteries threw it, but it seems to hold the tail very good.
i have only noticed it slows the servo down, am now trying to figure out why my pitch slider is slower.
i have all my limits correct, so not sure why my tail is slower now.
but i can say for someone just getting in to 450 class helis and looking for a cheap gyro, this is a very solid gyro. holds the tail real solid and if i can figure out how to speed the tail up i will report this info.
i purchased the gyro from helidirect for 36.99 plus shipping
bad400 is offline Find More Posts by bad400
Old Apr 18, 2009, 09:38 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Increasing you rudder endpoints increases your piro rate.
Gino CP is offline Find More Posts by Gino CP
Old Apr 18, 2009, 09:48 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
well its more like the slider moves slow.
but i believe i have that fixed now, i turned the delay the wrong way.
im useing the futaba 9650 so i had it in (ds) but had the delay wrong.
still seams a little slower than the futaba gy401 i ran today as well.
but i can honestly say it held just as good as the gy401 and we had some good gust`s of wind today.
i cant say its BETTER than the gy401, but CAN say it held the same. even in throttle pumps the tail didnt move as much as the gy401 did.
so far with today being the only time ive used it, it did rather well.
im very pleased with it and the price being what it is was a good selling point.
i know its hard to try new products, especially in todays market and economy.
but like the g401b someone had to start the test, so i decided on the gy48v it would be me.
i sofar like its abilities and after changeing the delay, i have a tail that moves and holds as it should.
Old Apr 19, 2009, 06:42 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
just a report of todays testing.
i have developed a right drift i can not seem to get ried of. my mechanical setup is basicly perfect.
i have new bearings comeing tomorrow to replace all the year old bearings.
i have a vibration, but its very small. it could be just enough to confuse the gyro, but seriously doubt it. the vib`s are not that bad.
the gyro held good yesturday, but i may have gotton a bum gyro.
i will replace the bearings tomorrow and report on my progress.
Old Apr 19, 2009, 07:24 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Sometimes people get hung up on drift. I am not saying that you are one of them. Nor am I saying drift is normal. They are not on quality gyros but predominant in cheaper ones.
There are drifts that you can ride out in normal flight. Fly your heli like you normally do. If it feels natural, you are good. On my flights, the tail hardly stays put. Not because of drift but because of the way I fly.
Old Apr 19, 2009, 07:31 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
truely im trying to get the tail solid on hovers and throttle pumps.
saturday the tail was very good, but today it just wants to drift. or more like turn right.
i have started over on the mechanical and ended with the same tail in rate i had yesturday. but the heli drifts right.
it seems the more i try to fix it the worse it gets.
Old Apr 20, 2009, 04:34 AM
muda is offline
Find More Posts by muda
muda's Avatar
Lt
Joined Mar 2006
The more you look at it - the more you notice it.
muda is offline Find More Posts by muda
Old Apr 20, 2009, 01:54 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
i wish that was all it was.
after the mail run`s and a few batteries, i`ll report back on the drift.
its not just a slight right drift, its more like im giveing it right rudder.
Old Apr 20, 2009, 09:11 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
well after some bearing replacements and few batteries, its gotton better.
i will try to boom mount the 9650 so i`ll have some more precise tunning.
i believe if i can get alittle more precise adjustment on the pushrod, this gyro will be a very good cheap alternitive.
so far under flight it holds well, its the hover im trying to diel in.
Old Apr 21, 2009, 12:35 AM
cfrank2005 is offline
Find More Posts by cfrank2005
Melbourne, Australia
Joined Aug 2007
hi..interesting gyro. I gave the mks293 a go, and that was a mistake. Drifts left, right and centre. This gyro sounds very promising. Have you tried setting the tail up in rate mode first before flying it in HH?
cfrank2005 is offline Find More Posts by cfrank2005
Old Apr 21, 2009, 09:36 AM
bad400 is offline
bad400's Avatar
Joined Jan 2009
yes i have done the mechanical in rate.
im still getting a right turn, i say turn cause it`s more than a drift. i have just replaced all the bearings in the heli, so its smoother now.
i will do relocation of my tail servo so i can get a finier tunning on the tail.
my servo is now in the stock location on the blade 400. i will boom mount it a see if this helps. which im thinking it will cause you can make smaller adjustments.
Old Apr 21, 2009, 12:56 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
well got a couple more batteries through it.
took some video of the latest test, its doing better
IF YOU DONT LIKE HARD ROCK MUTE YOUR VOLUME INSTEAD OF COMPLAINING
E-flite Blade 400 (4 min 16 sec)
Old Apr 21, 2009, 07:53 PM
Tamej is offline
Find More Posts by Tamej
Meridian, ID.
Joined Mar 2005
Have you flown it outside yet? You saying that the tail drifts inside your house?
Tamej is offline Find More Posts by Tamej
Old Apr 21, 2009, 08:03 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
had it out last weekend, and it did pretty good, we even had some decent gusts that it held up to.
what im trying to do here is find a cheap gyro for people just getting in to the hobby and they can progress with.
the whole (in house) test thing is simply that. if it works as good as my futaba gy401(which has no drift) in and out of the house for fraction of the price then i can honestly tell someone its worth 37 bucks.
and so far its doing rather well. most of the drift issue`s were some old bearings and setup, which i beleive i have corrected.
Old Apr 21, 2009, 11:23 PM
bad400 is offline
bad400's Avatar
Joined Jan 2009
im thinking of adding another piece of tape to see if i can play with the gain.
right now i cant get over 60% without a major wag.
video in post #12
