Old Apr 18, 2009, 01:29 AM
Billy Haynes is offline
Find More Posts by Billy Haynes
AKA BillyKillaWatt
Billy Haynes's Avatar
Rockwell, NC
Joined Jan 2002
FoamEdge by Billy Haynes
This is my own Foamie Edge design. I started it around June 2004 and kept modifying it. The goal was to make it lighter without sacrificing strength/durability and to maximize it’s flying ability. The following is the latest design (and probably the last). I have made molds for the landing gear and elevator support. If you have any questions ask.
W.S. 36"
W.A. 300 sq."
Length 30"
3oz-3.75oz airframe weight depending on material used.
A.U.W. 12oz-14oz depending on material and equipment used.
The plan is 36" x 40" for ease of printing at Kinkos, ect.
Building instructions done in Mocrosoft Word saved as Document (.doc)
Billy Haynes is offline Find More Posts by Billy Haynes
Old Apr 18, 2009, 01:57 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
Make a kit of parts
1- Cut out foam parts.
Old Apr 18, 2009, 02:04 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
2- Bevel all control surface leading edges at 45°.
3- Cut 1/8” groove for leading edge spar, secondary spar, and elevator joiner spar with a 1/8” router bit.
4- If cut from two pieces of foam, glue wing panels together with any foam safe glue you prefer.
5- Glue elevator joiner spar and elevator trailing edge support with epoxy or foam safe CA.
6- Glue leading edge spar and secondary spar into the wing with epoxy or foam safe CA
Old Apr 18, 2009, 02:09 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
7- Hinge ailerons and elevator. I prefer Blenderm made by 3M.
8- Glue elevator assembly/rear horizontal fuse to trailing edge of wing.
Old Apr 18, 2009, 02:14 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
9- Glue lower vertical fuse to bottom of wing/rear horizontal fuse.
10- Glue front horizontal fuse to the wings leading edge and lower vertical fuse.
Old Apr 18, 2009, 02:35 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
11- Glue top vertical fuse to wing/horizontal fuse assembly.
12- Trim vertical stab for elevator clearance if required. (You want to have 45° of elevator travel)
13- Hinge rudder to vertical stab.
Old Apr 18, 2009, 02:52 AM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
14- Install servos. Servos go on bottom side so as to be less visible.
15- Install cont. horns in line with servo arms.
16- Install .032” control rods. For 3D flying, elevator and rudder control rod guides should be installed. Control rod guides can be made from Sig Mfg. Giant Scale Hinges.
17- If molded landing gear and skid are to be used install it now.
18- Install RX, sped control, motor and battery to achieve a CG 3” from leading edge.
Old Apr 18, 2009, 04:44 AM
genetix is offline
Find More Posts by genetix
To Build? or Build Another?
genetix's Avatar
Los Angeles, CA
Joined Feb 2009
I really like the way you made the wheels! I always get stuck with how to mount it on the frame.. but thats brilliant thanks for showing it.
It also gives me a great idea for bracing wings and making them removable too.
I have some time this weekend. I might give it a go.
Cheers.
genetix is offline Find More Posts by genetix
Old Apr 18, 2009, 06:11 PM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
The plan was drawn in ViaCAD. Plan is 36"x40".
Here’s a zipped folder of the drawing.
If you want it in another format let me know and I'll see if I can convert it into the format you need.
Old Apr 18, 2009, 06:16 PM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
If you want to make the landing gear form, here’s the plan.
I use C-clamps to press the two forms together.
I tape a piece of clear plastic wrap on the workbench with the plastic nice and smooth and lay up the glass on it. Then I put a top layer of plastic wrap on the lay up and squeegee the air bubbles out. Usually turns out pretty good.
Old Apr 18, 2009, 06:35 PM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
Here’s the elevator support form drawing.
Old Apr 18, 2009, 06:37 PM
genetix is offline
genetix's Avatar
Los Angeles, CA
Joined Feb 2009
Billy, thanks for the forms and the structure, thats great!
I don't have any program to open your files. My programming days are outdated... got anything in a pdf form or similar? Thanks!
Cheers
Old Apr 18, 2009, 06:48 PM
AKA BillyKillaWatt
Rockwell, NC
Joined Jan 2002
From ViaCAD I can export to the following:
ViaCAD, ACIS SAT, Adobe Illustrator, BMP, CGM, DWG/DXF, EPS, IGES, JPG, STEP, Text, Viewpoint Media, Wavefront OBJ.
I do not claim to be a comp. whiz. I do good to just get stuff drawn
Old Apr 18, 2009, 08:04 PM
genetix is offline
genetix's Avatar
Los Angeles, CA
Joined Feb 2009
EPS and JPG would be our best bets I think. A JPG could show us the drawings and EPS means we can resize it to any size. Thanks
Cheers
Old Apr 19, 2009, 06:16 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
.dxf is a universal vector format. You don't lose resolution when you scale. It can be imported by most decent vector-based programs, like CAD and such.
.jpg is bitmap based with a lossy compression. It's fine for pictures, but for black and white vectors, it's a bit poor to scale.
Gene Bond is offline Find More Posts by Gene Bond
