Old Sep 29, 2011, 04:18 AM
brace is offline
Find More Posts by brace
brace's Avatar
Australia, NSW, Ashby
Joined Jul 2011
Has anyone tried the FY-30A ? or the FY-20AP ?
brace is offline Find More Posts by brace
Old Sep 29, 2011, 07:11 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Originally Posted by Dillzio View Post
Oh come on Chatch, you had to go there didn't you?
lol I love my E-Sky 704 gyro
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Sep 29, 2011, 07:42 AM
Dillzio is offline
Find More Posts by Dillzio
Dillzio's Avatar
Australia, SA, Parafield
Joined Oct 2009
what bird do you use it on?
Dillzio is offline Find More Posts by Dillzio
Old Sep 29, 2011, 01:55 PM
panther3001 is offline
Find More Posts by panther3001
Joined Dec 2010
panther3001 is offline Find More Posts by panther3001
Old Sep 29, 2011, 06:06 PM
Joined Apr 2011
I use it on my hawk sky when I fpv
Old Sep 30, 2011, 11:21 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Looking forward to the FY-30A. I'm impressed with the instructions. Knowing that it's probably betaware, I might just make the plunge and try one out on something el-cheapo. It's a killer price for sure! $125 USD = 3 gyros + 3 accelerometers in a single tidy little box. Plus it's programmed specifically for planes, and not helis. Just wished they had made it as a self contained rx with Spektrum satellite, and or S-bus compatability. That would have really cut down on the amount of wires. Although an option like that would probably bump the cost up considerably.
Silverexpress is offline Find More Posts by Silverexpress
Old Oct 01, 2011, 03:38 AM
Dillzio is offline
Dillzio's Avatar
Joined Oct 2009
Originally Posted by Silverexpress View Post
Looking forward to the FY-30A. I'm impressed with the instructions. Knowing that it's probably betaware, I might just make the plunge and try one out on something. It's a killer price for sure! $125 USD = 3 gyros + 3 accelerometers in a single tidy little box. Plus it's programmed specifically for planes, and not helis. Just wished they had made it as a self contained rx with Spektrum satellite, and or S-bus compatability. That would have really cut down on the amount of wires. Although an option like that would probably bump the cost up considerably.
that's one nice looking gyro!
You see how many spare wires it has to hook up to the reciever for adjustment? I counted 4, that's 4 extra channels you need to be able to adjust all of the gyros functions in flight.
Old Oct 01, 2011, 07:44 AM
Your customer
Joined Dec 2009
The gain adjustments are done by trim pots. They also serve to reverse the direction of the servo - interesting shortcut the developers took inorder to save cost.
I would think that the individual gyros and accelerometers on the board work together via software too. Thats another advantage to a setup like this. If implemented, it can prevent weird stall conditions that individual heli gyros present on airplanes.
Old Oct 03, 2011, 07:35 AM
Dillzio is offline
Dillzio's Avatar
Joined Oct 2009
How can I expect an gyro (lets say in HH mode) on the aileron axis to handle during a loop?
If I pull up until the plane is upside down facing the opposite direction, would the gyro automatically take control of the ailerons and roll the plane the right way up again?
If so, how would this effect 'loop the loops' if the gyro started trying to roll the plane around half way through the manoeuvre?
Old Oct 03, 2011, 07:37 AM
Your customer
Joined Dec 2009
It would not right the plane, and as long as you don't move the ailerons, the plane will loop like its on rails.
Old Oct 03, 2011, 10:22 AM
Joined Apr 2011
HH is based on relative position. As you loop, your wings don't rotate. it would help you with the loop.
Old Oct 03, 2011, 09:16 PM
Dillzio is offline
Dillzio's Avatar
Joined Oct 2009
Great, thanks guys.
I've read that in heading hold mode, gyros can sometimes do nasty things that make the plane handle in unexpected ways. For example, a gyro on the rudder in heading hold mode would try to counteract any steering you did by using ailerons and elevator - Imagine your gyro locking on to the horizon as you tried to bring your plane back to you using only ailerons and elevator, you would be steering it towards you and meanwhile the gyro would be using the rudder to try and turn it away from you, what a mess that would be!
I was wondering if there are any similar pitfalls that may be experienced when using a HH gyro on ailerons? The only one I can think of is that on a stable high wing plane, the gyro would tend to counteract the plane's natural ability to right itself.
-thanks
Old Oct 03, 2011, 09:44 PM
Joined Apr 2011
if you lock the gyro in a certain roll position it will maintain that position. Use HH on rudder for crosswind landings. For a perfect crosswind landing, switch both rudder and ailerons from rate to HH on approach. This will keep the plane from rolling because of the rudder HH effects, while keeping the nose pointed in the correct direction(rudder HH).
You are overthinking the whole situation. A gyro only detects movement on one axis unless you buy a 3 or 6 axis gyro. These are single axis.
Elevator HH would keep the plane climbing at a certain angle, given you have enough thrust to keep it there. You should connect both gyro gain wires to the flaps channel through a Y-splitter if you want to be able to control two gyros and switch them between rate, off, and HH
Old Oct 03, 2011, 10:05 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
http://www.hobbyking.com/hobbyking/s...idProduct=8471
so I grabbed this gyro without even thinking, I got it tonight and installed it. It runs all the time even when i turn the gear switch off just not as much. Yeah i screwed up but is there any way I can use this?
stgdz is offline Find More Posts by stgdz
Old Oct 03, 2011, 10:29 PM
Joined Apr 2011
lol i have no idea. Kind of a waste of money... the Esky 704 is the one you want and it's cheaper than that turnigy one
Price Check on an RC Bike (Again, lol) RastaManBob Motorcycles 9 Nov 04, 2004 12:52 PM
First time on an RC airfield. Mendnwngs Fuel Plane Talk 18 Aug 03, 2004 09:57 AM
The most ridiculous use of an RC Airplane soholingo Electric Plane Talk 64 Dec 23, 2002 03:16 AM
