I don't want to be melodramatic but this
could be a huge issue if you have GA-250s.
First before I say any more you need to know that Meng at Assan has be completely upfront and honest and had done everything in his power to set things right for me -- and others...and if necessary I'm sure he will for you as well.
First Issue I detailed here last month. I can't say which color label this will effect -- and it may affect ALL of the GA-250's purchased to this time.
The effect is that while in operation, the servo will become locked out and you have no control over the servo until power cycling (unplugging and plugging back in). The cause: The signal wire operates in a range from -100 to 100. The highest rate mode is -100, and the highest AVCS is 100 with 0 being essentially no motion and it is at
about 0 the gyro switches from rate to heading hold. IF the signal wire -- say channel 5 is right on the cusp of the two rates...say sometime between -10 and 10 then the gyro can switch to servo select mode.
The effect of this is the gyro locks out signal to the servo until the power cycle. Where this would bite an airplane guy would be if they set a switch to kill the gyro effect -- and this would essentially be delivering a signal of about 0. If you hook the gyro to a pot you can cause this to happen very reliably. simply start with rate mode and slowly rotate the pot. When the blue light comes on, stop, back up a bit, and find the point where the blue light flickers...then suddenly a red LED starts to flash with a code of between one and five red flashes -- corresponding to the servo that is currently programmed. Here is the second place this bug and strike. You may not know you entered servo select mode and change the servo type you've selected. This will not take effect until the next time the gyro powers up...and if you've got an analog servo you might need a fan to blow the smoke from the room. I know!! Ok, basically you can assume that all of the GA-250's purchase to this point have this problem. There are probably still about 1000 or more in the supply line that have this problem. Until HK sells out and restocks all they have will have this problem.
IF you have a gyro that has this problem, contact Meng at Assan and he will invite you to ship the gyro to him and they will flash new program onto it. I sent 4 back and it was about $4.
This second problem will probably not affect anybody because I think they got a handle on this.
Apparently I received the first gyros with fixed software. -- that is the problem of switching to the servo select mode. Unfortunately the software engineers at Assan did not engage the time tested practice of retrograde testing (checking to see if a patch of fix causes other problems) and these gyros arrived with a devastating flaw.
You may remember about a week or so ago I reported that my tests of the rate move were stellar. They were incredibly awesome. They beat the H
out of any piezoelectric gyro available at any price. I ALSO said I had not completed testing AVCS/HH functions. This was because early on something felt wrong and I did not have the time to run it down..so I set the limits on my TX for the signal channels from -100 - 0. This effectively kept me in rate mode and I had alot of fun. Then it came time to try AVCS....Saturday. It was windy as heck and when I launched my sky surfer (test plane) I had about 30% rate mode in the roll axis.... I had just come up to speed...about 30 feet high and thought I'd shut off the gyro until I was ready for the test. Rather than use the switch to flip it to zero I used the pot and entered AVCS... but just barely. Just barely didn't matter however -- the new fly in the ointment was that the gyro REVERSED the throw of the servo once it entered AVCS, I did not have enough time to process the situation and save the plane, although a stick of hot melt glue and it's ready for more testing. AT THAT TIME I DID NOT KNOW FOR SURE WHAT THE PROBLEM WAS. I'm using new Turnigy 9x radios with er9x software. I'm very enthused about these radios because they have been stellar so far. Of course that was my first suspect. The other pilots attributed the crash to the wind. I hit instant replay in my head over and over and realized it was not the radio because the problem was only roll and it seemed to me the left roll was worst as I added right aileron. Yesterday I mocked up the situation on my work bench. It didn't take long before I realized that I had probably been in AVCS inadvertently -- and only a few minutes after that that I understood that the gyro was reversing the servo output when it was in AVCS. The radios were still not off the hook. Out came my Futaba receiver and TX ... same result. Another hour of so of testing and I contacted Meng.
Here is some good stuff. Meng tested the situation and with a couple hours had contacted me twice - first to let me know they were testing my findings -- and secondly to let me know they had confirmed my findings. We exchanged several more notes, and ultimately Assan has notified all users that received this bug when sending gyros back for upgrading. Also they recalled all gyros with this bug that were still in China postal system. So the end result is nobody should see this happen in their GA-250. Just the same I think it's is prudent to be aware of it and test GA-250 for either of these bugs.
Actually if a person only wanted Rate mode or only wanted AVCS it's easy to work around both bugs. Simply use only that feature and set limits so you don't even get too close to the center point.
My final comments. I've never seen a company acknowledge a mistake as readily as Assan did. While somebody dropped a big serious ball in their engineering department -- I'm fairly confident that will be taken care of in house. I'm astounded that they have been so good about offering to flash new software to any gyros returned to them. I won't have the next version of the software until probably early Sept. You can bet I'll give them a thorough testing again and let you know.
When the bugs are stomped on these gyros they are going to rock the gyro world. Like I said earlier -- I've never seen such incredible performance -- but I've also never seen such nasty bugs either -- at least they are easy to recreate and remedy.
My apologies to Meng and Assan if my post causes them any damage. This is not intended in any way. In fact, it should do the opposite -- it should demonstrate that they are an upright company that stands behind their products.
