Old Jan 16, 2013, 03:57 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by crobar View Post
On the bench my eagle tree pro works just as it is supposed to. (I am using my gear switch to turn the gyro on and off). I take off with gyro in the off position. Once I am in the air I flip the switch to turn the gyro on and the plane does a major down spiral. Does the plane have to be flying level when I flip the switch to turn on the gyro?
Eagle A3, its not an eagle tree right?
Melnic is offline Find More Posts by Melnic
Old Jan 17, 2013, 05:40 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by bigaoleamy View Post
3G-A 3D Gyro.
where can we buy it????
jaccies is offline Find More Posts by jaccies
Old Jan 17, 2013, 11:01 AM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Here.
Gedexas is offline Find More Posts by Gedexas
Old Jan 17, 2013, 02:22 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Other than a case, I don't see anything the bigaole offers that the Eagle A3 Pro already does at the same price.
The A3 Pro has a known history and you can get it both in the USA and outside the US for $30. That first US supplier gives you the cables too.
http://www.mycoolrc.com/gyro/gyroLINKS.html
Old Jan 17, 2013, 05:02 PM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
I'm thinking about putting a hk401b I have on a RET plane, an Underball (Nutball variant). It has dual polyhedral, and the gyro would be mounted to detect rolling and correct it using the rudder.
I found an earlier post of someone who has done it, but does anyone else have an opinion?
Originally Posted by Vintabilly_NS View Post
If you have a RET airplane you can mount the gyro to sense a roll and correct by giving rudder input. Handy eh? I like to think of it as "adding scale mass" to make the aircraft less sensitive...almost like reducing the Reynold's numbers by electronics. It makes my planes appear scale from a distance..but that's not really a feature. :P
cmavr8 is offline Find More Posts by cmavr8
Old Jan 17, 2013, 07:39 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
Of course we have opinions
If the only control your plane has is rudder, then trying to keep wings level will mean that every time there is a gust, your plane will yaw violently. You will also lose some directional control in gusty weather. Is that what you want?
Try it, let us know.
Old Jan 17, 2013, 11:41 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
From experience, gyros aren't worth fitting on a rudder only glider. I took mine off as there was no advantage. Ailerons, yes. Rudder only, no. Maybe a heading lock gyro if you want it to fly straighter but rudder only will not stop the roll.
Grantham Kid is online now Find More Posts by Grantham Kid
Old Jan 18, 2013, 03:18 AM
cmavr8 is offline
Chris
Joined Sep 2010
The Nutball banks when rudder is used.
I also think it wouldn't work because the gyro will not have a way to directly correct wind effects. I just asked anyway because I saw someone has done it.
It is a headlock gyro, I could use it in that mode but it wouldn't change much.
Maybe I'll just put it on the elevator channel then... (controlling the elevator, dah )
EDIT: just found out that 3 people at the Nutball thread have had it working once upon a time. Asked there to see if they still do...
Old Jan 18, 2013, 10:04 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I"ll keep saying it but headlock is in my opion NOT the way to go to try your first gyro.
It's going to be hard to make a rudder-only plane fly well in the wind. even with a gyro.
I tried bypassin the aileron gyro on my hawsky once letting on the the rudder react as well as running the aileron gyro through the rudder. It just was not worth the effort. It would wiggle before it was doing anything useful. You could try it, but well, like you posted, seeing what others did on your specific airplane really is key. IF you do it, keep the rudder control tight, no slop.
Its good to ask nutball pilots (wouldn't that encompass everyone?) cause people who comment without any real world experiance with the gyros are just increasing their post counts anyway.
Old Jan 18, 2013, 04:48 PM
cmavr8 is offline
Chris
Joined Sep 2010
Nicely put.
I'll just try it on rate mode next time I get a chance.
Will report back.
Thanks for putting things in perspective
Old Jan 30, 2013, 11:27 PM
IceManPro is offline
Find More Posts by IceManPro
IceManPro's Avatar
Joined Sep 2012
Worth checking out the BL-3GRC ICE-MAN gyro too if you get a chance.
IceManPro is offline Find More Posts by IceManPro
Site Sponsor
Latest blog entry: BL-3G Independent review
Old Feb 17, 2013, 12:08 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Looks like a big gun in flybarless heli units have joined in....
http://cortex.bavariandemon.com/en/index.html
http://www.youtube.com/watch?feature...&v=5oL7v2ekRB4
What they are capable of and known for - bailout/self-leveling without the use of accelerometers.
HC3sX Horizon Mode and Rescue Mode - Goblin 630 - Part 2 (1 min 28 sec)
Silverexpress is offline Find More Posts by Silverexpress
Old Feb 17, 2013, 05:09 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Curious how they do the self-leveling w/o accelerometers.
Do they use another sensor (like a horizon detector)?
Or another guess: they initialize at level and then add-up all the rotations recorded by the gyros to keep track of how far away from level they are (sort of like heading-hold on level).
flying-llama is offline Find More Posts by flying-llama
Old Feb 18, 2013, 01:27 AM
Your customer
Joined Dec 2009
I don't have a clue.
Old Feb 18, 2013, 01:41 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The heliCommand website which I think is the same guys says this about their helicopter system:
The supplementary attitude stabilisation features an artificial horizon and three electronic gyros, and works completely independently of the prevailing visual conditions.
Suggests accelerometers to me. Pure speculation though.
jj604 is online now Find More Posts by jj604
Price Check on an RC Bike (Again, lol) RastaManBob Motorcycles 9 Nov 04, 2004 01:52 PM
First time on an RC airfield. Mendnwngs Fuel Plane Talk 18 Aug 03, 2004 10:57 AM
The most ridiculous use of an RC Airplane soholingo Electric Plane Talk 64 Dec 23, 2002 04:16 AM
