Old Dec 18, 2012, 08:25 PM
WhalleyB0Y is offline
Find More Posts by WhalleyB0Y
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Hey guys I am using the HK stabilizer V2 in my Funjet Ultra and I can't seem to get it right. The servos are moving correctly in their Delta configuration but it seems the gyro only corrects roll on one servo and the pitch on the other servo?? I cant get both servos working together in stabilizing. Any tips would be awesome. Tyia
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Dec 18, 2012, 08:52 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Can your stabilizer mix delta wing?* If so, is it on?
*You can't use delta mixer in your radio, the mixing needs to happen post-gyro.
Gedexas is offline Find More Posts by Gedexas
Old Dec 18, 2012, 09:33 PM
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Thanks, It was the radio. I had to remove the delta mixing in my Dx8.
Old Dec 24, 2012, 06:40 AM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Howdy.
Sub'bing.
And MERRY CHRISTMAS!
PikeStaff is online now Find More Posts by PikeStaff
Old Dec 24, 2012, 03:56 PM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
Originally Posted by Melnic View Post
Did you read the gyro page at mycoolrc?
http://www.mycoolrc.com/gyro/indexnew.html
Did you watch the vids?
Hello Melnic,
i watched your vid "setting up gyro for airplane."
It was very usefull, thanks fo the very helpfull vid
But i have a problem , maybe you can help me.
I have a GAZ-126 gyro for my ailerons and set it up as in your vid explained for rate mode on my DX8 GEAR switch 30% and 0% ( =light of gyro is just off with subtrim) ,
it is working just fine , but what i detect is this:
- the travel adjust setting on my DX8 for ailerons is on 100% ,
-and i have set the Limit pot on the gyro to approx 80% for aileron servo max deflection of 60 degrees.
i notice that only 50% left and 50% right of the aileron stick is only working for 100% deflection of +/- 60 degrees of the aileron servo
i measured with a turnigy servo meter the pulswidth of the gyro receiver channel
a pulswidth from 1700 to 1300 usec for a max deflection of the aileron servo and measured at the gyro servo output a pulswidth of 1920 to 1110 usec
the receiver channel aileron output pulswidth goes for aileron 100% stick movement from 1920 to 1030 usec .
so when i set the aileron travel adjust on the DX8 to 50% which gives a pulswidth of 1700 to 1300 usec then i can use the max 100% stick movement of the aileron stick for max servo defection of 60 degrees
is this a normal behaviour?
I have tested 2 GAX-126 gyro's and both behave the same
thanks in advance for answer
gyro is for the ailerons on my Antonov AN-124 wingspan 110inch
is it better to use one gyro for 2 ailerons servo's or should i use a Gyro's for each aileron servo?
jaccies is offline Find More Posts by jaccies
Old Dec 24, 2012, 06:48 PM
Grantham Kid is online now
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
One Gyro for ailerons. You will open a hornets nest trying to use 2 seperate gyros. Just my opinion. I have never done it but I can see there could be issues.
Grantham Kid is online now Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Old Dec 24, 2012, 09:48 PM
captain MoMo is offline
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
One Gyro for sure. I have recently intstalled one gyro on my PC-21 for teh roll (i.e. Aileron) axis and she flies awesome now. You need to adjust the gain once airborn. Start with a low gain and increase once airborn until the plane starts to jiggle left to right, then lower till it stops. Thats your best gain for the gyro. Also, I used the Detrum GY48v, a $10 gyro. You will need a minimum of 7 Channels to have room for the gain input as well as the gyro/aileron input.
captain MoMo is offline Find More Posts by captain MoMo
Old Dec 24, 2012, 10:44 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I"ve done 2 gyros before and then switched back to 1 cause it's just easier to use 1 and a Y cable. A 2nd gyro does not really offer any more advantages worth the effort.
Melnic is offline Find More Posts by Melnic
Old Dec 25, 2012, 03:40 AM
Joined Oct 2012
That Gyro is advertised as operating at 80A ? Can't be right. Maybe 80mA?
http://www.hobbypartz.com/60p-dy-1017.html
Old Dec 25, 2012, 03:42 AM
jaccies is offline
Joined Dec 2008
Melnic,
thanks for answer, onlyu thing what you can do with 2 gyro'' is use differential ailerons deflection.
Any answer for me Melnic about my stick problem in previous post?
Old Dec 25, 2012, 07:57 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
not sure what you mean but I can tell you that when you use a generic heli gyro, you can't always measure stick and difflection on the ground when not moving.
Dedicated airplane gyros like the bluelight and eagletree don't do this.
On some gyros, you move your stick 50% but the aileron moves 100% with no further difflection as you keep moving the stick. But in the air, it does not do that because it senses movement.
See this:
http://www.mycoolrc.com/gyro/controlthrows.html
Old Dec 25, 2012, 11:43 AM
Mach One
Joined Apr 2011
You are right! 80mA (from the manual)
Old Dec 25, 2012, 03:28 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
Originally Posted by jaccies View Post
Melnic,
Differential will not work with two gyros, the gyros will work independently of each other, so it's likely that the output of one gyro will interfere with the output of the other one. If you need differential, you can mix it mechanically at the servo or electronically at the "Y" cable past the gyro.
Old Dec 26, 2012, 04:32 AM
jaccies is offline
Joined Dec 2008
See this:
Melnic,
what you show in the vid, that is exactly what i see , but sorry it is hard to understand what you say that it does not do that in the air
do you mean that in the air that my stick movement works also for 50% to 100% and gives 50% to 100% movement of the aileron deflection?
and on the ground the stick movement works only 0% to 50% for 0 to 100% aileron defelection what i noticed.
the last issue i can only compensate that by setting the travel adjust of aileron to 50% , then i can use the full stick movement from 0 to 100% which gives a 0 to100% aileron deflection movement
so herewith i can prevent that THE GYRO TRUNCATES THE LAST 50% OF MY STICK MOVEMENT
Old Dec 26, 2012, 08:37 AM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
It doesn't, your stick movement and servo movement have nothing to do with each other when a gyro is involved.
A gyro listens to the receiver input and determines the required servo deflection based on the sensor readout. Sensor readout on the ground is always zero, so your servo deflection on the ground will always be different than it is in the air.
You never limit the servo deflection with your transmitter stick, you limit it with the endpoint adjustment on the gyro itself.
Price Check on an RC Bike (Again, lol) RastaManBob Motorcycles 9 Nov 04, 2004 12:52 PM
First time on an RC airfield. Mendnwngs Fuel Plane Talk 18 Aug 03, 2004 09:57 AM
The most ridiculous use of an RC Airplane soholingo Electric Plane Talk 64 Dec 23, 2002 03:16 AM
