Old Oct 04, 2012, 12:00 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Russ, hook up the cables the way they show it.
Hook up the Elev (Red) wire to your elevator connection on the Rx and make the Red wire go where the signal wires are.
Hook up the Brown wire to gear channel.
Leave the pitch wire hanging.
But I still say send it back unless you really wanna play it through
Melnic is offline Find More Posts by Melnic
Old Oct 04, 2012, 11:24 PM
Russ The Flyer is offline
Find More Posts by Russ The Flyer
It flies or it dies
Russ The Flyer's Avatar
Deville, Louisiana
Joined Sep 2008
I greatly appreciate that Mate. I like a good challenge and this is a good challenge. I've won some and I've lost some. That's what makes a challenge good. It's not knowing how it'll turn out 'til it turns out.
Russ
Russ The Flyer is offline Find More Posts by Russ The Flyer
Old Oct 10, 2012, 12:37 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I pulled the A3 Pro out of my Edge 540 and put it into my 1400mm Foam P47.
The P47 flies SOO smooth with the A3, windy day today.
EDIT: I"m using only RATE MODE. I keep RATE mode enabled all the time on this plane. OFF for me is only if there is a problem.
Old Oct 10, 2012, 12:58 PM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Agree. Even in a crosswind.
Bugbitten is offline Find More Posts by Bugbitten
Old Oct 10, 2012, 01:14 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I fly the same FMS series T28 with the standard A3. With that plane's 80 plus ounces it sure is a great windy day flyer.
Prof100 is offline Find More Posts by Prof100
Old Oct 10, 2012, 01:26 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Is there a dedicated A3 Pro thread or combo A3/i86AP/A3 pro thread?
Old Oct 10, 2012, 02:13 PM
LawnDartMike is offline
Find More Posts by LawnDartMike
LawnDartMike's Avatar
United States, OR, Salem
Joined Jan 2012
I have two A3 Pro's that are coming out of my 3d planes and going into two 1400mm (P-40 and P-47 FMS) planes that I'm getting put together. Glad to hear they work well and add some stability in planes that size.
LawnDartMike is offline Find More Posts by LawnDartMike
Old Oct 10, 2012, 04:44 PM
iskess is offline
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
I have an issue with my A3 Pro where it resets it's self back to default setting randomly sometimes, so I loose all my gyro reversing. It's a real pain, and pretty scary if I forget to check gyro direction before takeoff. Glad I have a switch on the pro to turn it off, that's all the pro upgrade is good for.
Has anyone had success reaching Eagle for service. They don't answer my emails, big surprise! I could reinstall the board to match the default directions, but that would take some tinkering to lengthen all the servo wires.
iskess is offline Find More Posts by iskess
Old Oct 10, 2012, 05:01 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
WOW, that's a surprise failure mode. I would just toss the supect one and try another. Also, make sure your jumper has good contact and it's not losing connectivity and reverting back to a default.
Old Oct 10, 2012, 05:39 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
It's diffective.
This will be the big difference from an EagleTree and anything from Asia. tail light warranty.
Old Oct 10, 2012, 08:37 PM
jwolf98 is offline
Find More Posts by jwolf98
United States, IL, Crystal Lake
Joined Aug 2011
I remember using a spare GWS cheapy gyro a few years back in a delta wing (micro Zagi). The thing had a tenancy to get buffeted pretty bad in the wind and that gyro made a huge difference. Now that gyro tech has gotten so cheap, I've been really tempted to try putting a KK board into a 3D model for practicing torque rolls. Anyone used quad controller boards for something similar? For $30, you can't go wrong if it works.
jwolf98 is offline Find More Posts by jwolf98
Old Oct 10, 2012, 08:48 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
http://www.rcgroups.com/forums/showthread.php?t=1614811
But not overly active as of late.
flying-llama is offline Find More Posts by flying-llama
Old Oct 12, 2012, 09:44 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Can anyone recommend a device targeted at merely keeping the takeoff roll straight?
I have 49" taildragger that's devilishly squirrelly on the ground, especially in the swirling toilet-bowl crosswinds that are common at my field.
Is there simple, inexpensive gyro, that would hold the heading, and then after takeoff could be turned off from my DX6i?
Thanks.
pugsam is offline Find More Posts by pugsam
Old Oct 12, 2012, 10:07 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Thanks.
http://www.mycoolrc.com/gyro/ruddergyroinstall1.html
Old Oct 12, 2012, 11:04 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Melnic, thanks, just watched the 2-part video - which was great!!!
Follow-up: I'll be using a DX6i. I assume that the GY48V would be controlled by the flap/gear switch, and programmed in the flaps menu. Any special instructions for that? (The flaps menu shows "FLAP" and "ELEV," and toggles between "NORM" and "LAND.")
At the end of your vid's part 2, you refer to another part to come, which would talk about generic setups. Is that out there somewhere?
Again, thanks.
Dave
Price Check on an RC Bike (Again, lol) RastaManBob Motorcycles 9 Nov 04, 2004 12:52 PM
First time on an RC airfield. Mendnwngs Fuel Plane Talk 18 Aug 03, 2004 09:57 AM
The most ridiculous use of an RC Airplane soholingo Electric Plane Talk 64 Dec 23, 2002 03:16 AM
