Espritmodel.com Heli Air
Old Aug 23, 2012, 10:15 AM
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
It's a good thing not everyone has the same kind of uneducated views about new technologies as mikhail does as we'd still be living in the stone age if they did.
Herman Munster is offline Find More Posts by Herman Munster
Old Aug 23, 2012, 10:31 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
A3 Pro
I moved the A3 Pro from my Hawksky to my Extreme Flight 540 Edge. I flew my Extreme Flight last fall,winter,spring till a couple weeks ago w/o a gyro and it flew great. Even in the wind, it really does not need the gyro to stay stable. But I'm using it to see how the gyro affects it and is an alternative platform for testing than my Hawksky. I previously flew the Eagle Tree Guardian in the Edge 540 so I can compare and contrast those two.
First off, as mentioned, the A3 Pro has the ability over the A3/i86AP to switch from RATE/OFF/HH mode via a switch. I have mine on a 3 position flap switch. But if you have a TX capable of setting 0% Travel adjust, you can use a 2 position switch and pick the 2 you want.
Also as mentioned above, the Heading Hold mode, wants to see 0 trim in order to know your not moving the sticks. You set this 0 trim mode, by removing the blue jumper and powering it up (as per the manual). So no matter what Tx/RX you have you can program it to not move w/ centered sticks. Here lies the problem as mentioned. It will not only see that as your center stick position, but it also sets the output signals to what it thinks is center (1500-1520uS abouts). So if you were to fly your plane w/o the gyro or were to fly the plane w/ the gyro in OFF or RATE mode, and then touch the trims, once you do the center stick function, the servos will move BACK to a non trim condition. This means that with the A3 Pro you have NO CHOICE but to trim mechanically whenever you want to use HH mode AND either OFF or RATE MODE. If you flew only in HH mode, no problem, It will just like a heli gyro, hold the plane straight. My only caveat on this is that if you were to line up for take off, you better hit the switch to OFF or RATE before taking off in HH mode or the plane may roll/pitch/yaw on you on take off. I spent some time, working on my mechanical trim to get it right. Previously, I've gotten my planes to be mechanically trimmed but usually needed to hit a click or two trim to get it nice and level and that was fine with rate mode, but with HH mode, the A3 does not like trim (note, this is not as much of a problem with the Eagle Tree Guardian, It remembers center stick but keeps the servo output to your trimmed setting when you reset the centering).
Next, I found that in HH mode, the gyro gain dials were MORE reacting different than Rate mode. For example, If I tested for an osciallation condition, the oscillation condition would occur sooner (with a lower gain) in HH mode than rate mode. And in HH mode, the oscillations (occured for me with elevator) were very violent (unlike in the Eagle Tree Guardian where it has the oscillation detection). In order for the HH mode to have any benifit in a torque roll, I had to crank up the gains. If I had the gains lower, the plane response was laggy, and I really need to put in some Dual rates to make it feel comfortable as well. When I did the torque roll, it was MUCH easier than before, but almost to the point of "that's great, but this wont' help me get better at my stick movements to be better at torque rolling". So although, the A3 Pro allowed me to torque roll easier, I dialed back the gain and then ran it in rate mode instead.
So once again, I come back to RATE mode being more "organic" and "natural" than HH mode. Rate mode is more like taking a small plane and making it fly like a big plane. I can sort of quantify this by saying that my friend's 100" wingspan Extra 300 was SOO much easier to torque roll than any of my planes, it made me realize that I was not as bad as I thought if I was comparing myself to people with bigger planes. But w/ my little Edge 540, if I simply have a RATE gyro, I'll be learning the orientation skills needed for a good torque roll w/o having to bring out a big gas planes so I'll get more stick time. (my 48" Edge hangs in my garage and fits in the back of my Yukon w/o taking it apart so I can litterally spend 30 seconds getting into the car and 2 minutes setting it up before I fly allowing me to easily fly before work or lunch break).
Oh, yea, this was asked before, YES, the A3 Pro in Rate mode as well as HH mode will fight the turn some. Less in Rate mode than in HH mode if you keep the gyro gain down.
So I know that some of you have been happy w/ the A3 Pro in HH mode, but for me, I'm gonna recommend people still start out in Rate mode. If I were to keep the A3 in the Edge 540 that is already a VERY stable plane, I'd be flying it mostly in the off postion unless it's excessively windy or I'm practicing my torque rolls.
Melnic is offline Find More Posts by Melnic
Old Aug 23, 2012, 10:42 AM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Here's my 800mm FMS T-28 with the i86ap from HK.
FMS/Airfield 800mm T-28 Trojan w/ Stability System (6 min 48 sec)
Diesel6401 is online now Find More Posts by Diesel6401
Old Aug 24, 2012, 03:59 AM
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Melnic,
Thank you for the excellent review and comparison to the Guardian. I finally really understand. I flew my A3 Pro today for the first time and HH mode was a terrible mess. Now I understand why. I'm going to edit my end points so I never inadvertently turn it on.
Rate mode worked very well. I will need to reprogram my RTH on my DOSD because it no longer has the control authority to turn the plane around.
I had one major problem with my A3Pro. Twice it forgot my gyro reverse settings, and switched back to default directions. The second time I didn't catch it on preflight, and it made for a very scary and confusing flight. When I got it on the ground, and checked the settings, I only saw blue flashes, my red flashes had gone away on their own.
Has this happened to anyone else?
iskess is offline Find More Posts by iskess
Old Aug 24, 2012, 10:48 AM
WRXpilot's Avatar
Bethesda, MD
Joined Jul 2006
He's also over in the Battery forum extolling the virtues of old-school "Tamiya" battery connectors over the myriad of high-quality, low resistance hobby-grade connectors. I know this is a topic that approaches religion in terms of discord, but I've never met ANYONE that thought the Tamiya connectors were anything but toy-grade crap.
He's either trolling all over the forums, or just has a very particular & esoteric set of firmly-held beliefs, and is unwilling to change them based on empiric data & evidence reported by others. Either way, not a particularly useful source of knowledge on a community forum.
Personally, I'm waiting for the OrangeRX 3-axis to come off backorder. For $15, I'll try them in a couple of my planes at least. Wind doesn't scale properly with the small size of our models, if these do nothing else but help to dampen the effects of wind on lightweight electric models, they're already worth it IMO.
WRXpilot is offline Find More Posts by WRXpilot
Old Aug 24, 2012, 05:13 PM
Joined Nov 2007
I just recently got my Guardian 3 axis gyro, can't wait to try it out. The plane I'm installing it in is going to the field tomorrow and I'm going to get everything trimmed up mechanically, then the gyros going in. Should be fun.
Old Aug 24, 2012, 07:54 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
I really want one of those for my Dynam Peaks Bi-pipe... looks like an awesome product.
Old Aug 26, 2012, 12:28 AM
1911tex's Avatar
Joined Nov 2010
Diesel6401: I use the Detrum GY48V gyros on my Dynam Peaks....one for the ailerons and one for the rudder. I see no need for an elevator gyro; which negates a 3 axis gyro. The Rudder is on my DX7 gear switch and the ailerons on the flap switch. Switch them off unless in very windy conditions; sure make the bipe fly like dead calm when all other flyers are grounded. Like cruise control on a car, for those winers. These Detrum gyros are cheap and faultless and I followed the Melnic website instructional videos...what a great value to us mortals! Love that Peak bipe...the best plane I ever owned.
1911tex is offline Find More Posts by 1911tex
Old Aug 26, 2012, 03:08 AM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Another 3 axis gyro
Melnic,
Check it out and only $50
http://www.bluelight-tech.com/index.htm
Prof100 is offline Find More Posts by Prof100
Old Aug 26, 2012, 08:33 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Hey Prof good find.
That one is a geek's delight. You can adjust just about every possible variable that influences the outputs. Wow!
jj604 is offline Find More Posts by jj604
Old Aug 26, 2012, 08:51 AM
Prof100's Avatar
Joined Jul 2007
Originally Posted by jj604 View Post
Hey Prof good find.
There is even a developer's model for twice the price. May the geek's have a party.
Old Aug 28, 2012, 06:54 AM
Joined Jun 2011
https://www.youtube.com/watch?v=X6JM...e_gdata_player
Got a pair of those i86 on order to play with. Pretty easy setup?
RustySpork is offline Find More Posts by RustySpork
Old Aug 28, 2012, 08:21 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Yea not to bad. Go on HK website and find the product and click the "files" tab towards the bottom and find the instructions and the amendment. Read the amendment first because theirs a mistake in the instructions regarding output leads and the amendment calls out that mistake.
Old Aug 28, 2012, 11:43 AM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Originally Posted by Prof100 View Post
Melnic,
Got one on the way to me. i'll report when I get it in.
Old Aug 28, 2012, 04:39 PM
Prof100's Avatar
Joined Jul 2007
I look forward to your analysis and report.
Price Check on an RC Bike (Again, lol) RastaManBob Motorcycles 9 Nov 04, 2004 12:52 PM
First time on an RC airfield. Mendnwngs Fuel Plane Talk 18 Aug 03, 2004 09:57 AM
The most ridiculous use of an RC Airplane soholingo Electric Plane Talk 64 Dec 23, 2002 03:16 AM
