Old Apr 17, 2009, 02:37 PM
Seahawk82 is offline
Find More Posts by Seahawk82
Joined Mar 2007
Flightpower Eon vs Eon-X
Saw a post somewhere about new Flightpower Eon-x batteries
are these newer than "Eon"
does anyone have any idea about the difference between them ?
thanks
Allan
Seahawk82 is offline Find More Posts by Seahawk82
Old Apr 18, 2009, 02:57 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Maybe there was a problem with the EON and now they bring out the EON-X. I know there are some EON batteries that where already discontinued some time ago. Reason?
rebell is offline Find More Posts by rebell
Old Apr 18, 2009, 06:02 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
I have been testing the EON-X for some time now, its quite a big uppgrade from EON and current Lipo batterys on the market today. The resone why they bring out EON-X now already is becas there have been production problem with the EON, to fix this and have full production we get EON-X, first out will be the 30C, and its much more powerfull than the EON33 for example and other 30-35c rated packs on the market, in fact the 25c EON-X is up with same power as todays 30-33c rated packs, testing in 3D heli a prototype version that is not even perfectly matched, it holds up to 3,75v/cell avg and other packs in same size and spec holds 3,5-3,6v/cell. Maby the most importand aspects of the EON-X will be the fast charge and sycle life even at high C loads.
Jocke is offline Find More Posts by Jocke
Old Apr 24, 2009, 11:48 AM
UbHauled is offline
Find More Posts by UbHauled
Glassy waters to all
UbHauled's Avatar
California
Joined Jul 2006
Do you have a discharge chart?
UbHauled is offline Find More Posts by UbHauled
Old Apr 24, 2009, 12:13 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
What kind of fast charge rates are permitted? Is this another 5C charge rate cell? I want some 10C charges on LiPos! It'd be nice to apply 20A from the iCharger 208B on my 2200mAh cells to get a full charge from 80% depletion in ~6-7 minutes.
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Old Apr 24, 2009, 12:21 PM
UbHauled is offline
UbHauled's Avatar
California
Joined Jul 2006
- David
That would be awesome David I am with you, BUT keep in mind that the higher the Charge rate, the shorter lipo life you'll have...
Old Apr 24, 2009, 12:31 PM
Joined Dec 2006
Not necessarily. New cells are claiming little to no impact on cycle life from high C charging. Time (not marketing) will tell. I often charge at 2-3C using quality cells and have experienced no impact on cycle life.
Site Sponsor
Old Apr 24, 2009, 12:40 PM
UbHauled is offline
UbHauled's Avatar
California
Joined Jul 2006
Hi David, Jan here...
how long have you charged them at this rate?
I wish I could remember where I read that it shortens cells life.
Old Apr 24, 2009, 12:49 PM
Joined Dec 2006
Hey Jan! I've been using 2C-3C on some test packs for ~1 1/2 years. I keep detailed logs and 1C charge other identical packs for a control sample. I've experienced no demonstrable effect on capacity charging at these rates and many others have reported similar results.
Note : this should only be done with newer high C rated packs (15C-40C cont. rated, manuf. in last 1-2 years) or those packs rated for such. And ONLY when using a quality charger with integrated balancing to allow for individual cell monitoring and charge current tapering to prevent cells from exceeding max. permissible voltage of 4.20V/cell.
Site Sponsor
Old Apr 24, 2009, 01:03 PM
UbHauled is offline
UbHauled's Avatar
California
Joined Jul 2006
Interesting, I am assuming that the packs are holding up voltage as well as the holding charge when sitting on the shelf, right?
Well, I'll try to find the article I've read and post a link or file here...
Old Apr 24, 2009, 01:14 PM
Joined Dec 2006
Oh yeah, no problems whatsoever with that. The only impact/risk I've heard associated with high charge rates is decreased cycle life, which I have not experienced.
Site Sponsor
Old Apr 24, 2009, 02:32 PM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Yes i have grafs and some data, but letts whait untill FlightPower makes these new cells official first.
Old Apr 24, 2009, 02:46 PM
Joined Dec 2006
Aight.
Are there any official info. releases from FP on the new EON-X line?
The Eon line has to be the shortest lived product line in battery history. How long were they available, ~2 months?
- David
Site Sponsor
Old Apr 25, 2009, 04:33 AM
Jocke is offline
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
No i dont think there are any official info of the EON-X yet, but there will be soon.
Old Apr 25, 2009, 10:57 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
Jocke, the problem with this information is that you are connected to FP and as seen in other threads you will say anything to let them look good. As indicated by others as well, only independent information will be believed.
Sold NIB FlightPower EON Lite 20C 5S 5400mAh pack Fidelity101 Aircraft - Electric - Batteries & Chargers (FS/W) 8 Apr 17, 2009 01:23 AM
Discussion New FlightPower EON batteries rebell Batteries and Chargers 3 Jan 02, 2009 03:17 PM
Question 11 x 3.8 APC SF vs. 11 x 4.7 SF APC? Shortman Power Systems 5 Feb 01, 2004 12:12 PM
Wally Wing -Vs- ZAGI400(x) Bsmooth Foamies (Kits) 5 Aug 15, 2002 04:11 PM
rocket wing vs zagi x Which why funflyer Foamies (Kits) 7 Jul 15, 2001 09:00 PM
