Old Apr 17, 2009, 02:11 PM
RoadKingAl is offline
Find More Posts by RoadKingAl
RoadKingAl's Avatar
United States, IL, Chicago
Joined Aug 2008
NEW Turnigy 2.4Ghz FHSS and DSSS - 9 channel radio under $80.00
8 Channel 2.4 RX under $20.00.............
http://www.hobbycity.com/hobbycity/f...ts.asp?TID=284
Available in 2.4Ghz FHSS and DSSS
On sale in around 3 weeks.
Estimated Street Price: (About $79.95)
RoadKingAl is offline Find More Posts by RoadKingAl
Old Apr 17, 2009, 02:30 PM
F-111 John is offline
Find More Posts by F-111 John
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
This was supposed to be on sale last Monday, April 13th, but was delayed due to a box printing error. I hope it isn't another three weeks before they are on the HK web site!
http://www.hobbycity.com/hobbycity/f...&PID=4538#4538
HK is also going to offer the Turnigy 6 ch 2.4 GHz radio, with drivers for Windows Vista, at around the same time.
The nice thing is that the 4 ch, 6 ch, and the 9x (8 ch with 2.4 GHz module) all can use the same 6 channel $15 receivers.
So for those of you who have bought those inexpensive 4 ch and 6 ch transmitters, you should be able to upgrade to this transmitter and keep using your existing receivers.
F-111 John is offline Find More Posts by F-111 John
Old Apr 17, 2009, 04:30 PM
RoadKingAl's Avatar
Joined Aug 2008
Thanks John for the update;
Sweet, Should be a new world a big plus for both the New pilots, as well as our Seasoned Pro's.
Old Apr 17, 2009, 05:25 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
This is another version of the iMax 9X (Reviewed here) but I'm planning to review the HK version to see if they've made any significant changes.
If they haven't updated the manual (really bad Chinglish) then I'll post a far more readable version that I've written for the iMax, once I've got my hands on a set from HK.
Assuming no major changes from the iMax...
Pro's:
* Low cost
* 8-channels (9 in PCM mode on 35/72MHz)
* Nice feel for a budget radio
* Receivers include satellite unit
* Some of the programming is great
Con's:
* No failsafe when used with the 2.4GHz modules (only with PCM)
* Physical construction (of the iMax version) could have been better
* QC not up to scratch -- of three units purchased, only one was acceptable.
* Manual almost incomprehensible
* Relatively low power and unsophisticated RF sections
* Some of the programming is awful
However, in a year's worth of flying I've never had any issues with my iMax9X and it's my radio of choice for profile 3D flying (.46-1.00 sized engines)
If the factory has sorted out its lack of QC (the 4-channel does seem better) then this will be a good radio for small/medium electric/glow fliers. It's not a radio for jets or gasers though!
Note: I've also reviewed the HK 4-channel 2.4GHz system and shares the same basic RF systems.
A reminder that all the comments in respect to the 9-channel system assume that it is simply another OEM version of the FlySky 9-channel like the iMax. Until I get my hands on a Turnigy unit I won't be able to positively confirm that.
One of the first "hacks" worth trying on this set is to modify it to work with a 2S LiFePO4 or LiPo battery pack instead of the conventional 9.6V NiMH/NiCd one. Since the electronics work on a mix of 5V and 3.3V, there's little point in feeding this thing with twice the voltage it needs -- all that does is waste half your battery's capacity as heat.
In an FM/PCM radio, the extra voltage is useful to get adequate power from the transmitter module but in the 2.4GHz world, the vast majority of modules run on much lower voltages. If the 9X didn't also offer a 35/72MHz module they could have easily shifted to a 6.6-7.2V battery and provided twice the life per charge.
Clearly the Chinese need to think a bit harder about some of this stuff.
XJet is offline Find More Posts by XJet
Old Apr 17, 2009, 05:37 PM
4567 is offline
Find More Posts by 4567
4567's Avatar
Joined Mar 2009
would you guys recomend this as first radio cause the price just really grabs me?
4567 is offline Find More Posts by 4567
Old Apr 17, 2009, 06:17 PM
RoadKingAl's Avatar
Joined Aug 2008
Pro's:
* Low cost
Con's:
Thank You very Much for this update;
Great Information, Super Job. I will be following awaiting your final results.
Please keep us updated, seems like you will be the best in knowledge and information.
Many Thanks again;
Al
Old Apr 17, 2009, 06:32 PM
dav12 is offline
Find More Posts by dav12
Joined Jul 2004
Once we buy at Servo 9 gram $ 20-30, today we buy at good Servo 3-4 $ (HXT900), that will happen with this transmitter.... and receiver costs $ 12 compared to other receiver(2.4ghz) cost $ 50-100.
dav12 is offline Find More Posts by dav12
Old Apr 18, 2009, 01:13 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
That is cheap. I'm guessing that this will not work with the likes of an ar500, ar6200, ar6100, etc? Do all 2.4 have the DSM2 builtin?
All of my planes have the ARxxxx Rx and I have 2 DX5e and 1 DX6i, so I'm probably sticking with them for now.
WOW $15 Rx!!!
robj is offline Find More Posts by robj
Old Apr 18, 2009, 03:04 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
No, just like other 2.4GHz systems, the products from FlySky are only compatible with themselves.
Old Apr 24, 2009, 09:49 AM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
There in
http://www.hobbycity.com/hobbycity/s...idProduct=8992
keyman923 is offline Find More Posts by keyman923
Old Apr 24, 2009, 10:22 AM
LAN is offline
LAN
Find More Posts by LAN
LAN
LAN's Avatar
Sweden, Östergötland, Valdemarsvik
Joined Oct 2003
Interesting, it's sold without TX module and any JR-compatible module will fit (which would include Spektrum or Robbe FASST modules). If you add a Corona module + receiver, the total price is $120.
LAN is offline Find More Posts by LAN
Old Apr 24, 2009, 11:48 AM
pqt_bach is offline
Find More Posts by pqt_bach
Electro Addict
Joined Aug 2007
I acn hardly wait for someone with some radio analyzing equipment will take this one under the scope. If it's a well designed and operating system, I would be a bit surprised, but very happy
One thing I could notice from the picture is that the use the el-cheapo PCB type, which say much to durability, but then again - no Tx should be dropped or get abused. Let's hope the software and radio specs are of better quality
pqt_bach is offline Find More Posts by pqt_bach
Old Apr 24, 2009, 11:49 AM
airheli1201 is offline
Find More Posts by airheli1201
United Kingdom, England, Milton Keynes
Joined May 2007
was just looking at hobbycity. seems pretty interesting
airheli1201 is offline Find More Posts by airheli1201
Old Apr 24, 2009, 12:04 PM
heffe2001 is offline
Find More Posts by heffe2001
Conover, NC
Joined Jun 2005
If they are still in stock next Friday, I plan on ordering one with a Assan JR module (also going to get a Assan hack module for my 6102).
heffe2001 is offline Find More Posts by heffe2001
Old Apr 24, 2009, 12:35 PM
R.I.P, Aardvark.
F-111 John's Avatar
Holt, MI
Joined Jan 2009
According to Jason at Hobby King, this will be sold bundled with the Turnigy 2.4 module for about $80 beginning some time next week. The Turnigy 2.4 module will be compatible with the same $15 Hobby King 6 channel receivers that are also compatible with the 4 and 6 channel Hobby King/Turnigy transmitters.
The real question is will there be an 8 channel version of the Turnigy 2.4 receiver available at some point in the future, or are you stuck with only 6 channels?
Update: The Radio and Turnigy module will be $85, and 8 channel receiver will be $20.
For Sale Two Spektrums AR9000 DSM2 9-Channel Rx Brand NEW JR 2.4GHz theant1 Aircraft - General - Radio Equipment (FS/W) 1 Oct 19, 2008 09:00 PM
For Sale Two Spektrums AR9000 DSM2 9-Channel Rx Brand NEW JR 2.4GHz theant1 Aircraft - General - Radio Equipment (FS/W) 1 Oct 15, 2008 11:42 PM
Sold JR X9303 2.4ghz TX. With R921 9 channel 2.4ghz rx and a 6100 end pin RX cryhavoc38 Aircraft - General - Radio Equipment (FS/W) 5 Dec 26, 2007 02:01 PM
Discussion Next News: Kyosho 2.4GHz FHSS Rudy Vienna Radios 1 Feb 13, 2007 10:43 AM
Best 9 channel radio under $500? jwood Electric Plane Talk 9 Jan 31, 2002 04:30 AM
