Old Apr 17, 2009, 12:37 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Source for 1 green dot brick connector
I had a old broken estes plane in my junk stash and noticed that the wing to fuselage connector was smaller than a JST and looks a lot like the new AR6400 connector, so I soldered the female onto one of my green dot's.
I wish I had more junk sky rangers laying around...
It may not be the exact connector for the new linear servo, but since I have both a male and a female, that shouldn't be a problem.
Also, if the order of the pins is different on the new servos, it's easy to swap them around in these connectors.
UNGN is offline Find More Posts by UNGN
Old Apr 17, 2009, 03:45 PM
tune by tito is offline
Find More Posts by tune by tito
Inventor&Genius Extraordinary
tune by tito's Avatar
USA, CA, Riverside
Joined May 2006
Read this thread, you will find many connectors from regular servos down to 1.0mm;
http://www.rcgroups.com/forums/showthread.php?t=1024553
Best regards tito
tune by tito is offline Find More Posts by tune by tito
Old Apr 17, 2009, 05:00 PM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Maybe you could figure out how to solder the actual Female connector to the board somehow and get rid of those leads! Would be stronger, neater and sexier too.
Veteran is offline Find More Posts by Veteran
Old Apr 17, 2009, 09:21 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Oh, I almost forgot.
The other great thing about the female connector from the estes sky cruiser (I remembered the name) is that it plugs right into the plug on the 3A Brushless ESC from Hobby city, so the 5th channel can be mixed with the throttle channel for Brushless operation without a converter and the brick is plug and play.
Old May 27, 2009, 02:04 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
Do You need to have the lipo connection left or can the esc leads power the rx thru the servo connections as it normaly does. Or do You power the esc/motor thru the rx?
Just wondering since i dont believe pulling 3 amps thru the rx would be safe.
Need all info i can get since i ordered 2 rxes yesturday.
/Ulf
methuso is offline Find More Posts by methuso
Old May 27, 2009, 02:17 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
/Ulf
I'm going to run separate Positive and negative wires to the ESC power wires from the battery wires and power the brick normally.
The voltage will all be the same, but the brick probably wouldn't like the amp draw through the servo connector.
Old May 27, 2009, 08:24 AM
methuso is offline
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
what about feeding the brick from the ESC thrue the servo connector like on other RXes? Would the servos pull too much amp that way ?
/Ulf
WTB/ Source for 1/8 carbon fiber tubes for fanfold 3d's pval3 Aircraft - Electric - Airplanes (FS/W) 9 Nov 15, 2003 04:45 PM
Online source for 1.5 MicroHenry Ferrite Choke???? Chuck Parkflyers 3 Jun 12, 2003 11:32 AM
Here's a source for $1 c/f Zagi spars slowflyer Foamies (Kits) 0 May 01, 2001 01:16 AM
