Old Apr 17, 2009, 09:53 AM
zultone is offline
Find More Posts by zultone
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
Toys R Us giant foam glider to giant foam glider 3 Channel RC
To start - my journey to find a really big foam glider.
Hour 1 - Trip to Wal-Mart
After much looking, and talking to some not-so-helpful staff, my lady and I decided Wal-Mart doesn't have them.
Hour 2. Target! They're better than Wal-Mart... Maybe not so... No foam gliders here.
Hour 3-5. Toys R Us!
After much looking and asking some (quite) helpful staff... They had one left in stock!
But, it was BROKEN! Just the tail... bamboo skewer through it and some generous amounts of hot glue later, all better! fixed it.
Also got a %10 discount too.
They also had a small digital camera that takes video -and- SD cards, 12.50.
I will be testing it out on the slow stick today
Nifty.
Onto the build - pics will come soon. Forgot to bring them today.
Hot glued the wings on, and the plastic connector.
But SHIZZNIT! Glued the connector on backwards... Snap. Oh well.
I got the 'guts' from a Revell WhiteWolf heli, 2 180 motors, and a tail motor.
Replaced the tail motor with a linear actuator, works great.
Flight tests performed as 2 channell in my backyard... Haven't hooked up the tail yet.
First flight test - 1/8 throttle... Slow, gentle glide downwards.
Crap! Ground is coming at me. FULL THROTTLE! Suddenly it was vertical, 40 feet in the air... Aanddd... It stalled.
Oh no!
Back to 1/4 throttle. TREES! Smash.
Round 2. Fixed up the motors again, checked damage.
Launched, 1/2 throttle. Smooth climb. Noticed the wings bend.
A lot.
Like, a whole lot.
The wings were bending so much, the wingtips were straight up!
In the shape of a U.
Attempt at more throttle and turn because the CRASH! Tree... Is right.. There...
And the stream my plane just landed in.
The motors need glued back on, and I will be placing them farther out on the wing. They're 3 inches out each side, going to try 6".
Debating on how to hook up the tail... I'll figure it out.
Thinking of cutting the elevator in half via homemade hot wire cutter, and using the act for it. Should be plenty responsive.
Things I learned from flight tests -
Should've hooked up the tail!
Need to add a generous balsa spar to the wings.
I have several 36"x1/4 inch spars to add.
Need to take it to the field. Not enough space in backyard.
Need's further rear COG. I had the tail with full up elevator to level flight.
The wings are swept back, so moving the motors should help with this as well.
The guts I'm using previously had some issues - the last few times I tried it, I would plug the battery in, arm the motors, and full throttle.. throw plane. And it would slow down, and cut off, much like the LVC.
Tried a few more times, and decided to check wiring.
Short circuits everywhere! I guess I'm lucky it's not fried. Fixed it now.
Pics and video soon! Stay tuned.
That's all folks.
zultone is offline Find More Posts by zultone
Old Apr 17, 2009, 11:29 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Do you have a SKU number for the $12 camera that takes SD?
Nifty.
Oh no!
A lot.
Like, a whole lot.
That's all folks.
rich smith is offline Find More Posts by rich smith
Old Apr 17, 2009, 11:47 AM
zultone is offline
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
I'm at work right now so I don't have the SKU, but it did come with Arcsoft.
VQxxxx is the name of it.
Short search -
http://www.overstock.com/Electronics...3/product.html
That is what I have I think
Old Apr 17, 2009, 11:56 AM
zultone is offline
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
http://www.vistaquestusa.com/support...s/VQ1005BL.pdf
15grams. I knew it was light.
Old Apr 17, 2009, 01:45 PM
rich smith's Avatar
Joined Dec 2006
Yes, I got several of those from TRU but price was $22. I need to drop by again maybe.
They are a fantastic little camera and will take thousands of stills but unfortunately have very short recording capabilty regardless of SD size. Can be trimmed to 5 gram or less w/o case.
I'm at work right now so I don't have the SKU, but it did come with Arcsoft. VQxxxx is the name of it.
Short search -
Old Apr 17, 2009, 02:09 PM
zultone is offline
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
I noticed it does only take about 2 minutes of video, and then cuts off. I wonder if there is a way to bypass this? I'm thinking about rigging it up so that every time I use full left rudder, it takes a picture.
Old Apr 18, 2009, 01:49 AM
rich smith's Avatar
Joined Dec 2006
You will find there is a problem with CMOS cameras in general. Vibration causes "wavy" lines so it is usually necessary to stop the motor to get clear pics. I found it best to click shortly after throttle is cut (chan 3). Another trick is to continuously take pics every few secs and hope a certain percentage will come out.
Discussion Toys R Us glider turned crazy EDF 68Strat Foamy EDFs 6 May 25, 2008 09:28 AM
Video Toys-R-Us Glider conversion ExtremeSkyes Electric Plane Talk 0 May 25, 2006 08:44 AM
Toys R Us Peteohms Scratchbuilt Indoor and Micro Models 4 Nov 27, 2003 09:15 PM
Anyone using the Toys-R-Us batteries in a GWS Zero? WickedFunRC Batteries and Chargers 4 Nov 16, 2002 10:18 PM
Packs @ Toys R Us Daddio Aircraft - Electric - Airplanes (FS/W) 19 Oct 18, 2002 11:43 AM
