Old Apr 17, 2009, 02:30 PM
dnchvs is offline
Find More Posts by dnchvs
Joined Nov 2008
i put it in my drill press and i put it to the belt to the slowest speed it has a ton of torque do you think it will be to slow for a tug with a 3 inch prop
dnchvs is offline Find More Posts by dnchvs
Old Apr 17, 2009, 05:06 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Too slow, yes.
A good resource is the Raboesch prop catalog at http://www.raboesch.com/
Max speeds given therein are good typical limits for any scale prop of a given size... max for a 3" (75mm) prop is around 4700rpm. You may not want to run that fast normally, but 1400 rpm is definitely too slow.
What is this beast of a motor?
patmat2350 is offline Find More Posts by patmat2350
Old Apr 17, 2009, 06:22 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
I have found that a model airplane tachometer is priceless on finding the true RPM of any spinning object. I cut a piece of white adhesive tape and put it across the center of whatever is spinning. Piece of cake.
I have found that slow high torque motors need a OVERDRIVE setup.
The PTB below is running 2 :1 stepup drive ratio. with 5.5" pitch props. Gives a very smooth acceleration to about 20 mph.
The motor is a MinnKota 41# trolling motor driving timing belts. About 60 lbs of boat.
EDIT :
A look at the first picture, lower photo shows the deck & hull of the Artisana Amsterdam.
It is running a 1 to 1 timing belt drive to get the prop shaft horizontal to the big Pittman motor. A Octura #1470 plastic racing prop of 2.76" x 3.8" of pitch gives a realistic boil of water that is almost the height of the fantail. Bow wave is white water.
Torque can always be made into speed. Heavy, slow boats
High RPM's can not always be made into enough torque. In most cases.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Apr 18, 2009, 07:08 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
Originally Posted by patmat2350
mfr- au contraire, my friend. this method will give you the kV value of a DC brushed motor quite nicely.
dnch- you're measuring voltage, set it to one of the volt scales... probably something like "0-5v".
I will take your au contraire and raise you a think again.
Rotating the motor at a known speed and reading the voltage generated, then repeating at a different known speed will give useful figures. However, doing this takes no account of losses when used as a motor. Applying 6 volts will not give the same rotation speed as seen when generating 6 volts. The motor, even when not carrying an external load, still has its own internal inefficiences to cope with - these are taken care of by the driving device when used as a generator. Of course, an efficient motor does not necessarily equate to being an efficient generator, and vice-versa.
Being cautious, I would set the voltmeter to a higher value, then wind down. The needle tends to go curly when the meter sees too high a voltage.
mfr02 is offline Find More Posts by mfr02
Old Apr 18, 2009, 07:09 AM
dnchvs is offline
Joined Nov 2008
pat,it's a auto fan motor
Old Apr 18, 2009, 08:45 AM
Vita ex Machinis
patmat2350's Avatar
Joined Dec 2004
dnch- no clue, good luck!
mfr- I'll see your think, and call!
Bob Boucher is the brains behind Astroflight, and has written a number of papers in the field as well being a true pioneer in electric aviation. I have his book on motors, see below (now out of print, I think).
If Bob says the method works to determine a kV value, then I'm looking no further.
Old Apr 23, 2009, 02:44 AM
1Ironhorse is offline
Find More Posts by 1Ironhorse
Keep it Simple, Make it Fun!
1Ironhorse's Avatar
Wichita, KS
Joined Jul 2007
If you really want to know motor RPM, then use a data recording unit. Eagle tree has some for RC. http://www.eagletreesystems.com/Boat/boat.html They have a RPM sensor (magnet & Hall effect switch) that works really slick. That's the next thing on my "Gotta Have" list.
By the way, RMS stands for Root-Mean-Square, an AC (alternating current) measurement. It is .707 of the peak voltage or current or power, i.e. the avarage of 1/2 cycle of a sinusoid (avarage of a full cycle is 0, half of the sinusoidal wave is positive and the other half is negative). It is used to express the avarage power of an AC circuit.
1Ironhorse is offline Find More Posts by 1Ironhorse
Old Apr 23, 2009, 08:04 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
I reckon that real life trumps any theory.
Determining what a generators KV is, however accurately, can never predict what its actual performance as a motor will be.
The method given does not state the electrical load that the generator is subjected to - this affects the output voltage. When the motor is being run, what mechanical load is being imposed? This affects the running speed. Even with an airscrew, fit a larger diameter or different pitch, and the results will vary. The same applies with boats, but we get the added bonus of a more complex drive arrangement, usually a prop shaft with at least two bearings and a flexible joint, each applying different loads at different speeds.
All the above assumes a constant voltage supply such as at full speed (i.e. straight DC) - a lower speed from a PWM ESC can give much more variable and differing results depending on the characteristics of the motor, pulse repetition rate and the dwell angle at any given time.
You can use a motor as a sensor head to indicate RPM, but expecting an accurate prediction of performance as a motor is asking too much.
Old Apr 23, 2009, 08:21 AM
Vita ex Machinis
patmat2350's Avatar
Joined Dec 2004
mfr, you miss my point... the method gives a KV value which tells us what the FREE RUNNING (i.e., NO LOAD) speed is, and it does that quite well.
Nowhere did I address the issues of:
a) how fast will the motor spin with a load, and
b) how a powerful a motor is needed to drive a given prop at a given speed.
But elsewhere, I have mentioned that any load will slow down the motor, causing it to pull more current; and that with an appropriate match (how ever you get there), you want to avoid such a big load (i.e., big prop) that the motor is slowed to less than about 75% of the free running speed, else we have risk of overheating and may need to watercool everything (an abomination imho, except in b@lls-to-the-wall racing).
But, when dealing with "found" motors, knowing the no load speed is a good start for determining whether the motor is appropriate for a given application, especially when coupled with the use of recommended prop speed charts such as found at www.raboesch.com
Cheers, PM
Old Apr 23, 2009, 11:52 AM
mfr02 is offline
Blackpool, Lancs
Joined Feb 2006
Fair enough - there is nothing harder to let go of than the wrong end of the stick once it is firmly grasped.
Old May 12, 2009, 04:17 PM
flieslikeabeagle is offline
Find More Posts by flieslikeabeagle
Got shenpa?
flieslikeabeagle's Avatar
Los Angeles
Joined May 2004
Let's see if some lubricant can make that stick a bit more slippery, making it easier to let go of any firmly grasped ends.
mfr02 - you are right that Kv alone cannot tell you what to expect from a motor, for many of the reasons you mention. That is why a minimum of three different motor constants are needed to model the motor mathematically, and predict actual performance under load. The other two constants are Rm (winding resistance) and Io (no-load current). More sophisticated models add more constants to give a little more accuracy.
Patmat is right too - the method he outlines is one of the ways to measure a motors Kv. And I agree with him that knowing the no-load rpm is quite useful by itself, especially when you factor in that a good rule of thumb is to load a motor till the rpm drops by 20% - 25% from the no-load rpm. This much load will push the motor to the point on its operating curve where it is running at roughly 70% - 80% efficiency, which is a good starting point.
I know absolutely nothing about scale boats, but I do know a little about electric motors.
-Flieslikeabeagle
flieslikeabeagle is offline Find More Posts by flieslikeabeagle
Discussion Help please - how to find info about this motor? morpheusdream Power Systems 9 Jan 19, 2008 08:50 PM
Discussion how to find a motor mount to change a motor for a plane nashiem Electric Motor Design and Construction 4 Aug 23, 2007 10:47 AM
Question Dual motor rpms how close is close enough? KenP Power Systems 7 May 24, 2007 07:16 AM
how to find motor thrust beep684 Power Systems 9 Sep 15, 2005 03:00 PM
How to find Amps on can motor andyg Power Systems 1 May 27, 2005 10:38 AM
