Old May 12, 2009, 04:15 AM
The Flying Kiwi
Mt Maunganui New Zealand
Joined Oct 2005
Originally Posted by Aerogance
Increased the wingspan to 75 feet, here is the almost completed fuselage
What The!!!???
Is that one of the X prize planes?
Ralph Walton is offline Find More Posts by Ralph Walton
Old May 12, 2009, 06:46 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Originally Posted by Ralph Walton
What The!!!???
Nice guess Ralph. That is the tail assembly from the VMS Eve.
Aerogance is offline Find More Posts by Aerogance
Old May 12, 2009, 06:50 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Full Size Plans
I printed a full scale plan to see exactly what I was getting in to. Check out the photo below showing an Opus in comparison.
Old May 12, 2009, 07:08 PM
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Set yourself aside $1000 (maybe more) to build those molds. They won't be cheap.
Looks good. I like the lines.
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old May 12, 2009, 10:59 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Adam
Yeah,
Good molds would be worth the price. First prototype(s) will be bagged wings, moulded tail and fuse. I plan to use a universal wing saddle so I can make several wings for one fuse/tail to test certain configurations. Moulded wing will come later when I have it dialed.
Aaron
Old May 12, 2009, 11:02 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
One big paper airplane...
I cut up the full-scale plans and mocked it up on the floor. The fuselage is massive and I am tempted to shorten it or make the wing much bigger. I really want to test this initial configuration before making any other modifications.
Old May 14, 2009, 02:37 AM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Smaller Fuse/Tail
Still refining tail surfaces. Decided to reduce fuselage size rather than increase wing for practical reasons.
Old May 14, 2009, 04:33 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Like the planform, should be able to get most of the spar at right angles to the fuz axis. However that nose still looks awfully short - might nead a lot of lead to balance it.
Watching with interest,
S
Shedofdread is offline Find More Posts by Shedofdread
Old May 14, 2009, 10:30 AM
Sydney
Joined Apr 2009
For what its worth I agree with Shedofdread re the nose length. I also like the lack of sweep in the wing shape, which will help to produce a stronger spar and less wing twist when it bends.
However I feel you may have shortened the Fuselage too much, although this will depend on what Tail Area and hence tail volume you have already.
Anyway good luck and keep going with this, it looks great in the 3d pics.
cheers
John
OZPAF is offline Find More Posts by OZPAF
Old May 14, 2009, 11:16 AM
Sydney
Joined Apr 2009
"However I feel you may have shortened the Fuselage too much, although this will depend on what Tail Area and hence tail volume you have already."
Can this part of my comments - what you show should work well. I have found that my efforts (F3B) give a fus length of close to half the wingspan for tail area of around a nominal 10% of the wing. I still believe however that the nose could be a bit longer with the same tail moment.
cheers
John
Old May 14, 2009, 01:04 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Excellent comments. I am recalc'ing the tail tonight and will be drawing a more accurate planform. The nose was to be 16 inches but in my haste came up a bit short of target. Fuse diameter is 3 inches at the wing area and will be 1.25 inches at the middle of the tail.
Old May 15, 2009, 12:44 AM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Short on time, but not in a rush
I "ran the numbers" again and will need a few days to redraw everything. Spent some time comparing airfoils again and it looks like the old-school, off-the-shelf, tried-and-tested, cold-war-era foil I plan to use for the bagged wing is much better than expected. I am still settling on the tail sections, if anyone has a suggestion I am all ears.
Old May 15, 2009, 09:21 AM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I'd try the Ayers tail sections he posted in the slope section, and just pick which ever section you need thickness wise for structural reasons.
Or just use a thin section, and put a spar in it.
Target,
Interested in the cold war era foil selected.
target is offline Find More Posts by target
Latest blog entry: Stork 4 Pro X-tail from...
Old May 15, 2009, 07:57 PM
Sydney
Joined Apr 2009
Have a look at HD8000 on XFOIL - 8% thick. This was designed by Hannes Delago of Aerianne F5E fame. It has a good lift slope - especially around Zero CL.
I was going to use it with an elevator on a F3B model.
Old May 15, 2009, 09:58 PM
Fly and smile
Aerogance's Avatar
USA
Joined Sep 2008
Thanks John, I will pull that section up tonight.
By the way, does anyone know what section is used on the wizard Compact' vertical tail? It is quite unusual looking compared to your typical moldie.
Aaron
