Old Jul 08, 2010, 11:28 PM
daboz is offline
Find More Posts by daboz
daboz's Avatar
HB cali
Joined Apr 2006
my first JW build has a large steel rod in the wing and has flown over 200 more than one time, 219mph max and I think is the third fastest JW in the world weighs in at 117oz has crashed pretty bad at Mars and still flys and looks great.
Chris
who builds his planes thinking they may crash... and some of them have
daboz is offline Find More Posts by daboz
Old Jul 09, 2010, 09:08 AM
rothlisburger is offline
Find More Posts by rothlisburger
the occasional flyer
rothlisburger's Avatar
Rexburg, ID
Joined Jul 2008
Originally Posted by Aerogance View Post
There is no question the rebar will fail before the joint to the foam does. Here is a photo of the bent rebar:
Wow. Now you'll have plenty of dihedral.
-David
rothlisburger is offline Find More Posts by rothlisburger
Old Jul 09, 2010, 11:29 PM
Aerogance is offline
Find More Posts by Aerogance
U down with EPP? Ya U know me!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I went ahead and tested the rebar joint to the foam. I put all my weight on the wing panel and then bent the rebar almost 180 degrees. The rebar pulled out of the foam in 2 places, but remained joined everywhere else. It was not easy to bend the rebar and any plane I have owned would have had some sort of failure at the level of force I was applying. I still think rebar could be the secret ingredient in a heavy and fast foam core wing, but a single spar design may have its limits.
I was at HD this evening and took a look at other common materials they stock. The stiffest material I could find was rigid conduit and these thin-wall steel handled carpet mops. If you wanted to save some weight, the carpet mop handle would be great. The rigid conduit was much heavier. Rebar was the heaviest since it is solid. The smallest diameter rebar I could find is 3/8". 1/4" would have been perfect for a double rod spar.
Aerogance is offline Find More Posts by Aerogance
Old Jul 10, 2010, 07:55 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Get any odd looks from the store staff?
"Hey, there's a guy over there bending all the mop handles - SECURITY!"
Keep up the good work and the interesting posts,
S
Shedofdread is offline Find More Posts by Shedofdread
Old Jul 10, 2010, 09:10 AM
Rexburg, ID
Joined Jul 2008
You could still do a double spar near the root, and either drop one of them before you reach the tip, or overlap them near the tip (depending on how much weight you want). The sketch is a front view of the wing, with the top spar going all the way to the tip.
The advantage of doing the double spar near the root is that instead of loading the rebar in bending (not too strong), you're loading the rebar more like a truss. The top one will be in compression, and the bottom in tension. Truss loading is inherently more efficient than bending.
-David
Old Jul 10, 2010, 10:15 AM
Aerogance's Avatar
Joined Sep 2008
S
Are you kidding, you can spend days in a HD without seeing a single employee
Old Jul 10, 2010, 10:27 AM
Aerogance's Avatar
Joined Sep 2008
-David
I will give that a try. It resembles the JW spar arrangement where the bottom one is shorter. Getting the bottom one in will be the trick since it is bent.
Old Jul 10, 2010, 04:44 PM
Rexburg, ID
Joined Jul 2008
just cut a U channel, and fill it afterward.
-David
Old Jul 10, 2010, 06:26 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
How about using square tubing, with a solid joiner for a two piece wing????
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Jul 10, 2010, 06:40 PM
Alex May is offline
Find More Posts by Alex May
I'd Rather Fly
Alex May's Avatar
United States, CA, San Diego
Joined Feb 2008
If you cut a U channel to install the spar assembly that rothlisburger suggested, that would allow you to potentially weld the two pieces of rebar together to at the outboard points make a stronger connection for a true truss design. Maybe add a vertical cross member in the center between the top and bottom members.
Alex May is offline Find More Posts by Alex May
Old Jul 10, 2010, 07:00 PM
Aerogance's Avatar
Joined Sep 2008
I was thinking about th welding option and it could be a cheap and quick way to add a ton of stiffness. Good idea.
Old Jul 11, 2010, 11:15 AM
Alex May is offline
I'd Rather Fly
Alex May's Avatar
Joined Feb 2008
Here's an illustration of what I'm talking about, with the red lines being welds. This is a front view of the spar.
Old Jul 13, 2010, 08:46 AM
Derbyshire, UK
Joined Aug 2008
May I suggest brazing the parts together? Welding does rather change the properties of the steel. You'd need to heat treat the assembly post welding to recover the properties.
Also, why not get hold of a press brake and bend either a [ section or a Z (but with the '/' part vertical). You could use a punch to take out material from the web region. Many fabrication shops would do work like this for quite small amounts. Some have CNC press brakes if you want to be really posh.
S
Old Jul 25, 2010, 12:15 AM
flyboyjimi is offline
Find More Posts by flyboyjimi
The sky is my playground
flyboyjimi's Avatar
Near the Ocean in Hunt. Beach Calif.
Joined Apr 2006
:/ oo';
flyboyjimi is offline Find More Posts by flyboyjimi
Last edited by flyboyjimi; Jul 25, 2010 at 12:43 AM. Reason: Not within the seriousness of the Thread
Old Jul 25, 2010, 12:17 AM
Aerogance's Avatar
Joined Sep 2008
S
I imagine that it wouldn't be expensive to have some sheet metal formed on a brake. I also thought that using 2 C-channels interlocked female-to-female with a tapered plywood shear inside the crotches to follow wing thickness could be a quick and dirty way to get a heavy metal spar going.
