Old Apr 16, 2009, 07:51 PM
Jubei is offline
Find More Posts by Jubei
Woodridge, IL
Joined Apr 2009
Help!
Prop upgrade for Apache 24?
Hello, I am new to RC boats and recently aquired the Pro Boat Apache 24. I'm already thinking of upgrading to a Formula Fastech, but I'd still like to make the Apache as fast as I can without any major modifications in the meatime. I'm wondering if there is a prop upgrade anyone can reccomed for the Apache 24.
While I'm at it, can anyone suggest a prop upgrade for the Formula Fastech? I need speed.
Jubei is offline Find More Posts by Jubei
Old Apr 20, 2009, 12:50 PM
Midwestracer is offline
Find More Posts by Midwestracer
Lake Saint Louis MO
Joined Apr 2009
Are you planning on running all the factory gear but just switching the prop?
Midwestracer is offline Find More Posts by Midwestracer
Old Apr 20, 2009, 07:55 PM
Jubei is offline
Woodridge, IL
Joined Apr 2009
I was. I read somewhere that switching the prop on a SV27 gave it another 10 mph. I'm sure starting with a lower top speed (according to my eyeball, my Apache only does 15-20mph right now) I wouldn't see that kind of difference, but I figured it'd be worth a look if a $15 prop would add some speed.
BTW - I just ordered the Formula Fastech and 2 - Losi 5000mah lipos and I can't wait to get it.
Old Apr 20, 2009, 08:43 PM
Lake Saint Louis MO
Joined Apr 2009
Well that should be a little faster than the Apache .
Old Feb 26, 2010, 03:52 PM
millerdk is offline
Find More Posts by millerdk
Joined Feb 2010
Prop Upgrade
Have been fooling with Shockwave 26 witch has same components as Apache and I am beginning to think it may be overpropped from the manufacturer. I may still be having trouble with getting the trim set right. It is just as fast with smaller prop. My run time is very poor too. What is your run time on what kind of batteries? Good luck with your Apache.
millerdk is offline Find More Posts by millerdk
Old Feb 27, 2010, 08:30 AM
Norman22 is offline
Find More Posts by Norman22
Norman22's Avatar
North Carolina
Joined Jan 2010
Apache 24 prop
Hi, I use a Venom EKOS 36mm x 1.4mm pitch on my Apache. I use a small
brass tubing sleeve to make it fit. It works super. Attached photo from
Tower Hobbies. Regards
Norman
Norman22 is offline Find More Posts by Norman22
Old Feb 27, 2010, 08:32 AM
Norman22 is offline
Norman22's Avatar
North Carolina
Joined Jan 2010
Apache Prop
Here is the photo
Discussion Prop upgrade for PZ Cessna 210 and Citabria MikeHicks Power Systems 5 May 06, 2009 02:50 PM
Discussion Prop upgrade for Citabria MikeHicks Electric Plane Talk 2 Mar 26, 2009 12:25 AM
prop upgrade for my OverLord alien Foamies (Kits) 3 Apr 05, 2004 11:15 AM
Question re: motor / prop / battery for Apache Tempest Sport Planes 7 Aug 08, 2002 02:03 AM
Master Airscrew 5.5x4.5 prop upgrade for Zagi 400X 177ichael Foamies (Kits) 9 Jun 19, 2001 10:16 AM
