Nice! Very impressive
Given that extra sail area up front, may I suggest that you enlarge the vertical stab. In particular make it taller so that it clears the added height of the motor. I can see that this will allow you to fit a bigger prop. With the longer tail boom, you'll probably have more longtitudinal stability. What other advantages do you expect with your enlargement? While you're at it, did you think of using Cularis wings? I'm looking forward to your maiden...I'm sure we'll all learn from your build. Thank you. |
Latest blog entry: Travel Quad
Big-Big Easystar gets its color
Here I am again.
I made an thin polyester tube (30 mm ) to put the 1900KV outrunner in. I enlarged the vertical stab, but only the moving part. (what is the word for that?) I put the servos and the electronics in. I used the first hidden compartment in the hull for the receiver and the place where normally the servos are for the giro on the ailerons. (Idea from SCRTSQRL) The servos are more to the rear now, so I could still use the original plastic/metal servo links (=link between the servo and the rudders, what is the word?) I painted the plane in candy vivid colours. ( I live in a very green swamp and lost planes before so I need colours that are very visible in a green environment) But now I have to buy dark sunglasses to fly this plane ![]() I have had a problem with the paint, it don’t stick very well on the Elapor of the plane. Elapor feels a bid greasy but it is not.Anyone have a suggestion for that? Well here are pictures of the Big_Big EasyStar and the more "normal one" so you can compare them. Soon the maiden flight take place. Wish me luck. And keep sugestions coming. Frans |
clever mods you came up with. Regarding the "technical" terms: Moving part of the vertical fin = rudder Link between servo and rudder/aileron etc= rod The elapor feels greasy because the factory uses light oil in the molds to prevent the parts from sticking to the molds. Multiplex sells a primer that can be used before painting the elapor: http://www.natterer-modellbau.de/pro...P--100ml-.html |
OK like Connexxion said about the oily substance used at the factory is true but if you are going to paint, I recommend you rub down the plane real good with either methyl hydrate (or alcohol stove fuel) OR acetone to remove the oily film. Then paint! And yes since you are in Europe go with the Multiplex paint other wise Krylon paint for plastic from any hardware store will do.
really nice and clever job, my compliments! In the first picture it seems that the big one has a little banana shape, i.e. the fuselage is warped to the left (to the right looking from the nose)... Hope this is just an optical illusion... |
That is a really brilliant solution to carrying a HD Camera. I would put the FPV camera on the "step" forward of the wing and the HD Camera in the cockpit. You might have to carry the battery externally as I have, just under the wings, by the CG to balance properly. No need to dig into the faom and compromise the structure. The BWEZ* is perfectly happy with the batteries mounted this way. I think the Cularis wings may be more complicated because of the way it mounts onto that fuse...Forget that suggestion for now... One suggestion: Do not maiden w/ gyros...ensure the plane performs well with out gyros first... Keep it up. We're waiting to see the maiden video! Thanks for sharing. I hope MULTIPLEX is watching! |
| Thread Tools | |
| ESC too big - bad idea | digsy | Beginner Training Area (Aircraft-Electric) | 10 | Oct 27, 2005 07:35 PM |
| SMALL QUESTION for BIG IDEA. | Fon | Foamies (Kits) | 18 | Mar 26, 2004 09:55 PM |
| BIG 4Star idea | CAFplanekid | Sport Planes | 4 | Dec 16, 2003 04:52 PM |
