Old Mar 30, 2003, 01:35 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
What makes a plane STOL?
I was working on my honeydo list around the house this morning since it is raing and snowing here in NC and I got to windering what makes an aircraft suitable for Short Take Off and Landing. More power? More flaps? More wing area? All of the above? Thinking about a plane to take off from normal grass in very short runway lengths. Just one of those things that make you go Hmmm!
Mike C is offline Find More Posts by Mike C
Old Mar 30, 2003, 04:31 PM
AirVenture is offline
Find More Posts by AirVenture
He wasn't always evil
AirVenture's Avatar
SW Wisconsin
Joined Jul 2001
http://www.cubcrafters.com/cc/products.asp
Here's an idea about what is done on full scale aircraft. Also something that wasn't mentioned was the prop. I think with these cubs you can buy either a climb or a cruise prop. More advanced planes you are able to control the pitch of the prop.
Like you said, with model airplanes, just add wing area, reduce weight, use a more efficient airfoil, and so on and or forth.
AirVenture is offline Find More Posts by AirVenture
Old Mar 30, 2003, 04:37 PM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
STOL definition
It generally means that an airplane can depart after an unusually short ground run at a steep enough angle to clear the encroaching trees. And get back into the same place it took off from. Lots of aircraft can get off impressively short, but cannot safely generate an approach angle/rate of descent that allows them back into their departure location. Whether it means particular performance numbers, I do not know.
PeterH is offline Find More Posts by PeterH
Old Mar 30, 2003, 06:43 PM
BooBoo is offline
Find More Posts by BooBoo
Atlanta Metro Area
Joined Jan 2003
Usually you will find that full scale aircraft equipped for STOL will have turned down wing tips. Some aircraft manufacturers offer a kit to install on the wings. As an example, take a look at the GWS E-Starter ARF. It may be a bit exaggerated but it simulates a STOL equipped plane. It doesn't make that much difference on a model but for a full scale plane it can make a lot of difference. Had a friend that put a STOL kit on his Cherokee Six so he could land and take off from a unregistered short private grass strip behind his house (on a farm). STOL stands for "Short Takeoff or Landing"
BooBoo is offline Find More Posts by BooBoo
Old Mar 30, 2003, 09:33 PM
Mike C is offline
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
Those drooping wingtips might not offer any STOL advantage to a model airplane but they would look cool.
AirVenture: Neat website! I am always shocked when I see the price of real planes. That super cub looks like it is on Steroids! Sweet ride.
Old Mar 31, 2003, 02:12 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
For interest's sake in this thread, I added a relatively complete STOL kit to a Mountain Models Cessna 180. It's a 36" 10 oz park flyer. The flaps are scale and functional. The ailerons also droop slightly with flap operation. The droop tips are hand carved and there is a leading edge cuff to the wing. The cuff effect is quite noticable due to increasing the camber of the wing but the tips are all-but-useless. I had one bump off (they're held on with magnets) on a takeoff roll and noticed no changes whatsoever in the flying characteristics of the plane.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Mar 31, 2003, 02:51 AM
Patrick Plawner is offline
Find More Posts by Patrick Plawner
Patrick Plawner's Avatar
Joined Sep 2001
Speak about a beautiful plane !!!
Great picture, difficult to see it is not a real big plane.
Patrick Plawner is offline Find More Posts by Patrick Plawner
Old Mar 31, 2003, 04:09 AM
flyfalcons is offline
Find More Posts by flyfalcons
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
Mike, to answer your question, all of the above and more. STOL planes have lots of wing/flap/lift, which usually also increases the drag, and a sick thrust to weight ratio. Notice I said thrust, not power. Power to weight will give you a better climb rate, while thrust to weight gives you a better climb angle. STOL planes like to have a good climb angle. They are a real kick to fly.
flyfalcons is offline Find More Posts by flyfalcons
Old Mar 31, 2003, 04:55 AM
Doc Watson is offline
Find More Posts by Doc Watson
Doc Watson's Avatar
UK
Joined Mar 2000
This thing will STOVL, it must do it says it on the fin!!!!!!
Doc
Doc Watson is offline Find More Posts by Doc Watson
Old Mar 31, 2003, 06:30 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
The landing part of STOL is much harder than the take off part. Consider any fun-fly. Adding flaps only helps a little in reducing landing speed and increasing the approach angle. Leading edge slots or flaps are also required full size, though I don't know how well they would work on a model.
Pete Russell (RCM&E columnist) designed some gas STOL models with LE slots which he converted to electric and flew out of his garden (back yard) 25+ years ago.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Mar 31, 2003, 06:31 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
There's a well-known UK designer called Peter Russell who drew up a model called the "STOL" in the 70s, for flying in his back garden. It was IC (of course), for engines around .20-.25 IIRC. Very light, with flaps and LE slats. It was updated several times, with the plans being published in (I think) RCM&E. A quick Google search found the pic. below, which I think is a "Mk 3". I'm sure the plan is still available, it would make a great electric conversion!
Bill Glover is offline Find More Posts by Bill Glover
Old Mar 31, 2003, 06:41 AM
HyperFlight Support
Joined Feb 2001
Thanks for amplification and the illustration Bill. I also Googled but didn't find anything.
Neil.
Joined Nov 2000
Neil - great minds etc. !
I had a large photo plane in the 80s that was pretty STOL. ST 90 turning a 14x6, flapperons, and separate TE airbrakes. So you could dial in any combination of lift, or drag, or both ... with excellent power to weight (even carrying 4lbs of camera gear) for rapid acceleration and steep climbout. 'Cleaned up' it penetrated well (having a thinnish sem-symmetrical section) and was fully aerobatic. So it could handle most weather conditions, unlike the 'old timer' type models which many people were using for aerial photography at the time.
I also flew it with a servo-operated 8mm cine camera on the side of the fus., I have some footage (somewhere) including loops/spins/flick rolls/touch & gos, even a lowish inverted pass! Rather stomach-churning, and before that exercise I thought I flew pretty smoothly
Old Mar 31, 2003, 12:56 PM
flyfalcons's Avatar
Bonney Lake, WA
Joined Jan 2002
Neil.
While the LE devices help, they are certainly not required in full scale for short landings. Cubs and Cessnas don't have them and don't need them. Yes you can purchase a modified LE for a Cessna that is drooped just a little but most of them don't have it and can land in a fairly short distance. In the Beaver we can use flaps that can depoly nearly 75 degrees, basically turning them into a barn door. I rarely use full flaps for landing, especially with passengers, because the approach angle is uncomfortably steep. You are literally against your straps staring at the ground when approaching with full flaps. Once on the water the Beaver can be stopped in 300 feet or less, depending on the winds.
Old Apr 01, 2003, 04:36 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Re: What makes a plane STOL?
Reversing props really help on landing Other than that, the methods generally fall under camber changing. If you have a high-camber, high-drag wing for landing it requires a long takeoff roll and is very slow in the air.
Andy Lennon's book and his articles in RCM and MAN provide all kinds of details for model STOL designs.
http://www.modelairplanenews.com/pla...onth_robin.asp
Rick.
rpage53 is offline Find More Posts by rpage53
Discussion What makes a plane a sloper?? sirdirk007 Slope 56 Jan 07, 2007 07:16 PM
What makes a plane go fast? abbydog301 Electric Plane Talk 20 Jan 26, 2005 08:15 AM
what makes a faster plane? furnaceman Power Systems 8 May 27, 2004 06:03 AM
What makes a plane a 3d plane and not just a aerobatic? soholingo Sport Planes 2 Mar 12, 2002 09:38 PM
what is cheapest plane to get???? tbbd Parkflyers 2 Jun 25, 2001 04:52 PM
