Old Mar 30, 2003, 01:02 PM
J R Purcell is offline
Find More Posts by J R Purcell
Longview, Washington, USA
Joined Sep 2000
Slightly Confused: Triton and Li-Po Charging
I see in the Triton manual that it states Li-Po batteries should be charged at 3.6 volts per cell. I saw a post here that said it should be set @ 3.7 volt per cell to get a full charge of 4.2 volts per cell. Which is right?
It also seems very confusing that you set charger @ 3.6 - 3.7 volts per cell to get 4.1 Ė 4.2 volts at the end!!! I can see how people pouch batteries if they are not very careful and set the parameters properly. As part of the Tritonís menu I donít see why they did not ask for number of cells instead of voltage when setting Li-Po charge.
Thanks in advance
John
J R Purcell is offline Find More Posts by J R Purcell
Old Mar 30, 2003, 02:30 PM
Danny Troy is offline
Find More Posts by Danny Troy
Danny Troy's Avatar
Westchester County, NY, USA
Joined Jun 2000
For Li-Ion use the 3.6 setting. For Lipolys use the 3.7 setting.
I've been using the Tritons for a few weeks now quite a bit, and despite the lacking manual I'm getting pretty familiar with it.
All in all it's a solid charger, and it's well protected from high and low voltage inputs. I tried using a 24 volt input, forgetting what the manual said was the max voltage input, and the charger was nice enough to let me know the input voltage was incorrect.
As far as the difference between the 3.6 and the 3.7 setting, I don't think there's much of a difference.
I use my small Wes Technik lithium chargers, which charge at 3.6 volts per cell, and when I put the Lipoly on the Triton to top it off, it shows full charge in about a minute or so. I guess this shows there's really not a lot of difference between the two settings.
This is for a 1020 Lipoly pack.
Danny Troy is offline Find More Posts by Danny Troy
Question Help needed...Triton and li-po questions. omega blood Batteries and Chargers 0 May 14, 2004 11:28 PM
Li-Po charging question zbrubaker Batteries and Chargers 3 Apr 24, 2004 09:37 PM
Nomex Fire Retardant Sox for Li-Po Charging Synthetic Batteries and Chargers 4 Feb 03, 2004 07:43 AM
Li-Po charging question bztguy Batteries and Chargers 0 Jan 01, 2004 07:58 PM
Li-Po charging talonxracer Batteries and Chargers 3 Sep 26, 2003 07:18 AM
