This thread is privately moderated by c0dem0nkey, who may elect to delete unwanted replies.
Old Apr 14, 2009, 01:11 PM
c0dem0nkey is offline
Find More Posts by c0dem0nkey
I want it to go fast...
c0dem0nkey's Avatar
United States, OR, Bend
Joined Sep 2006
Build Log
Shredder Madness!
I found a Shredder kit..I'm stoked...I have no idea where to start
Questions:
1. How do I join the wing pieces...balsa braces or hard wood. How far in do I put them in each piece. Why did double taps have two..one large one skinny?
2. I have some winchdoc blingeron...can and should I use it. It would require the cores be modified.
3. Should I sheet it with 1/16 balsa..like the plans say or use 1/64th hard wood..as seen in double taps sale.
4. The plans show some dihedral in the first part of the wing...how is this achieved? Hopefully be the way the cores were drilled.
5. Should the fuse be reinforced in any way?
6. The tail has the holes already drilled...hopefully everything aligns to 0degrees. Personally I have no idea how to make sure of this.
The fuse needs some clean up work done to it so...I guess I'll start there since that is self explained.
c0dem0nkey is offline Find More Posts by c0dem0nkey
