Old Apr 13, 2009, 06:35 AM
daydreamjay is offline
Find More Posts by daydreamjay
Joined Apr 2009
Charge Rate For Mini Super Cub Battery
Hi,
I have a charger suitable for the mini super cub other than the one supplied. However I need to program in what charge rate I use and I don't know the safe limit. I want to charge it as quickly as possible. The battery is a 7.4V 300mah. What MA setting do I put on my digital charger? Thanks in advance.
daydreamjay is offline Find More Posts by daydreamjay
Old Apr 13, 2009, 08:09 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
7.4v 300mah lipo recommended charge rate of 1C would be .3A
If charged & balanced with proper lipo charger & balancer then you can charge up too 2C charge rate that would equal .6A. But you do this at you're own discretion.
freechip is offline Find More Posts by freechip
Old Apr 13, 2009, 09:11 AM
R/C_Addict is offline
Find More Posts by R/C_Addict
That's me.
R/C_Addict's Avatar
San Francisco Area, CA
Manufacturers never say to charge past 1C. I've seen only a couple 2C lipos.
daydreamjay: I would charge it at .3A. It will take 45 minutes to an hour to charge. That's about the fastest most lipos will charge.
R/C_Addict is offline Find More Posts by R/C_Addict
Old Apr 13, 2009, 11:06 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
If it is modern chemistry you can generally charge at 2-3C (.6-.9a) with little risk of life reduction. In fact most lipos today are charged at 3-4c (Silverlit). If fast charging is really your highest priority then you can charge at even more current but expect fewer cycles.
Rule of thumb is charge at highest rate that don't heat battery.
Originally Posted by daydreamjay
Hi,
rich smith is offline Find More Posts by rich smith
Old Apr 13, 2009, 12:58 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
^2C will heat a lot of lipos up. I've only seen a dozen or so brands that can charge at 2C. Everything else is 1C.
daydream, to find your maximum charge current, you simply take the packs MAH rating, and move the decimal value 3 places to the left, so a 300 mah battery is charged at .3 amps. 1000 mah at 1.0amps, 1500mah at 1.5 amps ect. ect. This applies to basically all batteries, although there is a short break in period for NiXX batteries, that you should charge at a lower current.
Xpress.. is offline Find More Posts by Xpress..
Old Apr 13, 2009, 01:59 PM
rich smith's Avatar
Joined Dec 2006
[QUOTE=Xpress..]^2C will heat a lot of lipos up. I've only seen a dozen or so brands that can charge at 2C. Everything else is 1C.
QUOTE]
You may be right if we are talking about NiMh. I was referring to lipo which is only ones I actually tested.
Old Apr 13, 2009, 02:27 PM
turbored21 is offline
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
the mini super cub battery is cheap chemistry... not a good battery its ok for the mini cub no doubt.. however.. charge it at .3A you'll save yourself alot of heartache and that 15$ replacement fee
turbored21 is offline Find More Posts by turbored21
Old Apr 13, 2009, 02:58 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
In my case, I've charged a few lipos at 2c justto see if I could do it, and save myself time. One was a hobby city lipo, one was an impulse 2 cell lipo, and the other was 300mah lipo I found. All (not sure about the 300 mah) were less than a year old. All got pretty warm at 2C. Not ALL lipos (even modern ones) can charge at 2C. For me, I like to keep my batteries for as long as possbiel, so 1C fo me.
Old Apr 14, 2009, 05:50 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
& you should never say never, because my over 1 year old FlightPower EVOLITE V2 2s & 3s LIpo have (CAN BE FAST CHARGE UP TO 2C) all on the manufacturing label on the pack them self. I have charge them at 2C with proper charger & balancer and have yet to see any side effect.
PS: I am more likely to kill my pack by abusing them (going below recommended voltage) then by charging them at 2c.
HERE's what THEY HAVE TO SAY ABOUT IT.
http://www.flightpower.ca/b2b/cart.p...category_id=49
Fast charge rates up to 2C approved in conjunction with balancing, the FlightPower V-Balance is ideally suited.
Old Apr 14, 2009, 11:32 AM
rich smith's Avatar
Joined Dec 2006
As a test I have charged Loong, Zippy, and Rhino up to 4c with no overheating. Only slight reduction in lifetime. Maybe Xpress is spending too much time charging out in the sun.
I've concluded it is mostly DISCHARGE abuse that hurts lipos. They suffer 10x more increase in temperature. RCG is filled with guys wondering why their batteries puff when they are using 3s with props that are too big for even 2s.
charge rate for hitec 600mah rx battery? thrasher Slope 26 Jun 22, 2005 09:07 PM
Charge rate for pb battery strong Batteries and Chargers 1 Apr 27, 2005 10:56 AM
Battery charge rate for Dragon Fly Maxcat Micro Helis 4 Jun 27, 2004 06:46 PM
