This thread is privately moderated by Loose_Screws, who may elect to delete unwanted replies.
Old Apr 12, 2009, 11:40 AM
Loose_Screws is offline
Find More Posts by Loose_Screws
In training...
Alabaster, AL
Joined Mar 2009
Mini-HowTo
Common wiring diagram for brushless setup
As requested, attached is a common wiring diagram for brushless setups. Connectors are not displayed, but you will commonly use bullet style connectors for the motor<--->ESC. I use Dean's connectors between battery<--->ESC, but there are plenty of options. Just ensure the connectors you use will carry the amperage. The servo leads carry minimal voltage (3 volts typically), including the lead shown between the ESC<--->RX.
CAUTION!!! When using a BEC, always test your RX before connecting the motor to ESC. Most ESC's have built in protection and will not 'ARM' themselves without input from the RX, but do you really want to risk your fingers?
To test your RX...
1) Connect all components with exception of motor and battery
2) Double check you have everything connected as shown in diagram
3) Power on your TX (transmitter/radio)
4) Connect the battery
...If the servos respond to TX stick movements, your system is functioning properly. You can now safely connect the motor.
1) Disconnect battery
2) Connect motor
3) Power on TX
4) Connect battery
Good luck!
Loose_Screws is offline Find More Posts by Loose_Screws
Old Apr 11, 2012, 07:19 PM
T56Engr is offline
Find More Posts by T56Engr
Joined Mar 2012
Thanks!
T56Engr is offline Find More Posts by T56Engr
Wiring diagram for electric sailplane fellrunner Electric Sailplanes 2 May 07, 2003 09:58 AM
Wiring harness for brushless TwinJet Dunc Foamies (Kits) 2 Jan 19, 2003 04:22 AM
