Old Apr 12, 2009, 12:51 AM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
Mini-HowTo
Multi-mode Winch
Here's a three mode winch: Reel position 1. engaged to raise anchor or haul towline, 2. freewheeling to drop anchor or release towline, and 3. lock position (if desired).
Requires 1 servo and a Tx channel that can place the servo into three positions (only two if the "lock" option is not used.)
Pictures of my tug winch and construction sketches attached.
Most assembly with hot glue.
Shuttle bar and its support base made with 1/4" thick delrin.
The small cam bar is necessary to compensate for the arc of the servo arm, since the shuttle bar must slide straight back-and-forth along the servo body.
Works really well - I was surprised....
EDIT 1 - Winch drive mechanism drawing has detail of shuttle bar construction added. The bar is basically suspended from the servo arm and swings to slide the shuttle bar and reel to desired position.
EDIT 2 - For automatic stop:
Put a normally closed microswitch at a point that the anchor head or such will activate and open the microswitch when the anchor is fully home. That will cut out the motor. With this system, your control servo is still active though.
As soon as you switch to freewheel, the anchor will drop and the "anchor home" microswitch will be deactivated (closed), and the motor will be again ready to pull when you go back to the Engaged position. See added sketch.
DanL is offline Find More Posts by DanL
Old Apr 12, 2009, 01:11 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Very nice.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Apr 12, 2009, 07:54 AM
A-37 is offline
Find More Posts by A-37
A-37's Avatar
Cortland OH
Joined Dec 2007
Smart concept. Well designed/built. Professionally presented. And it works!
Good job.
Ed
A-37 is offline Find More Posts by A-37
Old Apr 12, 2009, 09:43 AM
joe31hat is offline
Find More Posts by joe31hat
joe31hat's Avatar
USA, MI, Troy
Joined Jul 2007
Very Interesting!!! Thanks for putting it into 'MINI HOW TO' for us newbies.
Again very cool! Nice job!
Joe
joe31hat is offline Find More Posts by joe31hat
Old Apr 12, 2009, 10:13 AM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Wow! Fantastic! Thank you!
Kmot is offline Find More Posts by Kmot
Old Apr 12, 2009, 01:13 PM
DanL is offline
DanL's Avatar
See Edits
Based on questions received, see edits to Post#1.
Old Apr 12, 2009, 01:30 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
very very nice but mot nearly complicated enough! yes I am being sarcastic that is really great have to remember that one! I have seen verious designs for a windlass but none of them have a workable freewheel feature to be able to drop the anchor. Another thought is that you could use the same winch setup to raise and lower sails too!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Apr 04, 2010, 09:16 AM
onlinegamesnz is offline
Find More Posts by onlinegamesnz
New Zealand
Joined Jan 2010
Dude that's insane! Design me a gib roller reefer. Please!
onlinegamesnz is offline Find More Posts by onlinegamesnz
Old Apr 04, 2010, 08:31 PM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
Foo
Yes me as well ..theres some posabilities there ..Im considering it for Darby..very considering it
one wall I hit though Foo is trying to get a Scale anchor thats heavy enough to drag the scale chain up and through to fall .. A guy almost wants to put a roller on ball bearings to reduce the friction where the chain exits the hull..a fair-lead of sorts ..Is it called a Hawse..that hole ..where the chain exits ..
more coffee is offline Find More Posts by more coffee
Old Apr 05, 2010, 02:29 AM
Joined Sep 2008
If you check my history on this board you will find out that my first post(s) were on a DD thread about the proper terminology for ground gear. LOL! You made my day! I had a thought previously about casting the flukes from lead and using a lighter (3-d printed GRP maybe?) material for the stock. A pin through the flukes and the stock would enable the flukes to swivel so the anchor could be stowed properly.
Foo
P.S. The chain is stowed in the chain locker, it travels to the deck via the chain pipe, normally around the anchor windlass (and it's wildcat) then across the deck, and out the Hawse pipe......
Old Apr 05, 2010, 06:33 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
cast it in depleted uranium...
patmat2350 is offline Find More Posts by patmat2350
Old Apr 05, 2010, 10:08 AM
Adam66 is offline
Find More Posts by Adam66
Netherlands
Joined May 2004
This is a nice drawing, but it won't work.
At first the placing and setting of the microswitch are very critical.
In this setting its just a guess if the switch will always works
At second because the anchorchain is always wet, this isn't an ideal place for a microswitch because these microswitches don't like water
This is how I made it on my Smit Kamara.
No need for a servo, juist a switch for running the motor clockwise or counterclockwise.
When the anchor is pulled in its pocket (or when it got caught underwater) the strain in the anchorchain lifts up the complete winch and a microswitch switch off the motor. Therefore its not possible for the motor to keep running when in "overload"
When lowering the anchor the motor turns the otherway around, with a lever the drum becomes disengaged and the anchor falls freely.
Ankerlier Smit Kamara 1 (0 min 7 sec)
Ankerkluis Smit Kamara (0 min 7 sec)
Ankerlier Smit Kamara 2 (0 min 11 sec)
Everything is going a bit fast due to the speed of You Tube and because the anchor is falling in free air, and not in water.
The idea came from this site.
It took me quite a while to figure out how it works, but I adapted the principle of their winch for a heavier version for the Smit Kamara which would be fully functional
Adam66 is offline Find More Posts by Adam66
Old Apr 05, 2010, 12:13 PM
THE HORSEMAN is offline
Find More Posts by THE HORSEMAN
THE HORSEMAN's Avatar
Joined Aug 2008
Been watching intently don't want to muddy the thread to much but would be nice to see a good wright up on the system finished out.
great stuff lots of possibilities !!!! Thanks to all for taking the time.
THE HORSEMAN is offline Find More Posts by THE HORSEMAN
Old Apr 05, 2010, 01:47 PM
Old No7 is offline
Find More Posts by Old No7
Old No7's Avatar
Midcoast Maine
Joined Jun 2009
Wow, that's cool!
But as a long-time bass fisherman... I'd be concerned about tangled lines or chains when in the "free spool" mode -- as you should see some of the messes I've made with my reels!!!
Not to be critical... But some type of tension device or speed limiter might be needed to prevent the lower wraps of line from over-running the top ones... Especially when the anchor stops, but there's still line coming off the spool.
Good luck!
Old No7
Old No7 is offline Find More Posts by Old No7
Old Apr 05, 2010, 04:18 PM
Cheif Bottlewasher
Joined Sep 2005
Where did you get that righteous anchor chain!!
I do like this set up..
Just another example of why the Admiralty should release the funds for some shop tools ..lathe and milling machine ..
Multi-mode E/sailplane Tx? bmwbob Thermal 1 Apr 21, 2002 11:45 AM
Multi-mode E/sailplane Tx? bmwbob Electric Sailplanes 10 Apr 15, 2002 08:18 AM
