Old Apr 15, 2009, 01:51 AM
masson74 is offline
Find More Posts by masson74
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
wow joe you sure make it look easy
masson74 is offline Find More Posts by masson74
Old Apr 15, 2009, 08:46 AM
MattyB is offline
Find More Posts by MattyB
Taranis Tyro...
MattyB's Avatar
United Kingdom, England, Hitchin
Joined Jan 2004
I have the plans somewhere for the Paul Janssens Mk24 Spit (maybe one day I'll get round to building it!)...
From memory, he gets round the issues you've been talking about by cutting two panels (with different tapers) per wing half, joining them, then sanding away the smaller amount of excess foam at the tip and panel joins. Slightly more work at the panel cutting stage, but it should give a more accurate airfoil overall. Certainly if I was going for a 1/4 scale version as you are in the long term, I'd investigate this option. What you've got still looks awesome though!
MattyB is offline Find More Posts by MattyB
Old Apr 15, 2009, 10:46 AM
joemach1 is offline
Find More Posts by joemach1
Ramona Ca.
Joined Feb 2009
MattyB, I know there is a way to cut cores with the eliptical tips. 1/4 scale needs to be cut not shaped for sure. Small planes you can get away with a lot. thanks for the kind words.
joemach1 is offline Find More Posts by joemach1
Old Apr 15, 2009, 11:20 AM
RAFster is online now
Find More Posts by RAFster
United States, TN, Blountville
Joined Oct 2002
Very nice build joemach1!
Where did you modify things from scale outlines to make it a better slope bird?
Thanks!
David
RAFster is online now Find More Posts by RAFster
Old Apr 15, 2009, 09:59 PM
joemach1 is offline
Ramona Ca.
Joined Feb 2009
David, I dont think you need to modify this plane but I went with a shorter fuse that a 60" wing would have and higher aspect on the wings some. I made the wing fillets today and man what a difference that made. This Spity is looking SWEET if I dont say so myself. I kind of want to do a real scale 60" but this one is pretty close for me building it. I took some pics today and will load them tomm.
Old Apr 15, 2009, 10:21 PM
Chief High Horse is offline
Find More Posts by Chief High Horse
Chief High Horse's Avatar
Orange County, CA
Wow!
Some day, I hope to be able to make it look easy, not even that easy, just a little easy.
Chief High Horse is offline Find More Posts by Chief High Horse
Old Apr 16, 2009, 06:15 AM
Datman is offline
Find More Posts by Datman
New Zealand
Joined Sep 2006
It doesnt get much faster then this!! Amazing
I have read so many build threads now, I am almost getting comfortable to do a build myself. Gotta get my foam cutter going first!!
thanks for the info Joe.
Ian
(almost gleaned enough info for a scratch build)
Datman is offline Find More Posts by Datman
Old Apr 17, 2009, 01:04 AM
joemach1 is offline
Ramona Ca.
Joined Feb 2009
More Progress on the Spitfire
Sneaking up on a paint job
Old Apr 17, 2009, 01:22 AM
TFLG is online now
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Hmm, you put some icing on that cake nice!
TFLG is online now Find More Posts by TFLG
Old Apr 17, 2009, 01:33 AM
joemach1 is offline
Ramona Ca.
Joined Feb 2009
more pix
Well the project is almost coming to the end which means paint job. I have a couple of pics that looks awsome if I could just pull it off. I might post a few of the paint job as it happen or you could just see it at the PSS FEST 09.
Old Apr 17, 2009, 02:23 AM
joemach1 is offline
Ramona Ca.
Joined Feb 2009
Paint schemes for the Spitfire
Which one do you think would look the best or post another one that you have that would look good.
Discussion Australia's Manilla Slope Fest 09 be there steve wenban Slope 1124 Feb 05, 2010 02:11 AM
Question Anyone know sources for Spitfire Mk XIVe cross-sections? RAFster Scale Kit/Scratch Built 6 Mar 05, 2007 11:51 AM
Discussion Spitfire Experts Mk. V, Mk. IX scale differences Jim Connell Electric Warbirds 3 Feb 22, 2007 10:14 AM
Build Log Spitfire 50"WS Plans & Build Ralph A. D'Amelio Electric Warbirds 84 Jan 08, 2006 03:45 PM
Achtung Spitfire!!! (or Spit XIVE before maiden) flipnidaho Foamies (Kits) 30 May 19, 2003 09:52 PM
