Old Jun 17, 2010, 01:03 PM
Waldopepperaxe is offline
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
Alright DOG good job.
I think you guys are slowly talking me into building a 100% now, I can't wait to go for a ride.
Waldopepperaxe is offline Find More Posts by Waldopepperaxe
Old Nov 29, 2010, 04:19 PM
billd76 is offline
Find More Posts by billd76
billd76's Avatar
United States, PA, Nottingham
Joined Aug 2009
Is this thread dead?
I just got the twist 60 ARF. Man too easy. Everything is done, control surfaces pre hinged. Fuel tank lines and piping already installed!! Any way. I'll be running a super Tigre 90 Ringed in it. Currently has a 13X6 APC prop. I have read that some folks are using a 15 X 6 with this setup in their twist. Also what servos are you all using? Book calls for standards. I am not an extreme 3D flier (Yet). And CG. I have read that 5.5 from TLE, is the way to go at first.
billd76 is offline Find More Posts by billd76
Old Nov 29, 2010, 04:48 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Try this thread.... Welcome to the addiction.
http://www.rcgroups.com/forums/showthread.php?t=1177628
Ron
DaOldGuy is online now Find More Posts by DaOldGuy
Old Nov 29, 2010, 10:31 PM
NY
Joined Jun 2008
Hey Billd76 welcome and no the thread is not dead, So follow the link Daoldguy gave you as that is where the gang hangs out, this thread is just for a quick and easy reference guide.
Old Mar 25, 2011, 04:07 PM
blrogersjr is offline
Find More Posts by blrogersjr
Joined Feb 2011
twist flat spin
hey guys i'm flying a twist 40 v2 , i cant do a flat spin i've moved the balance all over used a supertiger 46 pro, 12x4 prop even on high rates with all the throw i can get it wont work. i'm missing something in my settup i've read it needs some up aileron mixxed in just not sure how, radio is a futaba 6ch ppm.any help would be greatly appreciated, thanks
blrogersjr is offline Find More Posts by blrogersjr
Old Mar 25, 2011, 05:04 PM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Hi - Take this over to the Twistaholic thread and we will give you a hand.
waynemia is offline Find More Posts by waynemia
Old Apr 20, 2011, 07:31 PM
YFD27 is offline
Find More Posts by YFD27
Joined Mar 2011
guys just a few easy questions from a new twist 40 flyer. I had to add about 3 ounces of weight just behind the fire wall to get it to balance at 5" behind the leading edge, is this normal? Also the plane is very hard to fly at 35% DR because the elevator is just way to darn much, is this because of the CG? Any pointers would be nice it is very easy to fly at high speeds but you slow it down and shes a horse of a different color. thanks in advance, YFD 27
YFD27 is offline Find More Posts by YFD27
Old Apr 20, 2011, 08:00 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Old May 18, 2011, 07:15 AM
NoMatta is offline
Find More Posts by NoMatta
Cookies Good - Bacon Better
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Here is a photo of the winglet I put on my T-40. The holes are 2 inches from the front of the winglet and are 6 inches apart. You can use the 6 inch dimension to scale them to the size that I cut out, but they could be sized to any size you want.
I made them of a lamination of 3/32 balsa and 1/32 ply. The ply could also be 1/16 for more stiffness. I spread a very thin layer of epoxy on the ply then laid the balsa on it and put a weight (concrete block) while curing.
Best way to attach is to carefully remove the covering on the tip first. Then I traced the outling of the tip rib on a piece of 1/8 balsa, cut out two pieces. Then trace these onto a piece of light plywood and cut out two pieces. Epoxy together. Drill the holes to match the holes in the winglet. Put blind nuts in the holes on the Lite Ply side (I used 6-32). Epoxy to the wing tip, balsa side out. Recover. I used 6-32 thumb screws for attachment. These winglets are really quite large and nearly drag the ground. I think they could be cut down. Don't think shape is all that important either. I made them the size they are so I can put them on the T-150 if the mood moves me. Try 'em out.
NoMatta is offline Find More Posts by NoMatta
Old Aug 03, 2011, 06:05 PM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
GAS - Walbro - Carb Tuning
Old Jun 04, 2012, 07:04 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Old thread bumpus
I have added some very interesting info on the Castor vs Synth debate to page one.
.......if your into that
http://www.rcgroups.com/forums/showp...3&postcount=13
Reminder to newcomers.......please leave this thread clean.
If you have any questions about Twist's or questions of ANY kind please visit us here...................
http://www.rcgroups.com/forums/showt...2#post21799916
Dad_Roman is offline Find More Posts by Dad_Roman
Old Jun 04, 2012, 09:27 PM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Thank you Shane, we have done a good job of keeping this thread relatively clean and full of good information. For those of you who don't know why this thread even exists when there is such a vibrant Twisraholic thread, it is simply to keep information of the FAQ type in one easily digested thread. We appreciate you keeping it unencumbered while also encouraging you to join us on the other thread to offer advice, ask questions, or just hang out. Happy flying!
plowboy1966 is offline Find More Posts by plowboy1966
Old Jul 30, 2013, 06:29 AM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
PropsnWings is offline Find More Posts by PropsnWings
Old Mar 21, 2015, 09:48 PM
NoMatta is offline
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Doing a little bump to make this easier to find for while
Old Apr 18, 2015, 01:20 PM
Do Da Dippidy
Joined Jun 2008
Thanks Bob! And kudos to everyone for keeping this thing sow to only four pages in six years!! Lol
FS: Original Electrostreak Kit, NIB w/ motor, plans etc. $70 747drvr Aircraft - Electric - Airplanes (FS/W) 7 May 17, 2003 10:29 AM
GWS Zero : mods, building, etc. Buku Gaidin Parkflyers 2 May 08, 2003 06:41 PM
FS: Original Electrostreak Kit, NIB w/ motor, plans etc. $70 Balin Aircraft - Electric - Airplanes (FS/W) 1 Dec 17, 2002 11:47 AM
GWS Zero tips/mods Hague Parkflyers 3 Oct 29, 2002 05:25 PM
Dymond's Flipper - what mods, batteries etc. work the best? Ron D Electric Sailplanes 0 Sep 18, 2001 10:16 AM
