Old Jul 29, 2009, 12:58 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Originally Posted by u2builder
Could someone tell me what the typical weight of a Twist 40 is (with OS 46) and what the wing area is? Approximately.
Wing Area: 747.37 sq. inches
Loading: depends on the final weight
Weight 5-6 lbs. depending on engine choice
gregory.da is offline Find More Posts by gregory.da
Old Jul 30, 2009, 08:14 AM
waynemia is offline
Find More Posts by waynemia
A trail of smoke is GOOD!
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Wing load is about 8.5 oz/in at 5.5lbs flying weight and 750 sq in area.
waynemia is offline Find More Posts by waynemia
Old Aug 07, 2009, 11:28 AM
waynemia is offline
waynemia's Avatar
USA, TX, Springtown
Joined May 2008
Battery Help
Old Aug 10, 2009, 10:28 AM
NoMatta is online now
Find More Posts by NoMatta
Cookies Good - Bacon Better
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
Fasteners
One of you posted this link on the other thread and I thought that it might fit will be easier to find here later.
I'll make a note over at T---taholics suggesting when we find this kind of stuff to post the links in both places.
http://www.rtlfasteners.com/
NoMatta is online now Find More Posts by NoMatta
Old Aug 18, 2009, 12:56 PM
Waldopepperaxe is offline
Find More Posts by Waldopepperaxe
Walk of Shame Season :)
Waldopepperaxe's Avatar
NY
Joined Jun 2008
AGGREED !!! did you mean to delete your post,, not the thread
Waldopepperaxe is offline Find More Posts by Waldopepperaxe
Old Aug 26, 2009, 05:50 PM
plowboy1966 is offline
Find More Posts by plowboy1966
Do Da Dippidy
plowboy1966's Avatar
Joined Jun 2008
Primo!! Sweet! This thing is shorter coupled and the rudder is plenty as is. It will already roll her all the way over. I think making it any bigger would just compound the problem.
The servos go in the tail. One for the rudder and one for the elevator. The 46AX is enough to balance her with two servos in the back. If you use a larger engine you typically need to move the battery back to balance. Standard servos are fine. Futaba 3004s have held up fine for me.
plowboy1966 is offline Find More Posts by plowboy1966
Old Aug 27, 2009, 02:45 PM
jib is offline
jib
Find More Posts by jib
jib
Chief Mechanic for my son
Covington, WA
Joined Oct 2008
Main thread. This is for tips, mods, etc., and welcome!
Jack
jib is offline Find More Posts by jib
Old Aug 27, 2009, 06:57 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Rib template and pinned joints
I'll put the build on the main thread, but here are a couple of "tips" that may be obvious, but I'll show them for general interest.
I made a template to make the ribs by gluing the rib drawing on some 3/32 ply, cutting away the overhanging ply with a hobby knife, and making the spar and LE notches.
I pinned the template over the rib balsa and used it to guide the knife. Then I removed it, added some clamps to stabilize it, and lightly sanded the edges and cleaned up the notches.
All the ribs are very uniform. It probably took about 5 minutes per rib. I made them all 1/16 and will laminate 3 to make the end ribs. (3 laminated seems like enuf to me). The template did not seem to be affected by the sanding.
I have found that sometimes the butt glued joints on tailfeathers and ailerons can come apart so I drill them and stick in a hardwood toothpic and add a drop of CA. I got this tip from Justerik on the MOJO thread and think it works great so am passing it along.
Now I just need to wait for my balsa to come.
u2builder is offline Find More Posts by u2builder
Old Aug 28, 2009, 09:57 AM
NY
Joined Jun 2008
looking great U2builder !! those ribs do look sweet, very nice job indeed.
One more tip on joining the elevators, you could also use a hard wood dowel, when I made the elevators I made the leading edge center to about 1 1/2 inches on each elevator half, music wire is a fine choice also, to me the solid one piece leading edge center gave it that little extra strength and there is no play at all between the elevators. So it seemed to be much more solid and the added weight helped adding a little tail weight, as most of us prefer it be a little more tail heavy on this bird for the 3D stuff.
Just my 02
Here is a Pic of the wood dowel joiner, I edited my last post also
Old Aug 28, 2009, 10:50 AM
waay is offline
Find More Posts by waay
Lawndart
waay's Avatar
Camas WA
Joined Apr 2008
HA! Leave it to plow to cheer from the flightline.
waay is offline Find More Posts by waay
Old Aug 28, 2009, 12:44 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Old Aug 28, 2009, 12:55 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Aug 28, 2009, 05:07 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Old Aug 28, 2009, 05:11 PM
NY
Joined Jun 2008
Old Aug 28, 2009, 08:38 PM
NoMatta's Avatar
Portland, Oregon
Joined Sep 2008
FS: Original Electrostreak Kit, NIB w/ motor, plans etc. $70 747drvr Aircraft - Electric - Airplanes (FS/W) 7 May 17, 2003 10:29 AM
GWS Zero : mods, building, etc. Buku Gaidin Parkflyers 2 May 08, 2003 06:41 PM
FS: Original Electrostreak Kit, NIB w/ motor, plans etc. $70 Balin Aircraft - Electric - Airplanes (FS/W) 1 Dec 17, 2002 11:47 AM
GWS Zero tips/mods Hague Parkflyers 3 Oct 29, 2002 05:25 PM
Dymond's Flipper - what mods, batteries etc. work the best? Ron D Electric Sailplanes 0 Sep 18, 2001 10:16 AM
