Old Apr 07, 2009, 06:46 PM
Adair Aerodrome's Avatar
Albany, Oregon
Joined Jul 2005
BCRCC 2009 Pylon Racing Plane
MS Composites P-51 Mustang
Default specs.
Wingspan: 950 mm 37.5 ”
Fuselage Length: 830 mm 32.6 “
Elevator Width @ CL: 40 mm 1.57”
Distance from prop to LE: 191 mm +/- 12.7mm 7.5” +/- .5”
Motor: KMS Brushless 2208/12 Quantum
BEC: Castle Creations Thunderbird 18
Battery: ThunderPower 1320/1350 mAh 7.2 V 2 cell Lipoly
Prop: APC 9 x 4.7
Weight: Minimum Weight – TBA
The Plane must be built as per included instructions with the following acceptable modifications
Acceptable modifications to airframe:
• Change motor mount
• Imbedding R/C gear *, wires, etc in fuse
• Change thrust vector
• Painting airframe
• Add skid plate
• Have beveling at hinge points
• Reinforcing and stiffening fuselage, wing, stabilizer and rudder
• Use alum, cord, carbon fiber or wood for modifications
NOT ALLOWED/UNACCEPTED!
• Changes to airframe from stock- rounding the outside edge of airframe, stabilizer & rudder
• Change the size or using only one aileron
• Using no rudder
• Using less than the entire elevator
• Changing the timing of the ESC
• Changing the incidence or location of wing stab or fin
• Covering with film or filling outer surfaces, trim is allowed
* The Castle Creations Thunderbird 18 must be mounted visibly
Adair Aerodrome is offline Find More Posts by Adair Aerodrome
Old Apr 09, 2009, 12:39 AM
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
I think this is the correct picture (I haven't seen it yet).
SteveM732 is offline Find More Posts by SteveM732
Old Apr 09, 2009, 01:15 PM
Electric Sport Flyer
Albany, OR
Joined Apr 2009
Downloading a picture
Hi Steve,
I have been trying to download a JPG file and cannot seem to make it work. When I review my reply, all I see is [IMG]. I would have expected to see my plane when I review my reply. What am I doing wrong?
flyinged320 is offline Find More Posts by flyinged320
Old Apr 09, 2009, 01:58 PM
SteveM732's Avatar
Joined Feb 2008
There are two ways to post images on RCG. One is to link to an image file located on a website somewhere else and the other, as I have done above, is to download the picture to my PC then upload it to RCG as an attachment to my post.
The first method is not used much, it uses the [IMG] tags as shown here.
The second method requires you to click on the "Manage Attachments" button that is below the area used to type your reply. This opens up a new window where you can upload files, designate the order they are to appear in, add a caption, or delete attachements. Once done which adding pictures click "Save Changes" then close the window. You will not see any of these attachments when you preview your post, you just have to trust that they will show up when you submit your reply.
Give it a try, let's see your pylon racer!
-Steve
Old Apr 09, 2009, 02:49 PM
Albany, OR
Joined Apr 2009
OK, Steve,
Hopefully, you will see a picture of my racer. It weights 13.5 oz, has a light ply front end and did not need any lead weight. I am looking forward to flying it.
Old Apr 09, 2009, 03:01 PM
Albany, OR
Joined Apr 2009
Steve,
Now that I got the hang of this...here are some more closeup pictures of my racer.
Old Apr 09, 2009, 04:36 PM
Joined Nov 2003
I haven't seen any sign-up for colors. Are we using streamers again this year and just relying on those?
KE Ryan is offline Find More Posts by KE Ryan
Old Apr 12, 2009, 11:51 PM
United States, WA, Seattle
Joined Apr 2009
Hey guys,
I took a small video of my plane and how I've placed everything. Feel free to ask questions. Right now I've not had to add any weight to balance the plane at the recommended CG.
P-51 Mustang Pylon Racer (1 min 31 sec)
Cheers,
Montana
harking is offline Find More Posts by harking
Old Apr 16, 2009, 01:08 PM
gonzales's Avatar
United States, OR, Albany
Joined Feb 2005
I'm thinking about using dual aileron servos? Do you guys think that this would be a legal mod?
Figured that I would ask before I cut any holes. :-)
-Matthew
gonzales is offline Find More Posts by gonzales
Old May 18, 2009, 05:06 PM
gonzales's Avatar
Joined Feb 2005
Well, she is finished. Took her out this Sunday for her maiden flight. Only a few clicks of trim and good to go.
Kind of seems slow compared to last years racer. Any thoughts?
I'll get the tach and watt meter out and take some readings.
Here is what I got...
Peak
15.22Ap
111.2Wp
7140RPM
Avg
13.89-14.4Amp
7000RPM
at 8.36v, .65W no load static
-Matthew G.
Old Sep 05, 2010, 01:11 AM
Electric
Joined Oct 2009
ERCA Intrest
Hey guys.... I'm one of the Eugene guys and wanting to get my own plane to jump into the frey, what are the latest specs? I have heard a 3s lipo pack is now used? I'll head up to the field this weekend if I don't hear something soon.. =)
DSD
DeadstickDuck is offline Find More Posts by DeadstickDuck
Poll Pylon Racing Plane Selection for 2008 Season HappyKillmore North Coast Electric Flyers 32 Mar 02, 2008 08:57 AM
Sold VIPER 500: quickie 500 pylon racing plane with servos, batt, and switch. simo10 Aircraft - Fuel - Airplanes (FS/W) 0 Jun 05, 2007 10:09 AM
Looking for some online clips of pylon racing Foxtrot Electric Plane Talk 9 Jul 26, 2001 10:38 PM
So Cal S400 Pylon Racing Troy High Performance 1 May 03, 2001 09:45 AM
