Old Apr 06, 2009, 09:46 AM
Australia
Joined Mar 2007
No RPM Reading on new Elogger V3
Hello Support,
I have just purchased a Elogger V3, but are unable to get the RPM to work.
I am using the magnetic sensor, have configured for magentic sensor and get 0 rpm.
I have tried sensor both ways, magnet both ways with no joy. Thought the sensor may be faulty so ordered a replacement which arrived today and it still doesnt want to play ball. Still get 0 rpm
Tried different magnets. And even stuck one magnet on the shaft of a battery drill, with the sensor taped up next to it so that I was getting some reasonable RPM to measure.
Also ordered a optical rpm sensor to try, and configured the unit for optical rpm and still get 0 , no jumps or any other reading, just shows zero the whole time (other guages are working OK)
The other sensors I have (two temp sensors, altitude, airspeed, LCD PowerPanel) all seem to work fine. Shows pack voltage etc, in live mode.
I had a look through the forum on RCGroups and posted a querie and another member suggested I check the RPM sensor type setting. Have checked and it is set right.
Have downloaded latest software from your site, and run the firmware update. The unit came with CD labeled ver 6.93.
I purchased the unit from Hobby City about 6 - 10 days ago, and I am located in Australia.
Any suggestions or help you can offer would be appreciated.
Thank you in advance for your help!
Cheers
Scott.
lilredrex is offline Find More Posts by lilredrex
Old Apr 12, 2009, 03:19 PM
billpa's Avatar
Joined Nov 2003
Hi Scott,
Sorry to hear about the issue! It sure sounds like the RPM input port of the eLogger is not working, unfortunately. Our automatic tester checks that, but something may have happened to the logger after our testing.
Probably the best course of action is to contact Hobby City about a replacement. Sorry about that!
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Apr 30, 2009, 06:15 AM
Australia
Joined Mar 2007
Originally Posted by billpa
Hi Scott,
Regards,
Hi Bill
Thanks for your help, have sent back to HobbyCity for replacment. In the mean time the 2nd one I ordered turned up and works a treat!
Downloaded my flights on the w/end and got some real insights in to what is going on. Great products
Cheers
Scott
Old Apr 30, 2009, 01:08 PM
billpa's Avatar
Joined Nov 2003
Hi Scott,
Sorry for the trouble, but glad you got it working! We'll ultimately get the problem eLogger back from HC and will determine what went wrong.
Regards,
Site Sponsor
Discussion No lift on New Lama V3 !!! NTS006 Power Systems 5 Jan 20, 2008 07:27 PM
Discussion Whitewall tires and vinyl roofs on new cars; yes or no? Flyingwingbat1 Life, The Universe, and Politics 10 Mar 07, 2007 10:49 PM
No Brake Disable on new Castle link/ firmware 1.22? JoeR Castle Creations 1 Oct 29, 2005 03:18 PM
Help! My New Hummingbird v3 Is On FIRE!!! djs7795 Micro Helis 3 Aug 04, 2005 12:25 AM
Rant No wires/leads on my new Mega....???? mr_ken Power Systems 7 Mar 11, 2004 07:35 AM
