Old Apr 07, 2009, 02:35 AM
AttackingHobo is offline
Find More Posts by AttackingHobo
Laguna Beach, CA
Joined Dec 2008
Ok The plane is done.
One thing that I did not touch upon earlier, is the hinging method I used. I was looking for my hinge tape, but I could not find it. So I used a method I have only used once with a scrap piece of foam to test it.
I used Hot glue. I put a generous amount down on the seem edge, and before it dried, I smeared the glue thin with a flat piece of scrap foam. It makes a really strong thin flexible joint.
I used adhesive Velcro strips to attach the battery and the receiver in the fuselage. I would have liked to mount them forward a bit more, but the wire length restricted me.
I decided to give the plane some permanent flaps on the bottom to force the air down, creating a better lift at the expense of some drag. I have a feeling that this one design change will make the difference from a GEV and a plane. I also added end plates to the ends of each wing.
I used small little ribs to hold the flaps in place. THIS IS THE BOTTOM
Showing the angle, I don't have anything to measure the angle with, but this shows it pretty well. NOTE THIS IS THE TOP
showing it from the front. THIS IS THE BOTTOM
Showing the ribs better along with side end plates THIS IS THE BOTTOM
Attaching the wing to the fuselage.
It is secure in the back now
Showing the front rubber band mount.
Rubber band attached
Full side view
Better full side view
I want to be able to fly this on most any surface without the plane being chewed up, so I used part of a thin plastic cutting mat as the the skid plate which covers the entire bottom of the fuselage.
From the front
The plane balanced at 7 inches from the leading edge when it should be around 4 inches from the leading edge. All the electronics are in the rear of the fuselage, so I needed a bit of ballast.
For ballast I filled two bottoms of server containers full of lead shot, and glued a piece of foam on top to secure all the shot inside.
I used 10 ounces of shot.
The plane it self weight a total 30 OZ with the Ballast and 20 OZ without
I am going to test fly it tomorrow, it will be on video, so I will either have a cool success video or a crash video followed by a rebuild thread.
AttackingHobo is offline Find More Posts by AttackingHobo
Old Apr 07, 2009, 09:02 AM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Originally Posted by AttackingHobo
...I will either have a cool success video or a crash video followed by a rebuild thread.
Can't wait to see it. I agree you've made a plane rather than a GEV. If you don't keep the speed down it's going to try to get out of ground effect fairly quickly. Although, the high thrust line is going to tend to keep the nose down. It'll be interesting no matter what happens. (That's easy to say when all you have to do is watch. )
Originally Posted by Dickeroo
... It's all about "owning" the experience which can then be applied to a future project. Like putting assets in your memory banks. Eventually, they all add up.
I just wish I didn't suck at math.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Apr 07, 2009, 01:47 PM
Laguna Beach, CA
Joined Dec 2008
Oh this is one of the original sketches I did on the design of the craft.
Done with the program Colors, on my Nintendo DS
Old Apr 07, 2009, 02:48 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
SEC. 336. SPECIAL RULE FOR MOD
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by tuppertn
Can't wait to see it. I agree you've made a plane rather than a GEV. kendall
The further it comes along the more I like it as a plane design. With tweaks it would make a wonderful AP!
DaOldGuy is online now Find More Posts by DaOldGuy
Old Apr 07, 2009, 02:53 PM
Laguna Beach, CA
Joined Dec 2008
Sorry, what is an AP?
Old Apr 07, 2009, 03:24 PM
DaOldGuy's Avatar
Joined Dec 2007
Air photography
Old Apr 07, 2009, 03:28 PM
maxthepaco is offline
Find More Posts by maxthepaco
Joined Mar 2009
it'd say GEV instead of WIG.. but ya that's just me.. looks good.. what are the mods you did?
maxthepaco is offline Find More Posts by maxthepaco
Old Apr 07, 2009, 03:33 PM
enduro_man996 is offline
Find More Posts by enduro_man996
Yummy cheese
enduro_man996's Avatar
Earth
Joined Mar 2009
Interestingly intresting... So what happened? ? ?
I am facinated... enthralled... O tell us please!
enduro_man996 is offline Find More Posts by enduro_man996
Old Apr 07, 2009, 03:49 PM
Laguna Beach, CA
Joined Dec 2008
It is still at my house. I am going to fly it this evening with MaxThePaco spectating.
I should have a video camera to film the event. I will try to post it later this night.
Old Apr 07, 2009, 04:03 PM
Laguna Beach, CA
Joined Dec 2008
GEV: Ground Effect Vehicle
WIG: Wing in Ground(Effect Vehicle)
Same thing :P
Old Apr 08, 2009, 12:50 AM
Laguna Beach, CA
Joined Dec 2008
Well I crashed it, but it is not too bad, and only there was pretty much area of failure that caused the faliure in the first place.
The wing is fine and the control surfaces are fine.
I did get a video of it, and will upload it tomorrow.
Old Apr 08, 2009, 11:09 PM
Laguna Beach, CA
Joined Dec 2008
I rebuilt it, and I think it was perfect, except for sliding parts I put on to be in contact with the ground. I have a pair of wheels that I think will work perfect for this.
I didn't crash it, the skids fell off.
I will see about the video uploading now.
And I just realized something, I do not have a video editor on my PC at the current time.
I am going to have to upload these on the weekend.
Although I will upload the pictures of my design.
Old Sep 06, 2009, 03:31 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Update?
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Sep 06, 2009, 12:46 PM
Mikey C. is offline
Find More Posts by Mikey C.
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
That's a really neat design. Did you get it to work?
Mikey C. is offline Find More Posts by Mikey C.
Old Feb 28, 2010, 01:05 PM
experimentalrc is offline
Find More Posts by experimentalrc
Joined Apr 2009
... Well? Any updates?
experimentalrc is offline Find More Posts by experimentalrc
Discussion WIG - Wing in Ground-Effect alexcmag Waterplanes 21 Dec 21, 2015 04:28 PM
Idea Tutorial: How to build a wing in Rhino3D cathode The Builders Workshop 54 Apr 10, 2009 09:16 PM
Off Site Exotic Aircat 2.0 Part Assmb Kit Wing in ground effect (WIG) vrylowflyer Aircraft - General - Miscellaneous (FS/W) 0 Jul 30, 2007 08:57 AM
Need idea on build a wing in depron Niggo Foamies (Kits) 1 Sep 21, 2003 08:56 AM
