Old Apr 05, 2009, 05:15 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
New Product
new dsr-30 retracts
smaller, lighter version with metal gears...options include 90 degree rotating and leds...i can think of quite a few models (not just jets) these could work in...if i'm able to get a few for testing, i'll post my findings...
http://www.epf.com.tw/dsr30/dsr30_complete_Set.html
gunracer is offline Find More Posts by gunracer
Old Apr 05, 2009, 07:19 PM
jhspring is online now
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
Gun, I would really be interested in seeing how these hold up. The originals were c%^& unless you made greasers on a smoothly paved surface. Love the idea, hate the executions. I notice that all the loads are still taken by those sill little plastic ears, instead of rails, like Robarts have. Please keep us posted.
Cheers,
Jeff
jhspring is online now Find More Posts by jhspring
Old Jul 26, 2009, 08:10 PM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
i just got a non-rotating set for testing...i'm told the rotating set should be available in the next month or so...along with the metal internal gears, i also like how the wires exit the housing...in the original design, the wires were in a bad spot and tended to break loose...the included struts a 2.5mm and the included tires are about 1.75" in diameter...i'm installing this set in a new gws a-4...
Old Jul 26, 2009, 11:25 PM
FlyinAg is offline
Find More Posts by FlyinAg
I Love 30mm
FlyinAg's Avatar
United States, TX, Wichita Falls
Joined Nov 2001
http://www.rcgroups.com/forums/showthread.php?t=940289
check that link out first.....
FlyinAg is offline Find More Posts by FlyinAg
Old Jul 26, 2009, 11:42 PM
Kometfreak is offline
Find More Posts by Kometfreak
Joined Sep 2002
A for effort in design, F for materials selection of these retracts. The trunions and side braces are now made from aluminum. Sadly, the rest of it is stilll made from sub-par plastic that can't handle the load.
Roy
Kometfreak is offline Find More Posts by Kometfreak
Old Jul 27, 2009, 01:31 AM
Jet Dreams is offline
Find More Posts by Jet Dreams
Jet Dreams's Avatar
Farr West, Utah USA
Joined Dec 2003
I sure hope these are better than the first ones.
How can we buy them?
Jet Dreams is offline Find More Posts by Jet Dreams
Old Jul 27, 2009, 01:23 PM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
the weak points in the original dsr-46 design were:
- plastic trunions (pivot points tended to snap off)
- plastic internal gears (worm gear tended to strip)
- wire connections (solder points tended to break loose)
the above issues have been rectified with the dsr-30...i've also heard a metal gear version of the dsr-46 should be out in the next month or so...
for the record, i'm not involved in the manufacturing, distribution or retailing of these units...as long as the units work well, they are another option to mechanical and pneumatic retract systems...good or bad, i'll post my findings...
Old Jul 27, 2009, 01:38 PM
gunracer is offline
gunracer's Avatar
Corona, CA
Joined Feb 2006
http://www.sonicelectric.com/Merchan...ry_Code=DSR-30
you can also get them at hobbycity i believe...
Old Jul 27, 2009, 02:00 PM
Jet Dreams's Avatar
Farr West, Utah USA
Joined Dec 2003
Just waiting for your report on them.
I wish they were available for a heavier plane.
Old Jul 28, 2009, 08:44 PM
Sid3ways is online now
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Those 46 sized retracts in V2 should be out any day now. They are rated up to a 7 lb. plane. They look 100x better than the first version that came out, those were complete garbage.
By the way, Hobby City is selling these 30 sized ones for ~$70. Not bad at all.
Sid3ways is online now Find More Posts by Sid3ways
Old Jul 31, 2009, 04:23 PM
Jet Dreams's Avatar
Farr West, Utah USA
Joined Dec 2003
Is Hobby City selling the new ones? they don't make it clear on their web page. Pics look like metal gears.
http://www.hobbycity.com/hobbycity/s...idProduct=9300
Old Jul 31, 2009, 04:25 PM
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Yes, the 30 sized ones are completely new units and never came with the crappy plastic internals.
Old Aug 15, 2009, 12:56 AM
Jet Dreams's Avatar
Farr West, Utah USA
Joined Dec 2003
gunracer, How did the gear perform? Are the 46 sized ones out yet?
Old Aug 15, 2009, 03:19 AM
dareh is offline
Find More Posts by dareh
Joined Jan 2005
Hey could someone reconfirm the hobbycity 30 size ones are actually with metal gears inside (not only metal arms)? I'm about to buy them from sonic electric cause it clearly says metal gears inside on their web but the price difference of almost 50$ would probably make the hc a better choice if theirs also metal geared.
dareh is offline Find More Posts by dareh
Old Aug 15, 2009, 01:18 PM
Jet Dreams's Avatar
Farr West, Utah USA
Joined Dec 2003
Thats a good question... I wondered why hobbycity was so much cheaper after shipping they're still about $30 less.
FS: Two Hitec HS-81's, new cond. $30 shipped P-51 fan Aircraft - Electric - Airplanes (FS/W) 4 Aug 03, 2003 02:11 PM
New Quick 30 w/motor w/gyro w/servos 95% complete ldracer Aircraft - Electric - Helis (FS/W) 1 May 25, 2003 12:01 PM
Yippee! New RADIO, 30% OFF Grom Aircraft - Sailplanes (FS/W) 0 Feb 28, 2003 10:26 AM
