| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 | ||
World's Smallest FPV-Camera for RC Airplane, RC Helicopter, RC Cars!
![]() Ideal for both covert camera& hidden camera, small enough to be taken almost anywhere! Wherever you place your mini camera, you’ll know for sure that you won’t miss anything. Ideal First Person View (FPV) system for radio controlled airplanes, cars and helicopters!
What your mini interview recorder includes: Mini Interview Recorder USB cable User manual 2GB Micro SD Memory Disk - Can store up to 2 Hours of Video! Features Dimension:73mm*20mm*11mm Weight:18g Tiny size makes it ideal for a variety of uses It’s great for use as a hidden camera etc. Real time recording in AVI video format, WAV audio format. Color video with voice lets you clearly see who’s there &hear what they say. Place it up high or conceal it down low. With built-in rechargeable battery so there’s no long cord for you to hide. Use micro SD card from 128MB to 4GB - Included FREE 2GB Memory Card Playback video on cell phone or PC Camera Technical Parameter Video Compression: AVI video format,640*480 Voice Recording: Yes, WAV audio Micro SD card/T-Flash card support:128MB to 4GB Video File Size:>500KB per minute Recording Mode: Continuous recording until memory is full or manually off Adaptor Type: USB adaptor charging cable Battery Type: Lithium-ion Record Time:4-6 hours, it has function of recoding audio alone for 2 days. Click here to Buy-it-Now |
#2 |
it's just plane fun
Very Impressive. One question, where is the lens opening located on the camera body?
#3 | |
#4 |
the best cat in town. :)
good camera
#5 |
FLAPS? We don't need no Flaps!
mini DVR camers
They were out of stock so I found one elsewhere and I have been having a blast with it, I mount them on my scratch built foam airplanes.
you can check out my planes and a video at http://www.ragwing1.com/foamair/colt.htm and http://www.ragwing1.com/foamair/bb.htm and a movie I made with it at http://ragwing1.com/foamair/aircam5.wmv |
#6 |
helo i have found much smaller FPV
this is the REAL SMALLEST FPV SYSTEM OF THE WORLD!! http://www.rctech.ch/fr/videos/item/fpv/x-twin-fpv.html CHEERS |
#7 |
Plugging in the recorder via usb does not show up as a drive on the computer. The promotional video said that plugging in via usb one could read it as a flash drive. Any idea whats wrong?
#8 |
Re the X-twin fpv...
Anyone got any clues where to buy a 5 gram (!!!) Camera and transmitter combo what do you think they are using? The smallest camera/transmitter packages I have seen are around 20 grams. |
