| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
Thanks to all for the links and pictures. Wof, I wouldn't worry about the diversification, all threads spread around a bit.
![]() With he pictures available, I guess I'll have to go with the rounded tips now. At least I won't have to cover them as I plan to paint it. Those tips would be no fun to cover with film. |
#62 |
MultipleCrashSurvivor
Arthur
What kind of lithium cells are you using? According to your calculations the cells are 950mah? The chart you're referring to is good only for the Etec cells, Kokams will only handle 5C in short bursts. If you have the new high output Kokams then they're good for 8-10C. The life of the pack should be good as long as you don't drop it below 10volts in the current config now, 4S6P. |
#63 |
Art do not forget the tip lights He He
#64 | |
The key is to have two hands to pull on the covering while you heat it. A actually had my heat gun between my chest and my chin trying to hold it at the right angle and that worked somwhat. I kept heating and stretching the stuff and got it to shrink enough. This worked better than an iron I guess because the heat was spread out more evenly. The Ultracoat lite takes paint well, I used Testors Model Master sprays and didn't even rough up the covering first, I was in a hurry. Some paint did come off when I was masking with newspaper but I only uses small doubled up tape loops to hold the paper off the surface a bit to get a soft masking edge. Sanding with steell wool or 600 grit might have prevented that. |
#65 | |
Based on the data provided for IR for single cells (.035) my motors & fans will pull 52 amps at full throttle - static. That's about 7C. In flight the motos & fans will pull 35 amps. That's 5C. I don't expect to fly at full throttle all the time. That's estimated at 90 mph. All these calculations are based on Motocalc values and are just estimates. I'll firm up values as the plane is built and I can adjust the weight and wing loading accordingly. As it stands now, I'm going to put about 175 watts per pound into it. Last edited by Arthur Knowles; Apr 26, 2003 at 03:34 PM. |
#66 |
Ed,
Thanks for the input. As I have glassed the wing, there is no need to cover it with film first. I'll think about doing this with the elevator and rudder though. That may be better than glassing it as well. Wof, Lights. Hah, that's a good one. ![]() On the serious side though, if the plane flies well I will be adding scale details to the fuse and wing. Lights (non operational ones) may not be too far fetched. Art |
#67 |
The stage i am at excuse the poor building area no space
#68 |
The fuse
#69 |
Picture 1 just to make sue all flat and correct washout,picture 2 just drying
#70 |
Wof,
So, no operational rudder, huh? I've been thinking about that a lot. I have one HS-81 servo I could use for the rudder. If I could figure out a good way to make them operational without making it too ugly. I thought about using a pull-pull cable with a tie between the two movable surfaces. I could mount the cable on the external (outside) surfaces. Maybe use fishing line (clear). Or maybe use a pull cable on the inside surafaces with the external surface under tension. Though that one bothers me is the line snapped (i.e. the tension would pull the rudder out and possibly cause a crash). I think a passive system would better. Anyone have any ideas they'd like to share? Art |
#71 |
This will be quite a simple version no operational rudders you can just see the bungee hook on the fuse,the sites i fly from are grass with a nice long tarmac runway but i cant guarantee i can always land on it.
It maybe easier to have a stearable nose wheel i assume it will only be used for take-offs? Mark |
#72 |
Wof,
I will have a steerable nose gear. I will only use it for takeoff, landing, and taxi back to the pits. Unless it has problems taxing on the dirt runway we have. I'll be using a micro servo for the steering. If I have functional rudders, it'll use another servo with a Y connector. I just haven't decided on the rudder because of the complexity. Most likely, I'll skip a functional rudder. If I do, it means no stall turns. No snaps. No knife edge or 4~8 point rolls. Art |
#73 |
I must get used to the fact that electric flight has advanced so much from when i got into it a good few years ago,it was an achievement to have a EDF that could fly let alone do a roll.
My first plane that surprised me was made by an english company called MFA it was the first plane that i had that could do a loop and a roll from level flight cant think of its name. I am just getting back into electrics got quite a few planes ready for our two week summer when it arrives. |
#74 |
Arthur no need for rudders the plane is small enough that it only becomes and issue in severe crosswind conditions, where the nose gear can't correct the force of the wind on the rudder planes.
Wof, the plane hand launches pretty easy depending on the weight, for those who use a bungee like DR jet and jepe have uses fixed wheels in the nacelles like if the real ones were retracted and a tail wheel (I think) this would allow for landings on paved surfaces. also this model will roll loop, fly inverted, split S and (by accident) do a hammer head)
#75 |
Art more curly tips to see,got the wing 1/32 balsa covered now been sanded reinforcing the servo wells then to glass we go.
| Thread Tools | |
| Question EJF Composite A-10 | nighthawk117 | Electric Ducted Fan Jet Talk | 4 | Jan 01, 2007 08:51 AM |
| FS NIB EJF Mini A-10 - composite. With Fans..... | jfruge | Aircraft - Electric - Airplanes (FS/W) | 10 | Nov 19, 2002 12:02 AM |
| EBAY: Never Flown EJF Composite Mini A-10 FS | jparisse | Aircraft - Electric - Airplanes (FS/W) | 15 | Sep 15, 2002 09:57 PM |
| NEW! EJF Composite Mini A-10 RTF | jparisse | Aircraft - Fuel - Airplanes (FS/W) | 1 | Sep 09, 2002 12:34 PM |
| EJF Mini A-10 Kit Info Please | FullScalePilot | Electric Ducted Fan Jet Talk | 6 | Nov 10, 2001 07:44 PM |
