Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Apr 23, 2003, 07:51 PM   #46
hoser's Avatar
that looks perfect Arthur
hoser is offline Find More Posts by hoser   Reply With Quote
Old Apr 24, 2003, 10:34 PM   #47
Arthur Knowles's Avatar
Send a message via AIM to Arthur Knowles
FG Wing
Here is a picture of the wing after fiberglassing with .75 oz cloth and Z-Poxy finishing epoxy. I've brushed it down with 80 grit sandpaper to knock some of the high spots/overlap and will hit it later with 220, 400, and 600 before I prime it.
  • Name: fgcoveredwing.jpg
Arthur Knowles is offline Find More Posts by Arthur Knowles   Reply With Quote
Old Apr 24, 2003, 10:50 PM   #48
hoser's Avatar
how does it fell in strength ?
Old Apr 25, 2003, 02:53 AM   #49
Wof
Wof's Avatar
Slow down Art i am tring to keep up with you,are you going for the curly wingtips with carved balsa?
Wof is offline Find More Posts by Wof   Reply With Quote
Old Apr 25, 2003, 03:37 AM   #50
Much stronger than before the FG. There used to be more give in it. Now it has a hard inflexible shell. I'm sure I could break it if I tried, but if that's going to happen I want it to happen in the air!
Old Apr 25, 2003, 03:44 AM   #51
I haven't decided yet. I don't have a good picture of the wingtip to base a carved balsa tip on. I thought about using the kit tips as a template/guess. If I go with carved balsa tips, I'll have to hollow out the block when finished.
Do you have a picture of the tip you can share? If you can't post it, you can e-mail it to me direct at Art@NT-Guru.Com.
As for slowing down, don't worry. There is still a LOT to do. Mostly sanding & filling. Once I have the wing finished the way I want, it's retract and servo time. I just ordered some servo mounts and covers for the plane from Hobby Lobby (used for sailplanes and include a hood for the servo arm/linkage).
I'm also debating reworking the EJF retracts. The mounting ears are very wide. So wide I think the wheel covers I'll make out of balsa will look rediculous in width. They'll have to be 1.5 ~ 1.75+ inches. I can cut at least 1/8" off each side of the mount and redrill it for closer spacing. That would drop it to 1.25 ~ 1.5 inches wide. Possibly more.
Old Apr 25, 2003, 05:09 AM   #52
Wof
Wof's Avatar
I do have a close up of a wingtip at home i will send it to you
Old Apr 25, 2003, 12:02 PM   #53
This is what I did for my RBC A10. It is close to scale and light, I think.
jans
  • Name: pict0020.jpg
JANSSENM is offline Find More Posts by JANSSENM   Reply With Quote
Old Apr 25, 2003, 12:03 PM   #54
another....
  • Name: pict0021.jpg
Old Apr 25, 2003, 12:56 PM   #55
Ed Waldrep's Avatar
There are some great web resources out there with info and pictures including detail shots of full size aircraft. It can really help during building to see how the real thing looks.
www.aircraftresourcecenter.com Go to walkarounds and pick Jet Aircraft...there's like 7 listings for the A-10 with lots of pictures.
They also have a reviews section where they have pics of built models that are helpful, and also articles on aftermarket decal sets. I'm using decals from CAM that are 1/32 scale and i had to blow them up 2.06 times to fit. This homemade decals stuff is harder than I thought, the decal sheet has a light blue background and the decals I got made on a color copier have the same background...oh well, guess I'll need to keep trying.
Here's a nice A-10 model on the same site
http://www.aircraftresourcecenter.co...els/fea692.htm
Ed Waldrep is online now Find More Posts by Ed Waldrep   Reply With Quote
Old Apr 25, 2003, 01:48 PM   #56
Wof
Wof's Avatar
Art try this view
  • Name: a10_2.jpg
Old Apr 25, 2003, 01:49 PM   #57
Wof
Wof's Avatar
There must be some aerodynamic reason for this Hoser can you help?
Old Apr 25, 2003, 01:53 PM   #58
Wof
Wof's Avatar
http://www.a-10.org/
Try this link hundreds of A10 pictures videos etc etc
Jans you must have a few planes on the go now i will have to call you Jans twelve kits on the go the same as me,i must finish one before i start the next.
A10 pictures to follow later.
Old Apr 25, 2003, 02:04 PM   #59
Too lazy to repair!
jperch's Avatar
Wof,
I thought those were known as "Horner Tips". I vaguely remember seeing an article in a modeling magazine many years ago. I could be way off base but I thought they reduced drag by changing the way the vortices developed on the wing tips.
Does this sound right?
Joe
jperch is offline Find More Posts by jperch   Reply With Quote
Old Apr 25, 2003, 03:41 PM   #60
Wof
Wof's Avatar
Sounds good to me Joe.
I am no expert but there are various shaped tips to do the same thing, i seem to remember that there was a jet airliner that changed the shape of its tip increased wing performance by some 5% less fuel burned = cheaper flights.
Art i have just thought this is your building thread sorry to diversify.
Question EJF Composite A-10 nighthawk117 Electric Ducted Fan Jet Talk 4 Jan 01, 2007 08:51 AM
FS NIB EJF Mini A-10 - composite. With Fans..... jfruge Aircraft - Electric - Airplanes (FS/W) 10 Nov 19, 2002 12:02 AM
EBAY: Never Flown EJF Composite Mini A-10 FS jparisse Aircraft - Electric - Airplanes (FS/W) 15 Sep 15, 2002 09:57 PM
NEW! EJF Composite Mini A-10 RTF jparisse Aircraft - Fuel - Airplanes (FS/W) 1 Sep 09, 2002 12:34 PM
EJF Mini A-10 Kit Info Please FullScalePilot Electric Ducted Fan Jet Talk 6 Nov 10, 2001 07:44 PM
Bored? Want to fight?
Join the RCGroups clan!
