Northampton, UK
Joined Dec 2005
Clearly I didn't have enough up elevon at neutral. I'd forgotten the rest of my wings have significant up elevon.
A bit more about my build: I used 3mm depron doubled to 6mm everywhere except the winglets. Am not sure how that compares to 6mm depron, probably a bit heavier with the glue in the middle. If I were to build another I'd go get some 6mm depron as it's a pain having to cut everything out twice. I caused myself problems by using 1/8" liteply; the drawings were based on thinner so it didn't quite match up, but it worked well enough - I have a bit of a gap on the canopy ends. I extended my spars all the way to the end of the wings as it seemed to add rigidity for little extra weight. Seems to have worked well based on cartwheeling on the wing tips a couple of times during my test flights yesterdays. I'm running a Turnigy SK2826-1350 motor on a Turnigy Plush 25A ESC, 2 x HXT900 servos, AR9000 Rx. I'm currently using my normal 2200 mAH 3S wing LiPo which is possibly a little over the top for this model but it's what I have handy. I also have a i-gotU GPS tracker on-board and I'm about to add a D001 (MD80-knock off) mini DV Video Recorder . |
Northampton, UK
Joined Dec 2005
One issue with the knock-off versus the pukka one is that it displays a time/date overlay in the corner of the video. It does not appear possible to disable this which is a shame, but not a major issue. Oh, and the other thing was that it came pre-loaded with a virus on the SD card - something to be aware of but easily solved by a reformat. |
SW England
Joined Aug 2009
I now have all the bits needed for my build, trouble is, I have some more urgent jobs to do first
![]() Jaron, have you seen this... http://www.rc-tech.ch/index.php/en/h...&category_id=7 Nigel. |
| Thread Tools | |
| Discussion flying wing UAV | MIG-29 | Flying Wings | 12 | May 20, 2009 04:27 AM |
| Discussion flying wing UAV | macboffin | Flying Wings | 4 | Sep 03, 2008 05:43 PM |
| Discussion UAV controller for a Flying Wing | Medve | UAV - Unmanned Aerial Vehicles | 3 | Nov 06, 2007 06:48 PM |
| Take a look at this 24 inch flying wing | Acer | Electric Plane Talk | 2 | Sep 10, 2001 02:29 PM |
| I think my downthrust is set wrong on my Electric Flying wing, help! | e-sailpilot86 | Beginner Training Area (Aircraft-Electric) | 2 | Aug 08, 2001 01:54 AM |
